Javlin
NRG Member-
Everything posted by Javlin
My MM Ocean Grey was to far gone to bring back with the leveling thinner and OG has a tint of blue I went US Intermediate blue I'm thinking a little to blue but the flash also is overstating the blue some what. I went back out to the shop to clean the AB definitely not that blue will take final pics outdoors natural light next week.
I have not built an Eduard in a while if ever and have to say this is a saaweeeet Kit! The fit is just about perfect filler was a minimum on one wing root only.The kit supplied the PE to build up the pit though being a Spit not alot to see but I did use for the first time the SG with the light worked great for the bezels.I have been back with my MM enamels of late having found that MR.Color Leveling thinner for lacquers works Frigg'in excellente allowing me to thin to a 60/70 ratio of thinner and get a good application and is reviving some of the ole paints.The camo was all applied @17psi with the draw back on the trigger set to very light spray.The camo was drawn out with a pencil one at a time hitting the pencil line 2X and filling in the area it took me about 1 1/2 to 2 hrs to paint the whole plane,the airbrush never stops moving in various patterns.I started the build last Monday after shelving it for sometime for lack of interest but I think it's time to clean up those off the SOD.
Thanks Phil I enjoyed this build it was a challenge I have seen others on other forums drop the build and one on YT as much that Special Hobby replied to the builder.The kit is definitely a builder making a Nice representation of the the A/C if I say so myself.I am thinking of ordering the SP WhirlWind in 1/32 another kit were people do not like their instructions once you to the WW/LG area?This is my 2nd SP Kit and yes both required attention in that part of the A/C but a challenge is fun sometimes over the shake-n-bake kits.I think the next build will be Eduard's Mk XVI Spitfire started some time ago I may actually clear out a few ole builds.I need to start on another floor cabinet like the other one things are getting full!!
Alright time to move on fellas to the next project.The inner door actuators kept braking off so made them out of .015" guitar string with a brass head then drilled the body of the actuator and just glued to the door only(bad pic).I used Alcad smoke first time ever using it easy just went a little heavy on the R/side of the plane.The bombs got a wash of Tamiya brown right on MrColor and then Tamiya grey wash both done with a q-tip did not touch the paint.Thanks for looking and the likes.
This is going slower than expected but I bit the bullet and did a weathering just sloshed the Tamy Brown and let it sit overnight.I think it will pass some areas on the side of the fuse R/side the future was thin and ate through in the sense the more I wiped the stickier it got and went "gotta fix that".I used a sponge and tweezers litely dipped in the respective color and all worked out just did not want brush marks.I usually go semi-gloss but seeing she's been a workhorse since D-day went dead flat.I am about to gloss black the LG and do the silver.I still at best guess another week of work on this one little stuff bombs and canopy and weathering the WW always more.She's not the best as far as weathering but I seldom attempt this part out of fear I dove.
Vincent Black Shadow by CDW - Revell - 1:12 Scale
Javlin replied to CDW's topic in Non-ship/categorised builds
That's me Craig once it hits the shelf beyond these pages no one will likely see it. -
I see and know there is truth in what is being mentioned but knowing the Brits with their precision about their camo in A/B scheme somewhere along the line those stripes would of gotten better by both the Army Air Corps and the British,willy nelly probably went out the window.The stencils are complete,glass dipped and prop built/painted.The actual L/G placement seems to be an area of concern for a few who ditched the kit that will not happen here!
The stripes have been laid it seems I am progressing more and more to a splotchy pattern with my paint.The white was laid down uneven 2.8" using 18" stripes which was roughly 9/16" in width the last white stripe in the middle had to eyeballed to be even usually 1/32" was missing.I painted the black first with falt black splotchy again and then came back with a Nato black to fill in here and there but never completely.I had the minimum of clean-up in the end.
