Everything posted by alde
Here is the finished form before bending the frames. I decided to use binder clips to hold the keel alignment tabs closed instead of pinning through the keel. It seems to work just fine. I let the cherry frame stock soak in plain water overnight. Here is the form all framed up. There was quite a bit of breakage but like other have pointed out they give you plenty of sticks to work with. You can see my broken pile in front of the form. Now to let it all dry while I re-read the planking section of the instructions. Thanks for looking, Al D.
It's great to see a start. You need a holiday after all that progress.
- 625 replies
- bounty launch
- model shipways
CaptainSteve, You have a crowd and we are getting restless.
- 625 replies
- bounty launch
- model shipways
A tallow/off white underside with the rest of the ship natural would be a nice look. There would still be plenty of that fantasic planking job showing. You can't go wrong either way.
- 2,191 replies
- confederacy
- Model Shipways
Thank you all for the information. I am really looking forward to starting the planking. Right now it doesn't look like much of a boat. At this point the rabbet is cut and the form is built and faired. Bending the frames is next. I plan to put the frams to soak overnight Friday and try bending them to the form the next day. The log will be updated along the way and there will probably be more questions. It's really rewarding to see it come together. This is a great hobby with some great people to help a new guy out. Thanks, Al D.
I have what may be a silly newbie question. I am still working on my building form (will do log update in a couple of days) but I have been re-reading ahead in the instructions. When I get to the planking stage and start gluing planks do I edge glue them to each other or just glue to the frames and keel. I imagine edge gluing would be the way to go as not would make for a weak boat. Thanks, Al D.
Come on now, sticks and glue too. We want to see a boat.
- 625 replies
- bounty launch
- model shipways
How do you guys keep your work area so neat and tidy?
- 18 replies
- maine peapod
- midwest products
I can't imagine taking on the task of crewing the launch. I will be thrilled with a clean planking job on mine. It sure is a slow but fun process though. When you build your form give some thought to putting the sheer tabs on after it's all faired in. They really make to hard to do a clean job when in place. Of course it could just be my lack of experience too.
- 625 replies
- bounty launch
- model shipways
I have the building jig assembled and one side faired in. It was pretty staright forward from the instructions. If I were to do it again I would have waited to install the sheer tabs until the jig was faired. The whole bulkhead needs to be faired so the frames lay against it at the correct angle and the tabs make it more difficult. It would be easy to add them after it's all together and sanded fair. I was really apprehensive about cutting the rabbet but the laser cut lines make it pretty easy. I am happy with the way it's going so far. Al D.
Your launch looks fantastic. I am only just starting mine.
- 78 replies
- model shipways
- bounty launch
US Brig Syren by Gahm - Model Shipways
alde replied to Gahm's topic in - Kit build logs for subjects built from 1801 - 1850
You have turned a great kit into a work of art. The attention to detail and craftsmanship are amazing. -
Mike, That is a nice little kit. Be aware when you start to plank around the turn of the bilge that you will have to taper the planks on both ends. The instructions don't tell you this but it impossible to get the planks to lay against the forms if you don't. Just trim them so they lay against all the forms without stressing the wood. Al D.
- 18 replies
- maine peapod
- midwest products
Mine is going to be a slow build so you will probably pass me right on by.
- 625 replies
- bounty launch
- model shipways
When are we going to see some glue action. The suspense is killing me.
- 625 replies
- bounty launch
- model shipways
First, thanks for taking a peek at my first build log. I have decided to put my MS Kate Cory on hold. I originally bought the Kate Cory kit in December of 1992. Since this kit is over 20 years old it doesn't really compare to the modern laser cut kits with great instruction manuals. It also helps that there are so many builders of the modern kits to get help from. I have just gotten started on it but I can see it will be a real pleasure to build. The parts are amazing compared to the crude wooden blocks and pieces for the old kit. I chose the Bounty Launch as a first planked project because of all the wonderful build here on MSW. Please feel free to nudge me in the right direction if I get off track. Only one picture so far. I only removed a few parts from the sheets and started to clean up the char marks on the edges. It is not heavily burned like some pictures I have seen. Looking forward to a fun build, Al D.
I'm in for a front row seat. Looking forward to seeing this take shape.
- 625 replies
- bounty launch
- model shipways
Ken, I see your point about figures. They would have to be perfect to work well. You don't want to spoil your beautiful work with a zombie invasion.
- 110 replies
- armed virginia sloop
- model shipways
