Sanding decks is tedious and tiring and with my fat fingers, problematical.  So.. a tool, preferably power was called for.  After remembering that a floor buffer could be used to sand a wooden floor, I reached for the Dremel.   I'm using the mandrel for the cut-off disks and one of the felt buffing pads.  A chunk of sandpaper is rubber cemented to the pad.   I'm looking around for a rubber disk, the right size to perfect it a tad more.  I turn the Dremel on low and hold it as perpendicular to the deck as I can get and apply next to zero pressure.  It does a nice job, fast.
Just to be careful and be light handed as usual when suing power tools and results can be amazing. Thanks for the tip! :10_1_10:
Respectfully
Valid points.  Low speed and light hand keeping the sanding head flat or nearly flat to the deck.
Good Ideas, Thanks for sharing them.
Later 42rocker
Current Build -- Finishing a 1:1 House that I've been building for a while
Current Build -- Triton Cross Section
Thanks Mark great idea for the work boat i'm in the middle of building right now. I was just thinking how I could make it a little easier sanding the inside of the boat...
Thank You all...
Mario
:piratetongueor4:  :piratetongueor4:
"Each of us is a mixture of some good and some not so good qualities. In considering one's fellow man it's important to remember the good things ... We should refrain from making judgments just because a fella happens to be a dirty, rotten SOB(biscuit) ;) "
My Builds....
BETTEAU WAR OF 1812     BOUNTY LAUNCH(bashed)    CHESAPEAKE BAY FLATTIE
THE SEA of GALILEE BOAT   VICTORIAN STEAM LAUNCH(bashed)    HOWARD CHAPELLE's CRABBING SKIFF
LADY KATHRINE 1812 SCHOONER
Here is another tool. It is called a 'mouse' made by Black and Decker and sells for about $35 at Home Depot.
I have used it to sand the deck and hull and for this kind of work it is a fine little sander. It comes with different size 'feet' for tight corners.
Jay
Current build Cross Section USS Constitution  http://modelshipworld.com/index.php/topic/10120-cross-section-forward-area-of-the-uss-constitution/
Finished USS Constitution:  http://modelshipworld.com/index.php?/topic/103-uss-constitution-by-modeler12/
'A picture is worth a  . . . . .'      More is better . . . .
Jay,
I almost bought one of those, but it's still way to big to get into hull.  There's some serious tumblehome to deal with.
Thanks for the comments everyone. I thought I'd add a bit more....
I'm using 220 grit with a very very light touch.  Too much and I'll get swirl marks which I found out in testing on scrap.   Too large a grit (100 or less) and it shreds and swirls the wood.
For finishing, I'll be using my oscillating pencil sander with 320 paper.   The scrapers are great but that deck area is in such a tight spot (between the raised center on oneside and under the tumblehome...  well.. my fat fingers argue the point. :)
What is a oscillating pencil sander? I've used spindle sanders and air powered oscillating palm sanders and disc sanders and hell, about 10 more not suited for this hobby but I've never heard of an oscillating pencil sander. Sounds perfect for tight spots. Who sells them?
Randy,
See here: http://modelshipworld.com/index.php?/topic/341-micro-power-sanders/
I'm using the top one on the deck for finishing.
Augie,
Sorry for the oversight. :blush:
Thanks Mark... I had no idea... I've not spent much time on micro-mark other than a quick glance... but, what a goldmine.
Great, another place where I could spend a fortune. :P
Micro-Mark makes a 1 inch diameter  sander mandrel and has both 80 grit disks and 220 grit disk which can be used in any rotary tool. The item number is 80482. Laman
Rats... I went to all that trouble and I could have bought one???   Oh well.. it was good experience anyway. :)
Being a newbie, I am still a danger to my kit with a piece of sandpaper. I could only imagine the havoc I could cause with one of those
 On with the Show.... B)
  J.Pett
“If you're going through hell, keep going” (Winston Churchill)
Current build:  MS Rattlesnake (MS2028)
http://modelshipworld.com/index.php?/topic/45-model-shipways-rattlesnake-ms2028-scale-164th/
Side Build: HMS Victory: Corel
http://modelshipworld.com/index.php?/topic/3709-hms-victory-by-jpett-corel-198/?p=104762
On the back burner:  1949 Chris Craft Racer: Dumas
http://modelshipworld.com/index.php?/topic/939-1949-chris-craft-racer-by-jpett-dumas-kit-no-1702/
Sometime, but not sure when: Frigate Berlin: Corel
http://www.corel-srl.it/pdf/berlin.pdf
