Dave,
I received this kit for my birthday several years ago and have struggled with it ever since. Your solution is both elegant and simple and has succeeded in turning a sow's ear into a silk purse.  Your imagination and creativity are very much appreciated.
I had a nice 3/4" thick walnut cutoff in the shop.  I cut it to an elongated octagon shape and routed a profile on the edges.  I wiped on several coats of wiping poly.  To mount the model a took a two pieces of brass rod, 1/16" diameter and epoxied them into two holes I drilled into the keel from the bottom.  I the took 2 pieces of 1/16" I.D. brass tubing and mounted them in holes I drilled in the wood base.  The brass rod fits inside the tubing and supports the model.
I added the two channels and belaying pin racks and started putting the final coats of poly on.
Remaining jobs:
-finish the poly.
-mount the deadeyes and chain plates.
-install the main mast bitts and glue the mast in place.
-install the brass stanchions for the guard rails on the ladder hatch.
-glue the carronades in place.
-mount the hammock netting stanchions.
-mount the gun port lids.
Edited by DocBlake
Thanks, Bob, and everyone for the "likes".
Almost done!  I'm in the home stretch now.  I finished the poly, installed the main mast bitts and glued the mast in place,
 installed the brass stanchions for the guard rails on the ladder hatch and rigged the safety lines, and glued the carronades in place.
All that's left:
-Mount the deadeyes and chain plates and finish the channels
Finally finished!!!
I added the last details to the cross section.  The hammock netting supports were mounted and I rigged them with some black line.  This was a style decision, not a historical one.  I chose not to add the netting itself.  The deadeyes and chainplates were installed next, with a small strip of boxwood glued to the outboard end of the channels to keep them in place.  Last, I added the 4 gun port lids.  Again, I chose not to rig them.
This was really a fun build, and I ended up with a model that was completely different from what the kit intended.  To me, that is the real fun.  Thanks for watching, everyone!
Edited by DocBlake
Simply beautiful Dave!! Your taste and skill in "painting" with wood is truly artistic. Congratulations!!
Congratulations on completing an extremely well done model!
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Congrats on a fine model.  I was impressed with the variety of colors.
Excellent work.
Ken
Washington 1776 Galley
Completed Builds:
Pilot Boat Mary  (from Completed Gallery) (from MSW Build)
Dude, you rock!  The perfect ending to an outstanding effort. With a model presentation like this, I do not see how the wife can complain as it is easily dusted :).  Can hardly wait for the next revamp of a marginal offering - how about the Essex half hull from Amati?
cheers,
