Javlin
Everything posted by Javlin
  1. Not a fast paced site by no means Craig but a good set of fellas some quite talented like Mike and Rob for two.
  2. https://forum.largescalemodeller.com/?_fromLogin=1
  3. On our sister site Peter was having issues with the insertion and I guess the alignment of certain aspects of the LG's themselves I think anything the Eduard's 1/48 I bought may help?
  4. Info for those that might stray down the path of a Tempest from Mr.Edgar Brooks one of those guys sadly missed and had the answers for many.Color changes coming. Before its restoration, I saw the RAF Museum's Tempest, when it was at Cardington, and the wells were green, legs and door interiors were silver. Edgar
  5. I think the blue will be a Nice change Craig most are done red.
  6. I have gotten past what has made a few put this kit on the SOD.The WW's in my instructions had you build them outside the wing and insert them afterwards screwy plans angles involved.The next issue I heard of was once the copit was inserted failure of the fuse to slip into the wing?I did encounter that but took me 30 minutes of grinding/sanding to overcome the obstacle.One has to grinding/sand the the very inner WWs that encounter the copit tubing and sand the outside of the tub some.I have my seatbelts coming from Eduard tomorrow with some others for Japanese and MkIX with a book.I will finish the 110 soon enough just find the challenges of this limited run kit interesting.
  7. Tension and OLD glue will take time to much.
  8. Chalk it up to damage some time ago new panel/paint.
  9. looking very good Craig I take it the wing fit has already been explored?
  10. Craig you will like it when done colorful scheme and when rigged looks the part I still appreciate mine in the cabinet.
  11. I got to stop on this one waiting on belts from SB usually keep them around but only have the Sutton in the stash as far as Brit stuff goes.I am not very good at dirtying stuff up it's what you get.Back to the 110. After seeing the photos will tidy it up some here and there.
  12. Reached out a little more EG to a friend in the UK since Mr. Brooks passed a few years ago but the friend passed photos of a wartime crate for me.I am going to add that the handle to the joystick looks brown maybe with the bottom being black that holds it to the stick.The reflector gunsight while SH/Revell says black the mounts are either IGG/Silver a change there?This is a Typhoon Hi Kevin, Wartime Tempest and Typhoon were normally matt black down to the elbow-level tubular frame, and Cockpit Grey Green below this. All of the tubular framework was most often dull silver, although in the photos below ( a Typhoon cockpit) they appear to be the Grey Green. The heel boards could be silver or matt black, probably scuffed. The back and head armour was matt black, as was the area under the canopy, with the seat normally in dull silver. Hope this helps,
  13. Thanks EG I think I will stay green seems they came both ways according to some readings and the opinion of Edgar Brooks.....A good rule of thumb with Typhoons and Tempests is that everything below the elbow was interior green, except for the tubing underneath the instrument panel, and everything above was black, including the inside of the windscreen. Don't forget that the Tempest didn't have a visible gunsight, the graticule was projected on the armourer glass. Then another chimed in were these after war crates? ....Hi Edgar and fellow Tempest enthusiasts, A few years ago, maybe around 1995, I was at the RAF Museum, and was given permission to extensively photograph both the Typhoon and Tempest V, including access to the cockpits via stepladder. Both cockpits were obviously unrestored. Both cockpits were completely black. Tubular framework, floorboards, seat, consoles, interior of fuselage skin panels.... everything. The gearbay on this Tempest is IGG as Edgar says, and the gearbay on the Typhoon is Sky. I suspect the original color of the Typhoon wheelwell was IGG. The Typhoon was incomplete and had to have a new radiator and spinner (weird looking though it is, and badly in need of a more accurate replacement) made in order to display it. The airplane was externally repainted at the time is was readied for display. The gearbay was most probably overpainted at this time as all hoses, fittings, etc. are all overpainted sky. EG what I did notice in the CM pics is that even the backing to the seat was green
  14. I have been trying to get as much done on this while waiting two weeks to get my order from SB's the USPS temporarily lost my order in Kansas I am just building sub-assemblies as I feel fit bouncing around and Limited Run kits seem to require that the instructions are not the best.I eliminated what might of been a couple errors for me by looking ahead and pulling that procedure into the now.I used a semi-gloss black on the sidewalls and all panels/boxes will be a NATO Black and will NBlack the console on the tubing with the airbrush and tidy up the green with a brush.I need to track down some good color pics of the copit for better clarity.Dan you made this happen
  15. Thanks Phil I think she goes to the Northshore Model Contest in June.
  16. I am opting out on this one and calling it finished fellas a dead line for the GB is end of the month.The flag was the last thing to add and I was going to do the individual glass but a PIA seems I read could be up/down ,,down it is.
  17. Thanks Mike some say now it's the fuse to wing joint after the innards are added looks 100% OK to me W/O the innards.So I have started on the innards alot of this maybe work out having good info.
  18. I started on this because no stuff came in for me today from the post man and plus been watching videos on YT of the Tempest.I watched the last night the dedication of one being restored in the UK with a sabre engine that has never been fired up yet new in the crate 80years now!!So I mentioned on another thread that slips me at the moment should/when I start this build the WW's would be the first place I venture to.I have seen builds stall when they get here even a YT vid.Well....I decided the instructions suck in this area and since they give you a Nice relief in the lower wing I started with the front piece and worked clockwise and it went together like a champ.The upper wings have already been checked for fit and it slips in like a dream.I will finish the wing and move onto the fuselage in the next couple of weeks.
  19. The finish line is not that far off no mail today so no yellow The canopy was a bit of a PIA probably more me than the manufacture I go outside the box/instructions and gets me in trouble but I resolved that issue.I have been touching up the nose decal with black tonight hence the yellow.I like it when you decorate the props just that little more touch.One pic of the port side of the fuse shows a decal that moved but also those ribs numbers not 9 like the 109 but 18.I tried making a RLM04 with what you gave Andy hence since I do not have the all the colors got to daRK.
  20. Looks good Dan I have this kit coming tomorrow.
