Thanks Frankie. I hope my log is of some assistance. I know the others on this site have helped me.
I am going to Eire in August to see the real Niagara (and the rest of the tall ships on the Great Lakes this summer). Probably will not check out the Tops - I grew afraid of heights after a trip up the pole mast on the USS Rathburne in 1977.
While in Australia late last year I got to take a "three hour cruise" on the James Craig (1873 iron hulled three masted barque) where we set eleven sails. Quite an impressive sight.
Thanks,
Gary
Current Build - Emma C. Berry
Prior Builds:   Rainbow 1934 America Cup defender
                       Lucia A. Simpson (Great Lakes Schooner 1875)
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
A point I should have made on the Main Mast but the issue is the same on the Fore so here it is. If you use the kit recommended line size for the Main/Fore stays and Preventer stays (.045 and .035) and serve them as I did when you install them there is  not enough room left in the opening at the top to get the top mast to fit. I had to taper the bottom inch of the top mast to about half its plan dimension on each side in order to get it to fit and slide down far enough to get the black painted section below the mast cap.
I have no other solution except using smaller line for the stays but am not sure that would fix the problem either.
Edited by cdrusn89
bad photo
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Assembling the Fore Mast (in spite of the issue highlighted above). Also working the bowsprit installation including the bowsprit shrouds, bobstays, and the spritsail yard lifts..
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
More issues. Unwisely I built the top mast and inner and out jib stays (the eye and mouse) without considering (or considering properly) that all three exit under the top mast platform and need to have their connections (eye and mouse) not interfere with each other. As a result I had to modify the top mast stay and create new ones for the inner and out jib stays. So, for those of you also building the Niagara and using the "eye and mouse" to create the loops to carry the top mast stays around the top mast, wait until the top masts are assembled before establishing where the mouse goes on each stay.
Here are the three fore top mast stays (top mast, inner jib, outer jib from top to bottom). I would have liked the out jib mouse to have been a little further away from the eye but since it passes through the bowsprit further forward than the other two, I think it is okay.
Now on to the fore top gallant mast.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Completed assembly of the Fore Mast with all the stays and shrouds (and the two fair leads for the main royal and top gallant stays). Now on to the Top Gallant and Top Mast deadeyes, sheer poles and ratlines.
Also have gotten the Bowsprit as far as I care to go before the Fore mast in onboard. There are four lines that pass through the dolphin striker, the top one is the Jib Boom Martingale, but the next two are the Top Gallant and Flying Jib stays. I want to rig these in the order from top to bottom to reduce the interference while rigging. Also the Flying Jib Boom and Jib Boom guys will not be rigged until the stays below have been rigged also to reduce interference. The red clips are holding the downhaul lines for the four head sails. These will connect to the respective halyards when the final running rigging is set up following installation of the Fore Mast.
Here is a shot of the complete Fore Mast and two of the Bowsprit assembly.
Edited by cdrusn89
missing photos
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Upper Fore mast now ready for ratlines. Sheer poles installed and Top Gallant shrouds terminated per the plans. Having done the Main it was easier to get these completed. Hopefully the ratlines will be easier also.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Fore Top Gallant mast ratlines (the easy ones) complete. I believe those are "calf hitches" on both ends.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Fore Top Mast Ratlines done - on to the yard arms after I stroup a few more blocks for the braces and some that I think are missing on the fore yard arms.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Before beginning the fore yard arms I "took a break" and ran the head sail downhauls (the bitter end will hook to the respective halyards) to the fwd pin rail along with the sprint sail yard lifts. When I started this effort I noticed that I had put the fwd pin rail on top of the main rail instead of under or at the same level (the plans are not clear on exactly where ism should go - except not on top). At this point I decided to leave well enough alone and added an additional 1/32" X 3/32 strip on top of the existing splash shield/fairlead to serve as the fairlead for these lines. Clearly I could have done a better job by cleaning up the inside where the holes are drilled but you live and learn. In addition to the downhauls and lifts there is the jib boom out haul tackle which is shown on the plans but not on the belaying plan. I took that line through the opening between the two pieces of new splash shield and to the stbd side cleat on the side of the bowsprit and then to the fwd bitts. Seemed like the only real alternative - the port side cleat is used for the Royal Stay tackle.
So here is what it looks like with the lines secured and rope coils added.
Edited by cdrusn89
typo
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Messing around with a few odds and ends (trying to avoid working on the Fore mast for some reason). Decided to get the anchors ready for installation. It will probably be easier without the Fore mast in place. I previously wrapped the anchor rings with .008 Syren dark Brown rope so will use Syren Dark Brown for the anchor rode too. I had both .065 and .054 sizes available (and the smaller ones too but the anchor rode should be the largest line on the ship). I tried the .065 but it is too big to get through my improvised anchor rode "fair leads" so I will use the .054 (that is ~3.5" in diameter at scale or almost 11" circumference which is pretty heavy line).
Here are the anchors in the jig for serving the eye "splice" and ready for installation (a bit of touch up required).
Edited by cdrusn89
typos
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
That looks Nice Sir! :imNotWorthy: Kevin
Edited by Javlin
Continuing my search for things to do before the Fore Mast is installed lead me to the head sail sheet lines. All but the Flying Jib have a pendant with a block on each end and the standing end is attached to some part of the structure (eyebolts or the support rod of the cat heads). That being the case the end that terminates at the bulkhead cleats can be done now and any adjustment (as long as the line gets shorter of course) can be done later at a more accessible location. So here are the stbd side head sail sheets belayed to their respective cleats. The port side is similar but the Flying Jib on that side can't be done until later.
I am going to make up some of the tackles that will be required later and then it will be time to mount the yard arms on the Fore mast at get to rigging them.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I finally got around to finishing the Main shrouds (those not involved in ratlines). I did not belay the bitter ends as they may need a final adjustment when the forward pulling stays are attached when the Fore Main is installed. Here are the port and stbd sides showing the Main Top Mast, Top Gallant and Royal backstays.
Having experienced the fun of accessing the eyebolts where the Royal backstay tackles attach with all the rigging in place I decided to install the 3/32 S block, with the lanyard already in place (it will be attached to the "becket" of the 3/32 S at the end of the Royal backstay) for the Fore mast now. I also added the course yard lift tackle (which attaches inside the fwd Fife rail) now and the bullseyes and lanyards for the Main Top Mast and Spring Stays terminations which are also inside the Fwd fife rail. Hopefully this will make getting these attached easier once the Fore mast is in place.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
While preping the anchor rode for installation on the fore deck I found where the plans call for .047 line for the rode. I don't have that size and .054 is "close enough" for this build. So I ran the rode through the hawse holes and used 50/50 glue water tom get it to lie flat on the deck, then ran them to the holes in the forward hatch where they (presumably in real life) go into what would be called the "chain locker" but in this case the "rode locker" somewhere below deck and forward. Given that the capstan is back aft they must have lugged the rode up from storage and back to the capstan when they were going to raise the anchor(s).  Doesn't sound like much fun as 10" line is pretty heavy, even heavier when wet. Anyway here is what the anchor rode looks like on the fore deck. The anchors are hanging from the cat head with temporary lines to keep them out of the way for now.
Continued to install yard arms, I believe I have the top three complete. Here is a shot of the Fore Mast with the upper three yards (and most of their rigging) in place. Also a shot of the Fore top showing the Top Sail reef (a port and starboard set) and Top Gallant halyard tackles. There are two more items that terminate on this platform, the Main Royal Stay and the Main Top Gallant Stay. The tackles for these are "ready and waiting" as it was easier to rig them now and just attach the stay to the tackle than do that and then try to rig the tackle after the Fore Mast is in place. The Main Royal Tackle is clamp you can see at the bottom right of the picture.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
A milestone day - the Fore Mast has all it yards and as much of its rigging as it is going to have prior to installation and then, and then the Fore Mast is in place onboard the hull.
Quite the rats nest that needs to be straightened out of the comes days and weeks.
I have an internal deadline to finish by the middle of August - we are leaving on a road trip to see the Tall Ships at Eire, PA and then a "side trip" to Bluejackets in Maine to pick up the case they are building for it. I have built cases using Model Expo "kits" but I wanted to get this "done" without further effort on my part (other than driving 600 miles out of my way and back to pick it up). I used to spend a good deal of time in Maine on business but have not been there in 15 in years or so. Will be good to see what has changed.
Edited by cdrusn89
typo
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Gary,
Your Niagara is beautiful.
Even thru that "rats nest" you describe, its really looks great.
Tom E
Thanks Tom.
I decided to try and get all the stays (except the Fore Stay and Preventer - I don't want to do them until the fore mast is stabilized at the correct rack by the stays from the Main Mast.) from the Fore Mast to the Bowsprit located and prepared for tensioning but not close to their final position yet. I think I got them all but discovered I had not installed the tackle for the Outer Jib Stay - that tackle is out on the end of the Bowsprit (all the others are at or near the bow). Turns out I had the tackle made up and ready to install I just never got that far down in the "tackle to be installed" box. It is empty now.
I got the lower deadeyes installed on the shrouds on the port side and will get the starboard side done tomorrow before I install the lanyards on the forward and rearward most shrouds on both sides as I did on the Main Mast. Once the Fore Mast is stable to port and starboard I will tackle the stays between the masts to stabilize the Fore at the proper rack.
So here is how she looks at the bow now. Also a shot of the rats nest of lines coming off the Fore Mast that have to be sorted, routed and belayed - after the stays and shrouds are done.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
While installing the stbd side deadeyes I thought I might provide some details on how I do it. I am not saying this is the "right" way just my way developed over the five ship models I have built plus many hours looking at other build logs and tutorials.
The starting point is a wooden jig attached to the lower deadeyes with a line where the top opening (upper deadeyes have the center opening at the top) in the upper deadeye should be located. It is important to make sure this is in contact with the channel at both ends and that the line is parallel with channel surface. The jig is attached to the lower deadeyes using pins through one of the upper openings. Once the jig is in place each shroud is brought to its lower deadeye and where the shroud crosses the upper deadeye line is marked. I drill holes (#72) through the jig at these locations and pin a deadeye in each place. For Niagara there are no significant angles that the shrouds must follow but if there were a line would be drawn on the jig from the upper deadeye center to the center of the lower deadeye to assist in getting the next step. Once the upper deadeyes are pined to the jig, they are aligned with the aforementioned alignment line (or "eyeballed to the correct orientation) and a second pin through one of the other holes is used to hold it in place. (Photo 1)
I start at the front (but I do not think starting point is important) and wrap shroud #1 around the deadeye and use an alligator clip to hold the shroud together just above the deadeye. For Niagara the plans say that the shroud end goes behind the shroud so I go to some trouble to make sure the end is behind the shroud (although that is not obvious in picture #2).
Using a piece of well waxed line (I am using Syren .008 Black but anything about this size or smaller will do) I tie an overhand knot around the shroud and under the alligator clip (Photo #3)
Remove the alligator clip and adjust the knot to both get the shroud end behind the shroud (moving the knot to the side and pulling it athwart ship seems to help in this) and to get the knot location close to the deadeye - you should get something like Photo #4. The wax helps to thread to adhere to itself and not loosen badly. A touch of thick CA on the knot and let it set up.
Remove the deadeye from the jig and use a "second hand" to hold the deadeye/shroud and a small clip to hold one end of the waxed line down. Wrap the other end of the waxed line around the line keeping the wraps as close together as possible. The wax helps keep the wraps from unraveling. (Photo #5)
Wrap the waxed line down until you reach the top of the deadeye (Photo #6)
Tie an overhand knot with the two ends of the waxed line which are now at the top of the deadeye and add a touch of thick CA. (Photo #7)
Use a similar technique to add a second wrapping above the deadeye and trim the ends of the waxed line and the shroud end. I use cuticle shears to cut the line. They can get really close and seem to stay sharp. A completed deadeye (for Niagara) is shown in Photo #8.
I return the completed deadeye to the jig and move to the next shroud. I believe it is important to keep all the deadeyes in place during this process. It is easier to see the tension in the completed ones as you clamp off the next shroud. It is possible to over tension a shroud and make some or all of those already completed too loose. Don't ask me how I know this.
Edited by cdrusn89
typos
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Great tutorial on a very complex process of rigging shrouds. The photos are a great help. Thanks and the ship is looking really good.
Will
HM Cutter Cheerful  Syren Shipmodel Scratch 1:48 scale
On Hold:
Syren by pearwill Model Shipways 1:64 scale
1776 Washington Row Galley scratch scratch from NRG plans #121  1:48 scale
Completed Build:
Erycina 1882 Fishing Trawler by Vanguard Models 1:64 scale
Charles W. Morgan by Artesania Latina circa 1988, Lowell Grand Banks Dory 1:24 scale by Model Shipways, Norwegian.Sailing Pram 1:12 scale by Model Shipways, Muscongus Bay Lobster Smack 1:24 scale by Model Shipways
Thanks Will - getting the deadeyes "right" (aka the same or nearly the same length) has always been a struggle for me.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
There’s a ray of hope for us as all my friends struggle as well.  HA HA HA
Will
On Hold:
Completed Build:
Having gotten all the deadeyes (including the smaller ones for the Top Gallant Backstays) completed I moved on to the hearts for the Main and Fore Stays.  I used a very similar technique on these as on the deadeyes. Really not too difficult. I used Syren 7mm closed hearts instead of the ones supplied in the kit - they look better. I also painted the ones for Fore stay and Fore Preventer stay black as I had previously painted the collars on the Bowsprit black. I left the Main and Main Preventer hearts the natural color of the wood which I believe is Alaskan Yellow Cedar which the what I have used for the masts, main rail and deck.
Edited by cdrusn89
typo
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
With the Fore Mast stabilized athwart ships I worked on the Main mast stays to get the Fore Mast stabilized fore and aft (having already rigged the Fore Mast stays (except the Fore Stay and Preventer). I had put the tackle for the Royal, top Gallant, Spring and top Mast stays in place so it was a matter of routing the stay through the (hopefully) correctly positioned fair-leads and connecting them to the tackles. It went pretty well except that getting the served stays to move through the fair-leads did not go as smoothly as I had hoped. The combination of the serving thread and the glue/water mix makes them much stiffer than the unserved line (and bigger in diameter too) which made some of the fair-leads both too small (drilled them out with handy pin vice - I used Britannia metal bullseyes of various sizes for the fair-leads) and not really in the correct place to get the stay through without 'hanging up". Luckily I had not done a very good job of securing the fair-leads so I was able to move them enough to get everything where it needed to be.
Once the upper stays were in place I rigged the Main and Main Preventer Stays using the previously installed hearts. I used Syren .018 Dark Brown line for the lanyards. Chuck is no longer making black line and I was out of black .018 so I switched to the dark brown. It is not too easy to tell, either in the pictures or on the model. You have to look closely to notice the difference.
Here is a picture with all the main stays in place and shots of the Main and Main Preventer stays, the Top Mast and Spring Stay tackle at the base of the mast and the Royal and Top gallant tackles on the Fore Top.
We will be untangling the "rats nest" soon!
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Looking really good Gary and got to give you credit for doing something just about everyday that's the way to get things done in a reasonable period of time. ;) Kevin
Thank you so much for the detailed photos and descriptions. I've been a little stuck on my Niagara rigging for a while and while there are many other excellent build logs, yours is easiest for me to follow along with. I really appreciate it. Such nice work and photos too.
Dave Barnard
Current build: IXO 1:8 scale Mercedes W196 (a little break from ships)
Completed:
Marseille (Mamoli) - 1985
Constitution (Mamoli) hull and deck only - 1987
Duke William (Kammerlander) - 2008
Halifax (Lauck Street Shipyard) - 2013
Niagara (Model Shipways) no masts/rigging - 2019
HMS Speedy (Vanguard Models) - 2024
Dave, Javlin - thanks. Being retired makes working on this easier than if I was still working but there are "other things" that seem to get in the way even now.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
I am declaring the Bowsprit completed (except for tensioning the head sail sheets lines and halyards). I got all the guys and stays adjusted, tightened and then glued to keep them that way. I hooked the head sail halyards to the downhauls although they are kind of hard to msee unless you look closely. I also included the headsail sheet lines, three of which have a pendant with a block on each end. I considered hooking the sheet lines to the downhaul/halyard intersection but it puts a load that causes the downhaul/halyard to sag well away from the stay that would hold their sail. For now the sheets  are just sitting on top of the bowsprit guys with the center (more or less0 of the pendant hooked to the eyebolt that holds the downhaul block. i may revisit this later but that is how I am doing it now.
I have started to unscramble the rat's nest of sheet, clew, bunt and leech lines and have gotten about ten of them terminated. I am concentrating on those at the base of the mast and on the fife rail. The ones on the pin racks come next.
Here are a few pictures of the completed (almost) Bowsprit and a shot of the base of the mast showing the lines that are belayed. If anyone wants pictures of a specific rigging item let me know. I am itching to get more use out of my macro lens.
Edited by cdrusn89
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
Thanks Kevin.
I reworked my plan for getting the braces installed so I could belay the Fore Course Yard Braces (pin 53 for those following along) now rather than later. This would complete my plans for the aft portion of the Mail Fife Rail (pins 15 and 52 are for Spencer brails which I am not modeling). With that done I can finally install the bilge pump which has been quieting sitting in the "to be installed" box for months (along with the galley stove pipe and the belfry). Access to the aft portion of the Main Fife rail with the pump in place would be a real challenge and the pump handles are pretty fragile. One sneeze while holder tweezers in both hands could led to more work than I had planned. Anyway, the pump is in place and I moved on to continuing to unsnarl the "rats' nest".
Here is the pump in place and the Fore Fife Rail with all (I think) the lines that belong there.
Thanks,
Gary
                       HMS Sphinx
                       HMS Winchelsea
                       USF Confederacy
