HOLIDAY DONATION DRIVE - SUPPORT MSW - DO YOUR PART TO KEEP THIS GREAT FORUM GOING! (Only 69 donations so far out of 49,000 members - Can we at least get 100? C'mon guys!) ×
Popeye and Elia,
It's 1/64 plywood alright and a pain in the backside to work with, the only good thing is the edges sand "fast" sometimes too fast.  I still need to work the overall height down just to make sure the top is level and square.
Cheers,
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
You are right Tim.  Scissors are the only way to go on thin plywood.  Now she’s looking good.
Bob
Current build:  SS_ Mariefred
Bob thanks for the kind words!  Hope you have a Merry Christmas!!!!   :)
Tim
Tim
Future Build:
Completed Builds:
Member:
Looking good Tim.  I have worked with this stuff before and it can be a bearcat at time.  Not user friendly.
David B
Dave,
I agree, fortunately BlueJacket supplies plenty with the kit!  Ive been pretty good at messing up a few pieces thus far!   :huh:
Hope you have a wonderful Christmas!
Cheers,
Tim                :cheers:
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Merry Christmas to all....
My next step was to cut and install the plywood shelf which runs along top of the instrument panel.  This piece is also 1/64" plywood.  The shelf needs to extend over the companionway and is attached to the starboard spray shield.
Cheers,
Tim
post-260-0-48716200-1388018775_thumb.jpg  post-260-0-41791200-1388018776_thumb.jpg
Edited by Timothy Wood
Tim
Future Build:
Completed Builds:
Member:
Nice work. I am surprised that you have not split the wood into a hundred pieces.
David B
Edited by dgbot
Dave B,
 I have!   :o  There times when everything goes smooth, as with the shelf, too bad I can't say the same for the spray shields!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
My next step is to make the antenna base from 1/8" x 3/16" x 2" strip wood, (easy enough), then cut the antenna base top from 1/64" plywood.  After this is complete it will be glued to the port spray shield.  Final step will be gluing the antenna mount to the base top.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
My next step was to cut the antenna base from a piece of 1/8" x 3/16" x 2" strip wood, then glue the actual antenna base to it's stand.  After cutting the stand and fitting the antenna base I found the base was wider than the stand.  I decided to cut and glue two strips of wood to the inboard and outboard sides of the antenna stand to make them the proper size.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
are you going to round off the edges?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Hi Popeye,
The plans show the antenna base square, I will follow what the plans call for.  I did "slightly bevel" the top outboard edge of the base though.  It's so slight it's not noticeable.
I also drilled out the receiver for the whip antenna!  I'll tell you now it made for some tense moments.  I'll try to  remember to add a photo of the drilled antenna base!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Popeye,
Here are two photos, the first an overall from above and the second a macro shot of the antenna base!
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
must have been hard to drill.......and leave such a thin wall!   very nice!  :).......good photo of those shields.....sooooo thin ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye,
It wasn't easy to say the least!  Now I'm working on the 1" aluminum tube which the "gin tub' is made from.   :)
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
Photos showing on the forward gun tub.  I used my disk sander to work the tub to proper length.  The forward tube should have a small amount of "Forward Rake" to it.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Tim,
Your PT boat is shaping up nicely! I agree with Popeye - drilling that casting and yielding such a thin and consistent thickness wall is no small feat. Sweet. I really like the mixed materials of this build.
Cheers,
Elia
Edited by Elia
Elia
Rose Valley, PA
Arethusa: 1907 Gloucester Knockabout
Your PT Boat is really coming along there Tim. When you drilled the hole for your antenna did you vice that and use a drill press or did you use a pin vice and go slow, it turned out superb.
Happy Modeling,
Marty G.
Tim - have you seen this by any chance-  i was reading this on the Flory site - and thought of you
http://www.pt103.com/
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Ella,
Thanks for the nice compliment.   :)
Tim
Tim
Future Build:
Completed Builds:
Member:
Marty,
I held it with a vice and used a small plastic egg beater type hand drill to bore out the hole.
Tim
Tim
Future Build:
Completed Builds:
Member:
Kevin,
Thanks for the link!  I have seen this link and use it extensively, it has a great amount of information for the model builder and also the history buff...
Thanks for the info!   :)
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
Greetings,
My next step was to attach the backrest to the  forward turret race.  This unit is made from two pieces of photo etch brass, the back rest has to be shaped so it will fit the rearward section of the turret race.  After the shaping and fitting is completed it's then glued to the race with CA glue.
Cheers,
Tim
Tim
Future Build:
Completed Builds:
Member:
  • 5 weeks later...
Greetings,
My next step was to glue the turret race to the aluminum tube, I used a combination of CA and yellow all purpose glue thinned with water.
The next step in the instruction booklet states: "Snip eight ammunition belts from the photo-etched sheet.  Paint the tips of the bullets copper, the raised portions black, and leave the cartridge case natural brass, and set them aside for later installation.
Cheers,
Tim      :cheers:
Tim
Future Build:
Completed Builds:
Member:
John,
Slow but sure!  I managed to get a little time at the bench after shoveling snow.  Virginia Beach was hit pretty hard, most people down here don't know how to handle this kind of weather.  I grew up in Michigan, so needless to say I'm loving it!
Thanks,
Tim
Tim
Future Build:
Completed Builds:
Member:
Great project and great work.  I kind of smiled when you mentioned the forward rake of the turret. To a non-expert like me, I'd probably see the slope and figure your guide on the sander wasn't square!
I've lived in the "South" for a while.  The lack of experience the drivers here have in any form of white stuff is startling.  Today I just closed my offices for non-essentials until the roads had a bit of time to clear.  The risk to these folks when they are forced to be on the road is just "to terrible to contemplate."
PopJack,
I agree,if you can't drive in the white stuff stay off the road.  A majority of the drivers in Hampton Roads can't drive in the rain, let alone anything more challenging.   :o
Best bet!  Stay home and work on a ship model!   :D
Tim
Tim
Future Build:
Completed Builds:
Member:
