HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 66 donations so far out of 49,000 members - Can we at least get100? C'mon guys!) ×
In the past, I've use rubber bands or what John recommended.
The deck looks like it is made of one piece of wood that is quite thick. Can you force the deck in place with your hand? If you can, the rubber bands or cord should do the job. Otherwise you may need to use larger screw clamps and use the piece below to hold the clamps in place.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
May I suggest to make a template of the deck, then make a thinner version of Birch Plywood and maybe adding deck planking.
Not only it will give the strength needed but also look good.
But then again it's only my 2 cents.
Respectfully
You can go here on my build log and see what I did. nails and rubberbands.
mario
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
If you are going to plank your deck after gluing in place, a good result can be gained by marking the deck where the bulkheads line up under it, predrilling (about a 0.8mm drill bit) through the deck and bulkheads, applying glue then nailing deck in place with pushpins or chart pins. I have found chart pins such as that arrowed below work better than standard push pins because the heads don't break off when nailing. Pins are easily removed when glue is dry.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
If you are going to use the existing piece, wet it thoroughly on top before gluing and adding rubber bands.
Would wetting this piece affect the integrity of the glue that's already holding the planks to the deck? Also, would the rubber bands leave indentations in the wet deck?
Zamboknee,
    Just click on my Steam Launch under my signature and you see what I did. It was basically the situation you have.
Mario
Thank You all...
Mario
My Builds....
Mario, thanks for reminding us.  I just enjoyed your build all over again.
Bob
Current build:  SS_ Mariefred
Zambocknee,
    As for the small multi-colored clamps at Harbor Freight. Alligator clips at Walmart. They are inexpensive. The clamps were 10 dollars for about 25 of them.
   Don't know where you live, but this is all in the USA.
Mario
Thank You all...
Mario
My Builds....
Zambocknee,
Mario
Harbor Freight and Walmart I can do.  thanks Cap'n
Hey Zambocknee,
    The multi-color clamps are on sale fight now at harbor Freight. 6 for 99 cents.
Mario
Thank You all...
Mario
My Builds....
