Hello Dear fellow forum members,
Having finished my Riva Aquarama and waiting for the days with better weather (read: summer) in Finland to take it to her maiden voyage in water, I have now switched my attention to building a model of a classical yet beautiful boat from my homeland, Turkey.
Here are some bullet points about the kit:
  • I am actually glad to notice that this model is not new to this forum. Here is a nice blog from an earlier build, by kutaykara: http://modelshipworld.com/index.php/topic/5571-bosphorus-sandal-by-kutaykara-finished-tershane-model-scale-116-1950-classic-turkish-boat/?hl=bosphorus
  • I don't think that the kit is widely available worldwide. I ordered it from a Turkish model boat website www.maketistan.com. The price is a little bit less than USD.100.
  • I actually built this kit about 10 years ago (see my signature) but this time I wanted to make it better and also have a blog of it.
  • I had met the designer of the kit, Mr. Kudret Altinkeser, who is a pioneer dedicated his life to model boats, in his atelier in Istanbul. He has designed several other great kits from Turkey commercially available.
  • The kit is 1:16 scale, 44,3cm x 11,8cm x 9cm in dimensions.
Throughout the build I will try to give more facts about this nice boat as much as I can.
Now some photos and start of the build, but first of all unboxing:
This is outside the box
Accessories, in their own set plastic bag:
Wooden strips:
Laser cut parts in plywood sheets:
Instruction manual consists of 2 piles of stapled A4 sheets (Credits Kudret Altinkeser): One of them contains step by step instructions and the other one includes photos. Even though the instructions are only in Turkish, I believe the photos give enough guidance for any modeller with a moderate level of experience.
That's all. Build starts with the next post.
Edited by aydingocer
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
BUILD DAY 1 - Preperation
This was a short day. The plywood sheets had been warped quite visibly. I used weights (boxes of DVD and books) to get them flat overnight.
Current :
Completed:
Titanic - Mantua
Build day 2 - Construction of bulkheads and keel
The boat has its own building slip to help work accurately and easily.
Two pieces in the middle are there temporarily to ensure vertical alignment. These pieces will be glued to either ends of the slip later on:
Current :
Completed:
Titanic - Mantua
First work on the keel is to glue walnut strips along its edges in order to cover the laser cut marks.
Instructions tell not to remove the rudder cutout at this moment, therefore no glue should be on that part, in order to make it easy to remove later:
Current :
Completed:
Titanic - Mantua
Next, rabbet recess cuts on front and beck. They should be 1mm deep with 45 degress opening. This is really nice because the lines were already marked and pre-cut:
Current :
Completed:
Titanic - Mantua
One quick observation with the laser cut plywood sheets: Laser cuts do not always go all the way through the other side of the plywood. In such cases you'll have to use your knife to be able to remove them smoothly:
Bulkheads removed and cleaned:
Bulkheads placed on the building slip, as addressed in the instructions. No glues used here:
Keel inserted into bulkheads, fixed using super glue:
Bulkheads tapered where needed:
Some sections of the bulkheads will be removed later, once planking has been complete. These sections are indicated with pre-cut dotted lines on them. Those sections have been covered with masking tape to make it easier to detach from the plank strip. Instructions also say you alternatively use wax on those sections:
Current :
Completed:
Titanic - Mantua
Planking starts.
According to the instructions, the most realistic way of proceeding is to use two strips per row, starting at both ends and meeting in the middle. This is apparently how the boats are build in real. The "middle" will vary at each row between bulkheads 6 and 7. So, if the 2 strips of the first row meet at bulkhead 6, the strips in the row below it will meet in bulkhead 7, the next ones at bulkhead 6 .. and so on.
The first planking has been the trickiest, even though it didn't need any tapering. The thing is that they can be glued only in both ends (since I cannot glue it on the bulkheads and I want to avoid using nails as much as I can). Starting from the 2nd row, it gets easier since now you can glue the strip to the one above it.
This is the end of Build Day 2.
5:30 hours in total so far.
Thanks for watching.
Current :
Completed:
Titanic - Mantua
Time to pull up a chair and getting a front row position. Always fun with a different build. Now I am waiting for that special smell..... of popcorn
Respectfully
Build Day: 3
1:30 hours today, 7 hours in total.
After a break of trips, holidays and Christmas, I continued today with planking.
Glued 3rd row of planking strips in both sides. These are a bit critical ones since they are actually almost the first ones to get the support from the bulkheads. The 2 rows of strips above are mostly glued only to the keel and are barely touching the bulkheads, which will be removed later. That's why these 3rd row planks have also the task to support the two strips above them as well. For that reason, after gluing them I stopped to ensure I wait until they are fully dried and settled.
Current :
Completed:
Titanic - Mantua
Build Day: 4-5
5 hours in two days, 12 hours in total.
Looking at my latest post, it has been a while. It has just been work, some trips and other stuff, so luckily nothing bad to prevent from building.
Anyway, here is the progress.
The strips need to be both tapered in order to sit flush with the strip above it (as usual method) as well as made thinner, in order to sit in the rebate, at the ends:
This way they ft quite nicely in their positions:
Current :
Completed:
Titanic - Mantua
Instructions suggest that you stop after 7-8 lines of plank and continue from bottom (i.e. from the keel upwards). This is the status after 7 lines:
Current :
Completed:
Titanic - Mantua
First planks to be glued on the bottom. They will rest on the keel from the sides with an angle therefore it is essential to chamfer these strips along the edge with an angle:
Following this rule, they sit quite nicely on their positions, after a little bending and warping with the plank bender:
Current :
Completed:
Titanic - Mantua
2 more strips on each side. There is about 4-5 lines of planking left on each side.
This is the status after day 5. Thank you for watching.
Current :
Completed:
Titanic - Mantua
Build Day: 6-7
4 hours in two days, 16 hours in total.
I have managed to finish hull planking in these two days.
Tomorrow I hope to spend some time for rough scraping and first sanding of the planking.
After sanding it will be filling the gaps with wood filler and fine sanding.
Maybe so far there was nothing too special to show, but after the hull has been completed I hope to show you fellow forum members more exciting (or at least interesting) stuff on this beautiful Turkish boat so keep following.;)
Here are some photos of progress. Thanks for watching.
Current :
Completed:
Titanic - Mantua
Build Day: 8
Continuing with filling and sanding of the hull. The entire hull will be painted on the outside therefore you don't need to care too much about the filling material showing.
I used the same white wood filler as in my previous project (i.e. Riva Aquarama. Except in that one I had used it only on first planking)
Waiting for a couple of hours and then sanding:
Current :
Completed:
Titanic - Mantua
Once satisfied with sanding (150 grit followed by 240 grit) it is time to remove the supporting dock:
Current :
Completed:
Titanic - Mantua
Then, it is time rip off the bulkheads from the lines indicated. They come half pre-cut and as I mentioned I had put masking tape on those sections which will be removed, where the plank strips rest on, so that it would be easier to rip off.
This is a bit a rough job where you use violence at some points, but overall the process went well. Sometimes I had to be cautious so that I did not rip all the part at once but instead ripped it piece by piece (see photos)
For example here I break the bulkhead piece by piece until I reach the line:
Quite an amount of rubble:
Current :
Completed:
Titanic - Mantua
Clean up by rasping, filing and sanding:
Current :
Completed:
Titanic - Mantua
Deck sheets. They are aft and stern decks, walls, seat in the middle etc. The sheets come with fake lines to simulate planking and you can leave them like that if you like but I wanted to go for real. I found some leftover 1x5mm strips and I will use them to plank.
Planking starts:
End of build day: 8
3 hours today, 19 hours in total.
Current :
Completed:
Titanic - Mantua
Very interesting build. Great job so far!
Jean-Philippe (JP)
Current build: Syren , HMS Victory Cross Section, Essex
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: Rattlesnake (Scratch-built)
Completed:
Build day: 9
4 hours today, 23 hours in total.
Today I continued planking the front and rear decks plus front deck wall.
Strips used:
Main planking : 1x5mm,
Middle of the lids: 1x4mm
Frames of the lids 2x2mm (inner part), 1x3mm (outer part), the outer part strip is glued on its 1mm edge, hence it is higher than the lid's middle area.
With the one in my previous post, they are altogether 4 pieces.
Current :
Completed:
Titanic - Mantua
Ayding,
Very interesting build, which is coming together nicely.
Respectfully
Thanks Per!
Current :
Completed:
Titanic - Mantua
Build day: 10
I noticed after preparing the decks that the panels had returned back to their warped shape even after planking them. This is really annoying. Check the photos below to see. Especially in the rear deck (left side of the photo below) it forms large gaps in the sides and does not sit on the bulkheads properly. Morevoer, I had already glued the front deck :angry:
Current :
Completed:
Titanic - Mantua
There is no option for me but to rip the decks off and plank straight on the bulkheads. There is no hope trying to reuse the decks. So I found suitable strips (slightly thicker to compensate for the thickness of the plywood deck guide) from my older stock and started planking right on the bulkheads. Note I used walnut planking on the front wall just for a change of taste.
Current :
Completed:
Titanic - Mantua
I reconstructed the front deck cabinet cover by carrying the measurements on a piece of paper:
Current :
Completed:
Titanic - Mantua
Front deck top, wall, cabinet cover and ribs are in place.
It will be complete once I have installed the 1x2mm strips along the edges of the deck and the wall in order to cover the gaps.
End of Build day: 10
3 hours today, 26 hours in total.
Current :
Completed:
Titanic - Mantua
Build day: 11 - Floorboards
I wanted to move a bit ahead and make the floorboards today. I could have continued with installing the "ribs" but I just wasn't up to do extensive strip bending work, mainly because I would have to use hot electric bender in order to avoid dents and bites.
So, first step: Cut off the 1:1 scale drawing from the plan sheet and take a copy of it:
Current :
Completed:
Titanic - Mantua
Step 2: Use template drawings to cut the boards from 10x2mm strips:
Temporarily aligned to check that they are almost symmetric and identical:
Current :
Completed:
Titanic - Mantua
