alde
Everything posted by alde
  1. This is the lower planking on the starboard bow. You can see some gaps and dips. Here is the port bow. A little better but not perfect. Here is the stern and I think this is the problem. It looks like I put the garboard plank too far forward and the rest followed. The upper planks are laying in just fine. I plan to use some slivers of wood and wood putty and paint the lower hull so will just call it a lesson learned and move forward. At a couple of planks a night after work it's slow going but that's ok. I am having a blast with this kit. Al D.
  2. Well Steve, it's coming along but it's far from perfect. I deformed the garboard strake on one side with too much pressure when clamping it to the form and keel. The other side is a bit better. It's been a great learning experience so far and it will carry over to future projects. I am painting the outside of my hull so it should all be fine with a little filler. You probably know this already but the mistake I think I made was not fitting the plank ends into the rabbit better. I should have trimmed them to follow the curve more closely. They would have layed down better. I will take some close up pictures later and post them on my log. Getting them to bend to the twist and the curve at the same time really takes some persuasion even after a 6 hour soak with water and amonia.
  3. A wise man once said "You can never have too many clamps". The planking is going OK. It's far from perfect but since I do plan to paint the outside of the hull it should be fine. There will be a couple of small gaps to fill but the planks are going into the rabbit really well and gluing up just fine. It's taking shape and looking more like a boat. .
  4. It looks great. It will all work out in the end. This is sure a great kit and a fun build.
  5. Here is the finished form before bending the frames. I decided to use binder clips to hold the keel alignment tabs closed instead of pinning through the keel. It seems to work just fine. I let the cherry frame stock soak in plain water overnight. Here is the form all framed up. There was quite a bit of breakage but like other have pointed out they give you plenty of sticks to work with. You can see my broken pile in front of the form. Now to let it all dry while I re-read the planking section of the instructions. Thanks for looking, Al D.
  6. A tallow/off white underside with the rest of the ship natural would be a nice look. There would still be plenty of that fantasic planking job showing. You can't go wrong either way.
  7. Tom, Thanks for the tip. I will try to keep the glue to a minimum. I am using yellow wood glue. I try to stay away from super glue where I can. It's too hard to recover from mistakes with it. Al D.
  8. Thank you all for the information. I am really looking forward to starting the planking. Right now it doesn't look like much of a boat. At this point the rabbet is cut and the form is built and faired. Bending the frames is next. I plan to put the frams to soak overnight Friday and try bending them to the form the next day. The log will be updated along the way and there will probably be more questions. It's really rewarding to see it come together. This is a great hobby with some great people to help a new guy out. Thanks, Al D.
  9. I have what may be a silly newbie question. I am still working on my building form (will do log update in a couple of days) but I have been re-reading ahead in the instructions. When I get to the planking stage and start gluing planks do I edge glue them to each other or just glue to the frames and keel. I imagine edge gluing would be the way to go as not would make for a weak boat. Thanks, Al D.
  10. I have always wanted to try some rope work. I have a friend who was a mariner by trade and could do some great stuff. He could make a monkeys fist in a couple of minutes and made eye splices look easy. That Bounty Launch is still waiting. It's a great kit.
  11. Steve, your boats look great. BTW, it takes a real man to admit the he knows how to knit.
  12. I can't imagine taking on the task of crewing the launch. I will be thrilled with a clean planking job on mine. It sure is a slow but fun process though. When you build your form give some thought to putting the sheer tabs on after it's all faired in. They really make to hard to do a clean job when in place. Of course it could just be my lack of experience too.
  13. I have the building jig assembled and one side faired in. It was pretty staright forward from the instructions. If I were to do it again I would have waited to install the sheer tabs until the jig was faired. The whole bulkhead needs to be faired so the frames lay against it at the correct angle and the tabs make it more difficult. It would be easy to add them after it's all together and sanded fair. I was really apprehensive about cutting the rabbet but the laser cut lines make it pretty easy. I am happy with the way it's going so far. Al D.
  14. You have turned a great kit into a work of art. The attention to detail and craftsmanship are amazing.
  15. I built this kit as a kid back in the 70's. It turned out pretty decent for what it was. It's long gone now. I had forgotten all about it until seeing this thread. Those were good days.
  16. Mike, That is a nice little kit. Be aware when you start to plank around the turn of the bilge that you will have to taper the planks on both ends. The instructions don't tell you this but it impossible to get the planks to lay against the forms if you don't. Just trim them so they lay against all the forms without stressing the wood. Al D.
  17. Just a bit more progress. These laser cut parts are fantastic. Oh, how do some of you folks keep your work area so clean? I never seem to.
