fmodajr
Everything posted by fmodajr
  1. Hi Michael, I think you have a great idea for your copper plating method! If you have trouble, you might try a method I have use in the past. Buy commercially available copper strip rolls to the width you need Then I use this pizza roller gadget I have that will put indents the way you want them. I roll the gadget along each side of the copper strip, using a steel ruler as a guide for the roller. Then I cut the strip to the lengths I need, using the cutting block shown in the 1st photo. Also, to ensure the plates stay on the hull, I spread slow drying glue on a section of hull and then add the strips. Anyway, just another idea! Frank
  2. Hi Michael, Glad you didn't give up and pull that Viking ship out from under the table! You're doing a great job on this! Welcome back! Frank
  3. Hello, I have been able to make more progress on my build! Here, I added the two stern pieces that rise up at an angle towards the stern. The first row of planking will sit right underneath these pieces. Starting the deck planking now. I decided to discard the kit wood and I will be using Eastern White Pine that I have in my wood stash. I like this wood. It is fairly light colored and later when I'm ready, it will take an oak stain nicely, to darken the deck. I rough cut the pine about 3" wide (the width that my thickness sander will take). Using my thickness sander, I grind the thickness down to the width of the planks that I want to use (I will be using 4 mm and 5 mm widths) Then I glue some black paper on one side to simulate the caulking. Now I rough cut the wood into strips, using my table saw, then run it thru the thickness sander to obtain my final thickness of about 0.6 MM I experimented on various red paints, including the nice "Gory Red" that Mark is using in his log, but I finally decided on a red paint called "Imperial Red". The photos of the red might not be a perfect representation, due to the lighting in my workroom! Now I am starting on the deck planking. The Corel plans show all the planking to be 4 mm wide and all the planking is laid out straight from bow to stern. I decided to have some fun and I will use the planking method from Gerard's book on the "Fleur di Lis". His plans call for 2 rows of planking, along the outer edges of the deck to be curved, following the deck curve. His plans also seem to show that these 2 rows of planking are wider than the straight pieces. So I made the 2 rows 5 mm wide. Now I will begin to lay in the straight pieces, using the smaller width (4 mm) pieces. Thanks for visiting! Frank
  4. Hi Michael, Good to hear from you! I hope you are well! I will be posting more photos very soon. Thanks, Frank
  5. Hi Mark, Thanks for the chain information! I think I will pick some this week. Good to have around! Frank
  6. Hi Mark, Nice improvisation for the strops, chainplates, and gun port lids. Looks like you are taking the kit omissions in stride. LOL! At Michaels, do they have a variety of different size chain? I'll have to take a ride down to my local store to have a look. Frank
  7. Hi, Small update: I took the time to make sure that the slots on both sides of the false deck were the same distance from the rear bulkhead frame. They were pretty close. After I finish the deck planking, I will have to re-slot thru the planking and can correct any errors. There are two main ribs running most of the length of the deck that had to be installed before the deck planking. I made up some temporary filler blocks, the correct width, to make sure the pieces stayed parallel to each other and glued the pieces. I also installed the upper false deck near the stern. I primed the two long ribs, in preparation for the final coat of red. Currently, I'm experimenting with different shades of red, and I have to finalize which I will use. (a lot of the deck pieces will be painted red, so I hope to get it right!) I want to get these two ribs painted before starting the deck planking.I have also just received Gerard Delacroix's fabulous monograph on the construction of a similar ship called "La Fleur de Lis". I hope to use his plans and illustrations as a guide and a "Cross Reference" to making sure that the Corel kit is somewhat accurate. I've already spotted areas of my build that I can make more detailed than what the Corel plans offer. We'll see how it goes as I progress. Thanks, Frank
  8. Hello! Before planking the hull, I had some more work to do. To make the first layer of planking a little easier, I have been taking the time to add Some filler blocks, made of basswood, in-between the bulkhead frames. The planking of the stern and bow sections will be more challenging. These filler blocks should help. Filler blocks in the mid section For now, I have omitted the filler blocks on 3 sections, so that I can still use my holding fixture. I remounted the model onto the fixture and made sure that the deck was level and square. I have to do some deck work first, including the planking of the top deck, before starting the planking of the hull. Thanks, Frank
  9. Thanks Mark, I still have time to decide. I think I will get the 1st planking in, then add the keels, and then do the final planking! Frank
  10. Hi Mark, Thanks for the red color information. My Reale de France will have a substantial amount of red in the build, and I want to try a few samples of different shades to see which one would work best. I like the look of your red, if, as you say, the photo lighting is correct. Thanks again, Frank
  11. Hi Mark, Yes, it is one long hull. That is also why I took the time to make the steel fixture. Everything seems to be straight, which will be critical later in the build. You bring up some good points about the "plank first" method. It is a double planked hull. The 2nd plank layer is much thinner than the first. So, maybe the compromise is to plank the first layer (not worrying about a perfect fit), then install the keels, then add the 2nd layer. Because the 2nd layer is thin wood, it should be easier to get it to fit up to the keel without gaps. Thanks for the warning and advise. What do you think about my compromise? Frank
  12. Mark, Superb paint job! May I ask the brand and name (shade) of the red you used? Thanks, Frank
  13. Hi, With all this heat up here in the northeast, I've spent more time on my full size boat, fishing and cruising, than I have working on the model!! I was able to get the false deck pinned and glued to the frame. As shown in previous photos, the Corel kit is designed with the keel structure made of 3 piece widths. The middle keel structure is where the actual keel, stem, and bow section will be attached to. Corel suggests 2 methods of attaching the keel. The first method is to do it now (attach the keel, stem etc) and then plank up to the keel itself. The second method, which I decided to proceed with, is to plank into the space where the keel, stem, etc would go and then file and insert the keel. This photo shows the slot where the stem will be inserted to the middle frame. I tapered the two outer frames in order to lay the planking correctly This photo shows where the stern stem piece will be inserted Here, is a photo of the bow section. I tapered the two outer frames and when I plank, I will overlap the middle slot, then file the planking back and insert the bow stem later. I finished tapering the two outer stem frames throughout the entire length of the model. Hopefully this all makes sense!! I will spend the next couple of weeks adding scrap basswood sections in between the bulkhead frames to make the planking easier when I get to that point in the process. Thanks, Frank
  14. Nice job! With the in-haul tackles in place, i’ve Always wondered how a sailor or gun crew got around all that tackle without tripping over themselves! Frank
  15. Hello, The instruction sheet on the Reale recommended that I dry fit a few of the pieces, before gluing the false deck. I'm glad I did. Most of the pieces around the false deck needed some tweaking! Checking the fit of the pieces around the deck area, which is held on by pins. (Not glued yet) I turned my attention to the last bulkhead near the stern. This piece had a couple of compound angles and curves to it. The hull planks will have to wrap around the half rounds and blend into the stern stem. Glued onto the stern My next step will be to glue the false deck onto the frame. Thanks, Frank
  16. Hello, So I ran into my first snag this week! I went to pull out all the bulkheads from the kit, in order to start fitting them in the stem of the ship, and I couldn't find them anywhere! I am missing parts 10 thru 22, but seem to have parts 23 and 24. Either they were omitted from the kit or I misplaced them. I did bring the kit over an elderly friend's house, a few months ago, and I might have left them there. (He has since passed away). No big deal anyway. I copied the plans and glued the patterns to a board with the correct thickness. I then cut, shaped and sanded them. Putting the model back on the fixture, I was able to check the heights on both sides and make adjustments to the bulkheads before glueing. Then I glued them all in using squares to keep them aligned. Thanks, Frank
  17. Hi Michael, Thanks for all the help!! I ordered the book today. (6 to 8 weeks to get it here in the States!) hopefully it will arrive sooner. My brother in law is French, so hopefully i'll get him to translate some of the book! Thanks again, Frank
  18. Hi Mark, Thanks for stopping by! I did not know Dusek also made La Real. I think my wife would have preferred the smaller scale. She keeps asking me where are we going to put "that thing" when your finished?! I keep telling her we'll worry about that later!! The Corel version will be over 40 inches long when done. Yikes!! Frank
  19. Hi Michael, LOL! Actually Michael, I am fortunate. While all my equipment is only designed for wood working, my friend has a very nice metal working shop in his basement. So I designed the fixture and he helped me make it at his place! He also makes and sells some nice thickness sanders and disk sanders. His company is called "Ship Ahoy Models". Thanks, Frank
  20. Thanks for the photo Phil! Looks like a nice model! I'm having a hard time trying to get more meaningful information on the actual ship. I want to make sure the Corel kit is accurate. I understand that a person named Gerard Delacroix has published some information on a similar ship called "La Fleur De Lis", but I am having a trouble finding this information. Thanks, Frank
  21. Hello, The Corel kit designed the internal keel, or spine, of the ship using 6 pieces. 2 pieces for the middle keel, 2 pieces on the left side and 2 on the right. In this photo, you can see the pieces from the kit. The total length of each 2 piece section is about 36 inches long. The Corel instruction sheet says that the triple keel design was produced this way to keep the keel straight throughout it's entire length. I was still worried that if I didn't get these pieces perfectly straight, It would show up later in the build. So with the help of a friend, I built a steel fixture to keep the spine perfectly straight throughout it's 36 inch length (which I felt was critical to the build) and I added vertical supports to keep the ribs perpendicular. Maybe overkill, but with the ship model being so long, I figured any warpage would be easy to spot. Photo with 6 piece keel on Fixture Keels all glued together After the glued pieces dried, I sanded the bottom side flat and inserted filler wood where necessary. Then with the keel back in the fixture, I sanded the curved keel (and filled with filler wood where necessary) and I filed the slots even to accept the bulkheads. Now to start on the cross sections! Frank
  22. Hi Phil, Do you have a log of your Heller Reale? thanks, Frank
  23. Hello, After finishing my Corel Vasa build in January 2017. I took the year off to help my wife with projects for the wedding of our daughter. (Of course, I did take the time to build a model of a Concord Stagecoach on the side!!) Back in January of this year, I purchased a Corel kit of the Real De France from the very nice people at Ages of Sail, with the intention of starting it right away. However, due to frozen pipes at my elderly parents home, I have spent the last few months with contractors, getting their house put back together. So now I am finally to get back into my hobby room! Here are some photos from the opening of the kit A couple of things I noticed about the kit. On the box cover, it says that the scale is 1:24, but in the instruction notes, it references the correct scale 1:60. The material in the kit seems to be of good quality. There is some plywood pieces included, so I might change these pieces out with some other wood for areas of the model that won't be painted. There are many pages of nicely detailed plans, which should make the build easier. The translations into English of the instruction booklet is not easy for me to follow, but re-reading it a few times brings things into focus! I don't know much about the Real De France, so I can't comment on how accurate the Corel plans are. If anybody can steer me to some other references or publications about the real ship, that would be greatly appreciated. Thanks, Frank
  24. Hi Michael, Sorry to hear about your shoulder and your wife. Glad all seems to be better now. Relax and hopefully you'll be back at it soon! Frank
