Hello
Which glue do you use for gluing the mast into the hole in the deck?
Thank you
Michael.
"smooth seas do not make good sailors..."
:pirate41:
MY FIRS BUILD : H.M.S BOUNTY (mamoli)
SECOND BUILD :The concord stagecoach 1:12 youtube link : https://www.youtube.com/watch?v=yJzCs9umWPI
CURRENTLY BUILD : H.M.S VICTORY (Caldercraft) : http://modelshipworld.com/index.php?/topic/15501-hms-victory-by-michael101-caldercraft-scale-172/
If you glue the mast into the mast step, you have only one chance to get it perfectly straight.  For that reason, many builders prefer not to glue the mast into the mast step, instead the mast is held in place by the rigging.
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
I always glue them and it has never been a problem. I carefully check to make sure they are straight and use a jig to hold in place if necessary.I find things are much more secure and stronger that way, and have less chance of uneven rigging tension pulling them out of alignment.
I use 5 minute epoxy to give myself time to get everything aligned properly.
Joe Volz
Current build:
Model Shipways "Benjamin W. Latham"
Completed  builds on MSW:
Caldercraft HMS "Cruizer   Caldercraft HMBV "Granado"   Model Shipways "Prince De Neufchatel"
photo-thumb-206.jpg?_r=1419304172  Don't blame the kitty!  It was the dogs, in the library with the candle sticks
Current Build
 - Glad Tidings -MS
Completed Builds
On the Shelf
I hope you're right  :) :) . This is exactly what I was planning to do with the masts on my current and 1st build. I've never rigged anything before, not having the mast fixed would make things even more complicated.
Richard.
Richard
Current Build: Early 19th Century US Revenue Cutter (Artesania Latina "Dallas" - messed about)
Completed Build: Yakatabune - Japanese - Woody Joe mini
Member: Nautical Research Guild & Midwest Model Shipwrights
Iv'e always used a small amount of PVA wood glue in the mast hole, this gives about 10 minutes or so to make sure the mast is perfectly aligned, then leave it overnight to set properly, never had a problem doing it this way but then that's just me!
Edited by geoff
Thank you friends for all your answers
i did it with "Carpenters glue"
p.s thanks a lot to "dee_dee" your message (If you glue the mast into the mast step, you have only one chance to get it perfectly straight.  For that reason, many builders prefer not to glue the mast into the mast step, instead the mast is held in place by the rigging.)
 made me think and when im thinking only good stuff raising up ;)  ;)  ;)
so.. i took some pics from my process and i hope to get a free time to make a nice guide with pics about how to install the masts perfectly straight !!!!
:pirate41:
:pirate41:
