Added 4 scuppers on each side in between the first and second wale.
Drilled a hole on an angle. Cut off 9mm aluminium tubing, brushed some glue on it and pushed into the hole. The square wooden pieces on the outside are 1mm thick 5mm square dowel.
This is the first time I have added these to my build. Never done this before.
Marcus
Current Built: Zeehaen 1639, Dutch Fluit from Dutch explorer Abel J. Tasman
Unofficial motto of the VOC:
"God is good, but trade is better"
Spent several hours bending and forming the pintels. Next I got out the soldering iron and soldered 1mm diameter brass wire as pins and filed excess solder from the pintels.
On another note, I am thinking of making my own blocks and deadeyes. I have many articles on how to make blocks but nothing on how to make deadeyes. Are there any articles on MSW about this? Or is there something on the Net about it?
By making my own, I want to see if the finished product lookes like the material you buy from an online store. If after the exercise I failed I'll just continue to buy online.
Totally different question.
Some of the plans from the 17th century Dutch merchant ships are in scale 1:96.  If I want to make them 1:48 do I set my printer at 200%? Twice the size?
The Fluit is 1:96 and I find it rather small. Enlarging this I can add more details.
Thanks for answering.
Marcus
Created some of the deck items from walnut. Installed the bits and bollards that line the sides of the boat.
The mizen mast holder is from walnut and I had to file the railing a bit so that the piece would sit straight as well as the mast that goes into the holder.
Finished the pinntels and will drill tinny holes to fit the brass nails.
Having trouble uploading pictures.
Marcus
Still having problems uploading pics from my phone. After much research there seems to be a glitch in the actual transfer from my android phone to the forum. It comes and goes for no reason.
(don't you just love technology).
Marcus
Hello Marcus,
I remember having the same issue as you of having difficulty uploading pictures from my Android phone onto this site. It seems that the size of picture that the phone takes is too big or too many pixels for this site to accommodate.  After being given an old digital camera, the problem ended for me. Another solution you can try to do is to e-mail yourself the pictures and then using a computer upload the pictures onto your forum.
Brian :)
Sort of fixed the transfer of pics to the forum by setting the camera to manual and reducing the pixel size of the pictures.
The deck items are pretty much completed.
The stem with bollards and bits. Hatches have been added as well.
The main hatch and part of the cabin.
Bollards, part of the cabin and at the pointy bow area the mizen mast holder.
The vertical piece of wood is for the sheet. There will be two of them.
Here is the second vertical bar that will be for the other sheet.
Rudder post and rudder.
Tiller under the mizen mast holder.
Is there another word for 'mizen mast holder'? What about Dutch?
Marcus
Hello Marcus,
I'm finally back with you and caught up with your build. Enjoyed looking through your posts with all the interesting information added.
She's looking rather spiffy.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi Marcus
I’ve also managed to catch up (after feeling very guilty for not stopping by more often due to work constraints).
Irrespective of that, wow wee!!!!  Yours is the sort of build log that puts a smile on my face.  What started out as raw materials in the beginning, has now blossomed into a real little gem.  Such a  pleasure to follow.
Good luck with the rest of the build.
Merry Christmas and have a happy 2019.
Patrick
Patrick
Thank you for the compliment. Yes, she is coming alone nicely. The masts, sails and rigging has some similarities as the yacht, Utrecht. The Boyer has an added mizen mast and a spritsail yard and sail.
Merry Christmas as well.
Marcus
Created more deadeyes.
1: Take a dowel and put it upright in a vise. Use a drill press and a dremel with a 0.061 bit and drill three holes.
2: Remove the dowel from the vise and carefully file a groove all around.
3: Use saw to cut the deadeye of the dowel.
4: Put the deadeye in the drum sander which consists of the following: plastic jar lined with sandpaper (gritt 120) with screw lid, quarter inch dowel which have 2 pieces of sand paper (gritt 120) glued to it
I either roll the dowel by hand or attach drill to it running the drill at 3 second bursts.
Marcus
Created the windlass and the windlass pawl which will be positioned in the midline on the inboard stem. I added four sticks in a rack in front of the windlass. In real life these are used to turn the windlass.
Created and installed the upper and lower brass pieces which are pinned to the upper stem to house the tie down for the main stay. Forged brass loop which has been attached to the stem and will be used to hold the gammoning ropes to support and fix the bowsprit in place.
Marcus
I inherited a dremel Moto 700 lathe from the secretary of the North West Indiana Woodworkers club and with that item I've made grooves in various size dowels (birch, walnut and cherry) in about 2 hours.
226731228_Boyer86ftdeadeyesondremellathe.thumb.jpg.e63e7d2a2ac58f6fbb9d0c18d90f9b6a.jpg
When filling a straight groove by hand this is the most difficult part of making a deadeye. With the lathe it is faster and straight.
Got 19 dowels which will be about 450 deadeyes. Enough for a few ships.
Drilling holes and cutting them off with the saw is easy.
Marcus
Have been spending several weeks making different types of blocks. Very time consuming assembly work. Several hours everyday.
After looking at prices of the different types of blocks I need for the Boyer, it made sense to me to make them myself and save some money. Compared to what is on the market, my blocks are not as nice looking...... Yet. But with time, they will become better looking.
Once I start building a Fluit and a war yacht I may just cave and purchase the blocks as I need lots of them.
Tried out different type of stock to see for myself what works. Walnut (easy, sands well, will use this for the Boyer), cherry (breaks easily), pear (sands well, no breakage), birch (splinters), and maple (too light in color).
I created my own method from the combination of several articles I have on file.
Stock is measured in 4, 5, 6, and 7mm width and thickness. Length of dowel is 30cm. With a slithing blade on the saw, 2 slits, 2mm apart, 1mm deep are cut the length of the dowel as well as the opposite side of the dowel.
Here I will measure and mark with pencil the different sizes of the blocks. Ever block has a 5mm boundary area between it.
Sheave openings are drilled.
Now comes the tedious part of the exercise.
Boundary cuts are made as we as removing the rest of the stock between the blocks.
Top if the picture shows the isolated blocks.
Close to the bottom of the picture is where I am sanding the edges to create an elliptical form.
The bottom of the picture shows the blocks. The final part of the exercise is the filling in of the stropping grooves and giving the blocks a final sanding.
Hope this made some sense.
Marcus
Created the metal work for the deadeyes. Tried several ways of attaching the deadeyes to metal links and came up with a simple way of doing it. They are a bit crude looking.
The picture in the book shows a simple method and I somewhat followed that as well.
Main mast channels and deadeyes
Mizen mast and deadeyes.
Been making some more blocks, just a couple everytime. Will start on the masts and yards next.
Marcus
Nice work Marcus.
Cheers,
                       VOC Ship Surabaya
Hi Marcus
I’m loving the colours and overall look and feel of this boat of yours.  I’m not quite sure what it is about this particular design of boat, but I reckon it looks pretty darn special.  Lots of charm and loads of character; all of which you’re capturing really well.
You’re definitely on a winner, there.
Pls keep the updates coming.
Cheers
Patrick
Edited by Omega1234
11 hours ago, Omega1234 said:
Hi Marcus
Patrick
Patrick,
Thank you for the compliments. What I like so much about this ship is all the curves, curved stem, the heavy wales and the triangular helm port transom.
Marcus
Created all the small single and double blocks, throat halliard blocks, fiddler blocks, leeboard block, one heart, 5mm deadeyes, belaying pins (need to make more) the gaff jaws and for extra added entertainment 4 barrels, 2 large and 3 small buckets.
All the deadeyes for purchase are flat in the middle on both sides but in reality they should be round. I have tried making them myself but it is not working. I am still figuring how I can do this.
I have purchased deadeyes and if I can't make them myself I will use those (picky, picky)
Thought of purchasing the buckets but because I was making the small blocks, why not make them myself. Drilled a hole in a dowel, cut them to height and glued a 1/32 thick piece of veneer as bottom to it, sanded and stained or painted them.
The rigging of the mizen mast is going to be a challenge. The plans are different compared to the model in the book. So I will look at both and work towards something logically. The rest is the same as the yacht "Utrecht" and the Galjoot (which I have plans for as well).
I will add some flags such as the Dutch flags in the colors of 1600's.
Marcus
Temporarily put in the jack boom and mizen mast.
Leeboards are attached and held up by a piece of string until the final rigging can be done for them.
Also painted the hull off white. White paint mixed with a drop of yellow ochre. Hulls were not pure white.
Marcus
Stitching the sails and putting the hardware on the masts and yards.
Starting next week I will not be working much on the Boyer as my wife is getting a knee replacement and I will be taking care of her.
Also after this boat is completed I want to start building the ships from Abel Tasman.  First the fluit, the Zeehaen and last the war yacht, the Heemskerk.
Scale will be 1:37.5. The plans I have are the printed 1:75. The cd has 1:50, 1:87.5, 1:100 & 1:150
The model Zeehaen will be a little more than a meter long. Always wanted to build a large ship. The details will be fantastic such as the carvings. I have lots of wood from my wood workers club.
The fluit will be a challenge.
Marcus
Marcus,
WIsh your wife well, and I hope she'll have a speedy recovery.
You have set your ambitions high with the ships of Abel Tasman, you'll have some exploring to do too.
Carl
