In Popeye's build of the Gothenburg a member posted pictures of blocks recovered from the wreck (see here) .  These blocks from 1745 have wooden pins.  When were blocks made with metal pins?
Bob
Edited by Cap'n'Bob
Current build:  SS_ Mariefred
Hi Bob,good question.
I think that both types of pin were in use all of the time. Lees quotes wood pins (lignum vitae I would think) for small blocks and Iron or Brass pins for large blocks used in English ships. Marquardt quotes pins being made from Lignum Vitae,Cog-Wood (Laurus chloroxylon),Greenheart and Iron in his book 18th Century Rigs & Rigging which covers other countries as well as Britain. Neither of these books mention anything about dates of change from wood to metal.
Hope this is of help to your question.
Dave :dancetl6:
Edited by davyboy
Are you guys talking of sheaves or really of the axles, i.e. the pins on which the sheaves run ? I have never heard that the axles were made from anything else, but metal. The friction of wood on wood would be rather to high and they would very quickly wear down without constant greasing.
I think there has never been a complete shift over from wood to metal as far as blocks for organic and man-made fibres is concerned. The sheaves of blocks for wire rigging to my knowledge have (almost) always been from cast iron. The wire rope would simply saw into wooden sheaves. Also, wire rope requires relatively large sheaves that would be quite expensive to make from wood.
I would tend to agree with you but it is obvious from the pictures the pins were made of wood.
http://modelshipworld.com/index.php?/topic/889-gothenborg-by-popeye-the-sailor-billings-1100-scale/page-8
Click and scroll down.
Bob
Edited by Cap'n'Bob
I wouldn't doubt the use of lignum vitae, it is an extremely hard wood.
In the late seventies I had a piece of it in my hands and I couldn't find a tool able to score it.
As for friction I can tell you it was part of a propshaft bearing on a 10 000Hp bulk carrier, operating at 122RPM,
so you can figure out the resistance to wear.
In that capacity it was water cooled, but on the other hand it would get more friction in one minute than a block in one
hour, so I believe there would have been no problem
All the best
Zeh
  • 8 years later...
Never ... well, I think brass or perhaps rather bronze or cast-iron came into use when wire runners came into use, for which even Lignum vitae was too soft. I believe expensive brass sheaves and ball-bearings came into use also on later 19th century yachts.
In addition to being hard as nails, lignum vitae contains oil that serves as a natural lubricant.  Oil content is a common property of tropical hardwoods.  It's what makes gluing those types of wood problematic unless they are wiped with acetone just prior to applying the glue.
2 hours ago, allanyed said:
an old block from the early 20th century that is internally stropped
Not trying to hijack the thread but I was just wondering when internally stropped blocks came into use.
My advice and comments are always worth what you paid for them.
Wish we were a little closer to discuss face to face.  We're over in Wailea this week,  but checking in on MSW for the important stuff 😀   As to internally stropped blocks I need to look at my books when we get back home but I know they were common by the late 19th century so probably quite some time earlier.  I am sure there are members here with some contemporary based information.  I hope so, as I am curious about this as well!!
Allan
Henry, you bring up a great point, LV had a variety of uses.  The bearings for the propellor shaft where it went through the hull on all the ships I sailed in the 60's had LV sleave bearings.   I am sure that has changed, but it served us well for many decades well into the 20th century, perhaps longer.
Allan
