A friend dug up a project that was starte quite some years ago and never finished and gave it to me
The 1st inspection was about trying to see if there was any missing parts, seems a few wooden pieces are missing, all i've see so far can be replicated easily from the scraps i have arround.
Some tears in the instructions along with some water damage, still everything is readable.
2nd inspection on what has been built already, news are not so great, this piece is wrong
The main piece of the deck is not centered
And the castle already made didn't take into consideration that the is inclined
So, the work started, mostly about correcting or minimizing the mistakes
more updates soon, the build is already a bit further ahead than this post
Nice recovery. Went through this on two previous builds over the years. Everything must be methodically measured and checked against the plans. If not, disaster. Keep up the great work.
looks really good  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
look'in very nice :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
a friend recently sent me the remnants of this model that he had bought off of E-bay.........your log will be a great reference when I get around to rebuilding it  ;)
nice job on the paddles! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
good luck on your build, let me know if you start a log
Now i have a decision to make, with the paddles in place, it is clear that the waterline should be higher, but if i move it, aesthetically from most points of view, only black will be seen on the hull... so... accuracy or aesthetics...
Edited by LFNokia
really like this boat and your build of her. regarding the hull color, i'm not too sure what you mean but why not get rid of the black altogether and paint the entire hull white, which was extremely common practice at the time. a lot of old drawings of the vessel depict her with a white hull. she certainly appears in literature and art with a predominately white hull as opposed to one having a black one.
cheers
chris
cheers
chris
I like that a lot more than moving the black so high, i'll definetly consider it, thanks
nice progress  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
lik'in the way she's coming along.......kind of a rustic / antiqued look :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
  • 10 months later...
Then the time was for the stairs
the pieces cut
After assembling the stairs
After staining (the wood from the stairs doesn't really absorb staining that well)
After working a bit with dry pigments
Stairs in place
Bit of staining arround to better integrate the stairs on the floor
Build is moving along once again, maybe this time it keeps moving until the end
The railings
A poor attempt at bending, used a lid of a jar
The columns/pillars
1st Markings for the holes
Marking for the drill
Holes drilled
Painted white
Aged
Final result
Final result on the other side
The copper wire was blackened with Brass Black, but applied with a brush, not dipped, to keep some of the copper showing a bit
good to see your still working on her....... looking very good :)    nice job on the railings.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
