Thanks for your encouraging comments Mike, E.J. and Gary. I am enjoying the framing. Maybe because it's not too difficult. I'm sure the stern/transom construction and cant frames will be a bit more challenging. I figure that I will learn what I need to know as the build progresses. What I like best is that I can do most of the work sitting down. Quite a change from the usual woodworking I do and a relief at my age. It's also nice to not be covered in sawdust all the time!
I thought you might like to see my work space. It is heated and insulated so I can work there comfortably all year around. It's really a woodworking shop of about 228 sq. ft. so it is more than roomy enough for modeling. I could make some really big models here, but I wouldn't know what to do with them when they were finished! In case you are wondering, the odd looking machine in the 3rd photo is my shop made 'Chevalet de Marquetry' which is used for cutting out intricate marquetry pieces.
Edited by Mike40
Mike,
an American living in Norway
Current build:  Galley Washington - 1:48 - Scratch POF - NRG plans
Good progress on the ship. I'm glad you took photos of your work space. This will be the last time you will see it clean! :)
Regards, Scott
Completed builds:
Awaiting construction:
Thanks Albert and Scott. It gets really messed up when I'm doing general woodworking, but I have kept the mess from modeling to a minimum so far although I still have the bad habit of taking out tools and not putting them back as soon as I'm finished with them, so they wind up taking over my work bench. Good work habits can be a real blessing. I wish I had some!  :)
Mike,
I think most of us are guilty of the messy work table. I think that is one of the blessings of a build log is that I try to clean up the area for pictures so the more I update, the more I can keep things clean. It isn't fool proof as some of my pictures show but it does help a lot! :P
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Mike I had to follow up on your 'Chevalet de Marquetry' What a neat tool it could also be used for frames. your shop looks great.
Michael
E.J.   Yes, we have to clean up a bit for photos, but I usually just clear up around the photo area or take an angle that doesn't reveal too much. I not sure if I'm lazy or disorganized, or maybe both!
Michael    Thank you. I could use the chevalet to cut frames with, but my scroll saw is just as good for that and motorized to boot. That said, the chevalet can cut some extremely small almost dust particle size pieces very accurately. I could see myself using it for very detailed scroll work on a transom for example or maybe some small details in living quarters furnishings below deck etc. Unfortunately the Washington doesn't have any fancy carving or scroll work. I do think it potentially very useful for cutting small sheet brass ship fittings parts. Brass is used a lot in traditional marquetry produced with the chevalet. The advantage being that vey fine blades can be used for the tiniest of details without overheating due to the much slower hand powered sawing.
Mike,
Mike one of the things that I liked about watching the video of the operation of the tool was the fine control that comes with the ease with which the carriage moved and the simplicity of gripping the part being cut.
What is the finest blades that work well with this tool relative to the fine jeweler's saw blades? I like to use a # 3/0 for thin wood and # 7/0 for thin brass.
Michael
  • 4 months later...
  • 9 months later...
