What is the trick for inserting dead eyes into chainplates? I've got two done and have broken two deadeyes in half during the process. This is worse than inserting an interior packing into a bearing seat.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
Spread the chainplate a bit and then insert.  Crimp back into position.  If they're the "cast" chainplates that a different can of worms.
That is what I have done in the past but these break. They seem to be soldered in the middle. Beyond Frustrating. So I just rigged them  with line and put a loop at the bottom for the link. Can't tell the difference when complete but what a PITA?
Regards,
Jim Rogers
Are they brass? If so, you can anneal them to make them more pliable. Then you can "spring" them around the deadeye and squeeze them gently to hold the deadeye snugly.
Russ
I tried heat nada, got really frustrated put the deadeye on a board put the chain plate on top and just hit the damn thing with a hammer. Low and behold  it went on. Thought it was a fluke so I did it again with the same result. As  Torpedoman we where always told to get a bigger hammer and it is still true.
Regards,
Jim Rogers
