Posts posted by drtrap
Trying to find the places for the 14 deck cleats.
I've located the 6 of them at the rear platform deck
Seeing as I did my Snake the other way round, you could progress onto the deck furniture?
My gratings and the hatches were in place before I did the carronades and I would definately do it the other way round next time...!
Also, try and map out where the deck eyelets need to be placed, they are shown on the belaying plan. There are far easier to install now rather than when the deck is full.
Thanks Jim for the help.
I'd like to ask you, it is important to fix the deck eylets as tightly as I can to withstand the tension of the line/rigging of the masts?
Thank you again
Hi to everyone.
Almost finished with the carronades rigging...
In your experience my friends what's next session or step you advise me to continue with?
Every time I see the manual I feel more unsecure than ever!
Cheers
Stergios
- egkb, Dimitris71, Aussie048 and 1 other
4
When I'm lloking the aftermarket casting fittings, I believe that the quality of the material is the same like those standard of the kit...
I feel so tired every time I need to order aftermarket fittings especially to cover/substitute cheap and deficient materials..
The casting-material of the bulwark cleats is so deficient that the central pin is broken following a minor stress......
So I'm about to place my aftermarket order for another time.....
Wishing to do it for the last time, I'd like to ask you my snake-friends do you suggest (from your advanced experience) to order any additional casting fitting should I need during the next stages (masts, etc...)
Thanks mates!
Stergios
Hi Jason
I was ready to post a relative question on this issue.
I remember quite well your concern going back to last October...
Thanks again anyway!!
All the 18 carronades in place...
I've placed the additional couple of the cannons temporarily in front of the most anterior openings just to have a general idea..
My plan is to continue (and finish) with the tackling of the carronades & cannons and leave the deck fittings fixing (ladders, capstan, companionway, pumps) for later ...
I'm glad in seeing the whole restoration Jim.
Keep in touch!
- Beef Wellington, egkb, Dubz and 1 other
4
I'm about to sand and fix the aft ladders in place...
Jason, Jim have you painted/varnished the wallnut of such deck fittings or have you left them uncovered as natural walnut?Thanks.
Stergios
I wouldn't normally use it for bonding a non-wooden piece to wood. If you're trying to bond something like metal or plastic then I'd use CA glue.
Thanks Patrick
I'm asking to bond wood to wood items trying to avoid those undesired glossy spots from the cyano micro-leakage on the deck...
Cheers
Hi mates, a basic question about pva glue: are you sure that is contraindicated for glueing fittings on varnished surfaces (deck, etc)?
Thank you. -
Ecelent lokking work. Keep the photos
Thanks for the comment Aussie048 !
You seem to have it thought out Stergios, its definitely a tedious process but feels so good when complete. The technique that worked best for me was to make up the tackles off the ship first (loosely), attach and then gradually tighten. You are right, there is a lot of wasteage of the thread between attaching the hooks and the actual tackle, but its better to be safe than sorry as its not a big expense.
Thank you Jason, for the moment I'm studying your technique...
I start to prepare the tackling.
It;s my first time but it seems a painfull story, I'm not sure.... should I assemble it on the deck or not ?....
But above all, the real head-ache is doing the "frapping"...
I think that I need at least a length of 15 cm for the running rigging and a knot as a final starter to turn the edge of the line 4-5 times around the tackling...
- mort stoll, Beef Wellington, egkb and 1 other
4
HMS Snake by drtrap - Caldercraft
Yes Jim, for the mo I'm seeing on the plans only the most aft three pairs of them, on the rear platform...
