Hello all. You might have noticed my absence but I’m still here…
Well, it’s been a long time since a previous presentation work of mine but I’m not notorious for accurate build logs anyway. So I have come to prove myself again …:)
I started the model one year before accepting the challenge to build a model with open hull.
I didn't work on it regularly, so that's why the lack of many photos, not that I have in my mind to take photos in other case…
I chose to represent a vessel from my place of origin, the Island of Mytilene (Lesbos).
It was a small double ended vessel (Tserniki type) which was used for coastal trading.
It was usually rigged with a half lateen sail or a sacoleva sail (sprit sail).
I observed many photos of that vessel from the archives of 3w.naftotopos.gr and I modified an old plan of that hull type.
I built the model following the method plank on bulkheads removing a number of them afterwards from the middle of the hull.
I prepared the false frames by soaking proper pieced of wood, bending them and drying them on the surface of the removed bulkheads.
I had to paint the inner of the hull before I plank the deck and keep it covered for the rest of the construction.
The grapnel anchor was made by using fishing hooks that were set and glued inside a hole in a plastic rod, while the cleats on the mast were made by modifying some fishing swivels…19859.jpg
The Shackles were made as is shown there
The Belaying pins were made as is shown there
The Sails were made as is shown there
It took me much time to decide about the colors on the model…Painting is always the only stage of my builds that stresses me. Wanting to give a local-origin character in my models, I'm always anxious whether I have chosen the right colors or I have turned it to a clown.
Finally the stand was made by a piece of plywood and some wooden rings which were cut in half. 19864.jpg
I hope my wife won’t notice the missing curtain hoops...:P :)
See the finished model in gallery.
Many thanks
sweet looking model.........very nice paint work and a really neat display!  very well done Thanasis.....a lot of charm and detail!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Sweet work.  Nice, clean, and beautiful.   It's good to see you back.
Thank you all for your likes and comments.!
Kostas nice to see you still here..
Friendly to all.
Thx
Edited by Thanasis
  • 1 year later...
Thank you Nikiforos-Thank you Igor. You're both vary kind.
Vagelis, You amazed me…Eventually you found the way to join us here.
By the Italian way…😉 Thank you buddy.
Grazie Nikiforos-Grazie Igor. Siete entrambi molto gentile.
Vagelis, mi hai stupito ... Infine trovato il modo di unirti a noi qui .
Con via Italiana ...😉 Grazie  Compagno.
Thx
