Hello
Just started building the Brigantine Schooner "Gigino", an Italian sailing Vessel from the Early 20th century. Actually I'm very fond of Schooners and Ocean Paddle Steamers as well, and I plan to  work on "Barquentine cote d'émeraude" in the near future, ((supposing that I find the Plan (I hope so)).
I'll follow the same technique, which is Double planking on Bulkheads. The first layer of planks will be 3 mm Balsa wood to get a tough body, while the second is 1.5 mm is to get a natural wood finish look. I guess it won't be easy to find a 1.5 mm Balsa wood with clear wood grain appearance and it would need some research to use coloring to get that look.
Thank you
Models in Progress
L'Etoile
Vapor Rimac 1848 -  a side Wheel Paddle Steamer
Previous Models
Bluenose II
I agree they are so elegant - I'm looking forward to see how your build develops.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you very much Keith, please do. I find your Models stunning and inspiring.
Good Morning All,
am still working on the 2nd layer of planks, here it is. Please Notice the difference :)
thank you
Mhkash - looking good - what wood are you using for the second layer of planks?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Good Morning Keith, I use Balsa wood 1.5 mm thickness, and i was lucky to find 3 sheets of good quality.
I have completed the 2nd Layer yesterday. Here we go :)
Thank you
That looks very interesting - whit some impressive progress. Could you kindly thell me what set of plans do you use?
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
Hello Heinrich
Thank you very much for stopping at this thread and apologies for late . Here is the plan i used, they are a little bit large.
Thank you
Hello
I spent yesterday building the rear cabin and finalizing the 2nd Layer of hull planks. Here is the latest progress.
Please notice the Deck and the hatch.
Thank you
Hello All
It is always like that, as I go on building, the model looks more better then it was at the beginning of the  process. At the Beginning it is like a junk to me :), however , I keep saying to myself ... no no , wait and be patient :):).. until the shape becomes similar to the Original :)..  here i did some work on the bow. hope you like it.
Thank you All.
Hello All,
Hope you are all having good time with your models 😉, spent some hours working on the deck rigging . I think a did a good job with the anchors winch. Please let me know what you think of.
Thank you
On 5/19/2019 at 12:53 PM, G.L. said:
It is indeed a very nice winch.
Thank you very much for your nice words 😊
Good Afternoon to you all
I'm still working on the Deck rigging, here is a piece i built this weekend.
Thank you
  • 2 months later...
Hello All
sorry for not posting the updates for long time, I was away for a month and as i came back home, i decided to resume working on my model , here are are snap shots for building the Deadeye blocks.
first , i took a piece from balsa sheet, used sandpaper for getting the shape of a tube, cut the blocks , paint and wrap a wire around to maintain against cracks :) :)
Thanks
Hi All
I've completed painting the Hull with a G5 Deco Spray, Black and Blue, with a yellow strip in between. The G5 is one of the best that i found here in the local market and gives a nice effect. here it is.
Hi
Here am working the rigging, there is not many left to do, I expect to get it done soon.
Thanks
Hello
While i was searching for real pictures of the Gigino, i found this old one.
Thank you
Good Morning
Here is extra work on blocks and on the fore sails ,  they are furled as you see ... However, I do not intend to do the same with the Stay ,Mizzen sails.
thank you
Hi
Here is some work on the rigging :), my problem is that I don't have a proper place to use while taking photo shots of my work, maybe I should do some work to prepare a suitable place at home for that ... meanwhile please excuse the photos quality
Thanks
Edited by mhkash
Good Afternoon all
Here is my Brigantine Schooner - Gigino at the EGYHOBBY 2019 fair, Thank you for your support and comments.
Thank you
Edited by mhkash
  • 1 year later...
That's a beautiful model. What did you use for the deck plans?
Tony
