Augie,
When I tell everything on forehand, I think David will change it before he get that problem….
It's good for his building skills when he found it out by himself  :D
But on the other hand….he can also read the log and find out  :D
Yes I could read the log as you say except it went down in the great crash of 012....I can look at the pictures though lol no biggie with help I will get there :) :) :)
David     :pirate41:
First Build: Corsair Brigantine
Sorry David…….
You are right "snik"
But now you know what kind od things you came up with.
And of course…..you can ask me  :D
I think you are on the right track and it's gonna be a beauty when she is finished!
Hi David,
I have a secret for that and I don't tell you how I edit the pictures  :D
The foredeck….I just placed it and then start planking it.
Then you can put the planks nicely against the bulwark and you don't see any gap.
It's a little bit more work but then it looks great!
Good luck with it.
Edited by Sjors
Well I guess that's late since I lined the foredeck lol oh well let the game of the fitting it begin......am thinking maybe soak the front in water to get bulwarks a bit more playable then try to force it lol. Will find out after Thursday :)
David     :pirate41:
Don't force anything David, no good will come of it. :(  :(
You could try to steam it and then use elastic bands to pull the bullworks in, that way it's a slow pressure that does the job. ;)
Failing that you could always put an extra lining in. :)
What ever you decide mate good luck.
mobbsie
mobbsie
All mistakes are deliberate ( me )
Current Build:- HMS Schooner Pickle
Completed Builds :-   Panart 1/16 Armed Launch / Pinnace ( Completed ),  Granado Cross Section 1/48
Harwich Bawley, Restoration,  Thames Barge Edme, Repair / Restoration,  Will Everard 1/67 Billings
HMS Agamemnon 1781 - 1/64 Caldercraft KitHM Brig Badger,  HM Bomb Vessel Granado,
Thames Steam Launch Louise,  Thames Barge Edme,  Viking Dragon Boat
Next Build :-
Patience.... patience ...patience..... building is so much about fitting. You'll better understand that after planking, So basically - fit and file, refit and sand and keep repeating until it's where you want.
I agree with Sjors on waiting to plank until after. This may have helped on the bulwarks also as IIRC you inner planked before fitting them, which made them thicker. I've found that saving time in one place usually cost it somewhere else, such as with pre-planking decks. That is of course build dependent, as differing vessels are shaped and constructed different and make doing certain things in a certain order a must. I inner planked bulwarks after gluing and it was a pain also, but Know Pain, Know Gain. If this were easy everyone would be doing it.
For example, I think I've seen someone plank the deck of the Swift before gluing but cant remember who, it may have been pre-crash, anyway the deck hasa compound curvature and honestly I don't think I'd have gotten mine down if it was thicker. On a flat deck this wouldn't be as much of an issue.
Now after all the constructive crappola, she's looking Sweet. That break will never show and that gap at the stem, Well look at the gaps between bulkheads and see how nicely they cover up with planking, no one but us will know its there once planked. She's looking Really Good.
Oh one other bit of constructive blah blah.... on the front Balsa shaping. I used rasps which work beautifully to quickly shape the balsa, before sanding. Plus a small plane (I really like the brass and walnut 3 plane set from harbour freight for 9.99) will be really handy in planking for narrowing planks. That is if your don't already have one.
Howdy David!
Also late to the party (as is usual for me, keeping up with posts is rough at work - they frown on that sort of thing here,  but I try not to let that stop me too much).
Looks like you have come quite a ways and quite well done!  The fix looks great, your decking and hull look great!
Trust me, I am a newbie to this as well and I totally understand the nervousness - one thing I have learned (many many many times) as others have said - it is wood. Anything can be fixed!   And you handled it like a champ!
NICELY done!!
Will sit back here behind Sjors, Augie and crew and observe - they know what they are talking about, I still soak up information as much as possible.
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Hi David,
See you can do it !
Be proud of your self!
Very great job.
That's exactly what i was meaning……You see, for all the problems, there is an answer….if you keep looking  :D
Great,great,great.
going well David. ona a model there is always lots of things to do . sometimes can be tedious but mostly it just extends the fun of building  :)
Current builds : HMS Bounty, Constructo Pilar
Next build : undecided
On the Shelf : AL San Juan, Mamoli HMS Victory
Builds on hold : Ochre Gorch Fock, Hachette/Amati Black Pearl
Previous Builds Gallery : Virginia; King of Mississippi
Previous Builds logs : AL King of Mississippi 1/80
Ho, hum.  Another life threatening catastrophe goes by the boards.
:D  :D  :D   Just kidding.  Nice job.  Almost anything with wood can be fixed or redone.  And we always learn a lesson from our problems.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Welcome Adam and thanks to all for the encouragement...... Spent couple hours fixing things no one but me would prolly see but that's the nature of the beast sometimes.....all my work and now I have 3 more pieces of wood in lol.......post-3113-0-17716600-1371662563_thumb.jpg
Spent a long time sanding the hull down...another hopefully will make it easier later job lol :) :) :) only got one side done for now will have photos when I get it where it will be :) :) :)
David     :pirate41:
yup David sometimes you spend hours wihtout noticing anything changed but in the end it wil make a difference :)
she is looking good :)
Very nice job on the deck!  :)
Tim
Tim
Future Build:
  • BlueJacket - USS Kidd (Fletcher Class Destroyer) Solid Hull
  • BlueJacket - U.S.S. SAMUEL B. ROBERTS, DE413 | Butler-Class Destroyer Escort
  • BlueJacket - 310' Destroyer "The famous "four-piper" of both World Wars"
  • Model Shipways - Pride of Baltimore II (Topsail Schooner)
  • Model Shipways - Willie L. Bennett (Chesapeake Bay Skipjack)
  • Constructo - Pilar (Ernest Hemingway's Fishing Yacht)
  • Sergal - Race Horse (Bomb Ketch)
  • Classic Warships - USS Salem CA-139 (Heavy Cruiser) Resin Kit
  • Pen Duick Schooner - Half Hull (Scratch Build)
  • CSA Submarine Hunley (Resin Kit)
  • Classic Warships - USS Washington BB-56 (Battleship) Resin Kit
  • Blue Ridge Models - USS Alaska CB-1 (Resin Kit)
Completed Builds:
Member:
Hampton Roads Ship Model Society
Sanding is cathartic, no thinking involved, and you can use the repetitive motion to help clear your thoughts and let your mind find peace :D
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
