Posts posted by drtrap
And what about the size, I mean the diameter of the encircling line?
Thanks
Regular sewing thread can work just fine. I went to a local store a just bought a bunch of different types (its very cheap), but I ended up using a 65% polyester 'glace finish' which seemed nice and smooth without any fuzz. I'd also recommend you buy some GS-Hypo glue, it works really well with rigging. Dries clear and slightly flexible, works well on false splices.
Jason do you mean hypo gs cement?
I can;t locate something like hypo gs glue, even I use my net browser...
In the meantime, I just wonder: do I need any special rope material for the serving except those of the kit?
Especially for the line that is encircling each mainrope, what kind of material and size is needed?
Thank you all, one more time.
Stergios
It would allow you to use both hands.. my home made version has to be manually turned so I can only use one hand to do the serving etc.. but this allows me considerable control as I can very easily go backwards slightly ! it just takes a little more time for long servings (admittedly that's why mine is 'geared' the way it is with 2 different sized cogs per side)
If it isn't overly expensive why not get it.. I'm sure it (the Motor) can be removed to revert to manual turning for more intricate work.
Eamonn
I agree Eamonn, I'll send a query to be sure that I can remove the motor to turn the procedure to a manual function....
Cheers
Hello again mates.
About that additional power option of the serving machine....
Do you consider it as an important feature except the basic 2.0 edition of the serving machine?
Thanks
I've sent a querying application to Alexey.....
The build is really coming together Stergios.
I would recommend serving as it looks excellent and is well worth the time. I wish I had served all my shrouds on my Snake.
Another question: are any instructional tutorial/videos on what a serving machine can "perform"?
Thanks again
Jim, I have no experience with serving....
Is there any help or manual about the basic steps?
Thanks
Hi Stergios, regards the residue of wax, some people run the waxed line quickly through a candle flame to melt the wax into it.. you may want to experiment a little first though
Also have you thought about building your own Serving Machine (I did just that, you'll find some photos early in my Ballahoo log ) it cost me around € 10 at most if I remember correctly .
Cracking good build you have here by the way, Snake is a beauty.
All The Best
Eamonn
Cheers Eamonn
I'll try to melt the debris the way you mentioned, thank you!
About the serving tool.... is not a matter of money, is a matter of time! I believe that thte remaining time to finish "Snake" will be seriously increased with serving, that's why I continue to resist and try to do my best to accomplish the rigging section without any serving machine...
Thanks again...
Stergios
Some times I think to buy a serving tool but every time I change my thoughts....
Fine work Jim, I like that contrast to the shrouds.
Do u use the lines of the kit or aftermarket supplies?
Have u used any kind of beewax in advance?
Thanks.
A lot of questions...about the shrouds and the mizzen mast...
Should I start making loops in the middle of each line and creating that way a double line running towards a respective pair of deadeyes?
At what distance from the mast should I make the seizing of each pair of line?Thank you all.
- Aussie048, WackoWolf, mort stoll and 1 other
- 4
Hi Jason, do you have any information about the length of the burton pendants?
Is there any length difference between those of mizzen mast and those of main mast?
I'm studying "Rigging period ship models" but olny the plans are illustrated....
Thanks.
- mort stoll and Aussie048
- 2
I used a double block.
Mort
Hi Mort and thank you.
Did you place it in the middle of the last crosstree?
Hi everybody, as a question, in brief..: that K (5mm double block): it is a single one in the middle of the last crosstree of the mizen-lowermast or it is a pair of blocks arising from each tressletree?
I was looking all the evening your posts and pics with no clear result.
Thanks for sharing.
Stergios
HM Schooner Ballahoo by egkb - FINISHED - Caldercraft - 1:64 Scale - First Proper Wood Build
We're waiting to see your pics, Eamonn !
