Posts posted by drtrap
- Mirabell61, egkb and Aussie048
3
- Aussie048 and Mirabell61
2
Jason thanks for the pics which hopefully are back in you build log.
The point is that I can't see any black paper in the kit...
Hi my friends
all those small strips of black paper of 2mm.... to simulate the metal bands etc on the masts.
It is about a special type (propably self-adhesive) paper?
How did you cut it and apply it so perfectly around the masts circumference?
I was thinking to apply rings of 2 turns of 0,75 line instead, I don't know whta's your opinion....Thanks
- egkb, Aussie048 and Beef Wellington
3
- egkb, Beef Wellington and Aussie048
3
- egkb, Beef Wellington, Jobbie and 2 others
5
- egkb, Aussie048, Beef Wellington and 1 other
4
- Beef Wellington, egkb, mtaylor and 2 others
5
- WackoWolf, egkb, Mirabell61 and 3 others
6
- Dimitris71, WackoWolf, mtaylor and 3 others
6
Next stop: started to learn how to cut the various masts sections (and especially how to make square a round section...
Very nice work Stergios keep up the good work.
I am looking forward to seeing your next build, I wonder what it will be
Vasileios
Thank you Vasileios. To see my next build (even I'm not sure what it will be, but you know my tendency..) I have to accelarate myshelf to finish my second beauty (Snake)
- Dimitris71 and Aussie048
2
- jim_smits, Aussie048, Dimitris71 and 4 others
7
Tried to draw both methods with served (A) and unserved (B ). Served is a little more complex because you need the exact measurement and you need to hide the 'join' where the line is 'spliced' with the seizing to secure the deadeye. Although I haven't used the method outlined for the non-served line for deadeyes, I have used it elsewhere. In both cases the seizing needs to be done on the bowsprit because the seizing essentially tightens everything and keeps it secure. Method is the same for deadeyes and hearts.
The other I used method which I outlined earlier in the log was to make the deadeyes with eyes at each end, and then lash these together. Although more accurate, its a real pain to do and I abandoned it after one as the results were not visible.
Hope this is readable and makes sense.
Jason
your excellent drawing was absolutely helpfull, for all of us.
Many thanks.
Cheers
Stergios
HMS Snake by drtrap - Caldercraft
Posted · Edited by Stergios
There is a difference between the plans and the anterior "opening" of the lower mast top but I hope that this is a minor cause of concern...
Thanks.
