Hi all, Scott here. I'm looking to get some Walnut to plank my scratch build of the Mayflower. With Crown closing, where's the best place to get modeling lumber?
Thanks guys!
current build : model shipways willie bennett
" Never make a promise that you can't keep , a man's word is his honor"
Scott I Pollack
Quick and dirty:  Woodcraft lists an outlet in Phoenix
They have Walnut veneer.  Can be cut with steel straight edge and a sharp knife.
There are hardwood stores in Phoenix - if you have the tools to handle dimensional stock.
Walnut can be a beautiful wood for furniture or gun stocks.  It is relatively hard, tight, holds an edge.
It has one bothersome characteristic - it has open pores.  Not the best look when scaled down.
A tight grained closed pore species can be used and made to match Walnut by using an aqueous or alcohol aniline dye of the desired color.  Not a stain - which is a surface semi transparent paint - a peritrating dye.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Many hobby shops carry the Midwest woods also:  https://midwestproducts.com/collections/hardwoods
If you are trying to avoid the box and pear, look into cherry.  The grain is tighter than walnut and it ages beautifully.
M
I know there has been some questionable 'boxwood' strips from Modelexpo, but I have recieved some excellent walnut, cherry and mahogany sheets from them.
Spend $100 and get free shipping  ( while promo lasts )..
WOOD SHEETS At ModelExpo
― Jimmy Buffett
On Hold:    Rattlesnake
Awesome!!! Thank you so much for the guidance. I'll start a build log once I get going in the next week or so.
Scott
Scott I Pollack
While my link took you to the ModelExpo sheet wood, there walnut strips should be good also.
They have always been good about taking stuff back if you are not happy with it..
Edited by Gregory
― Jimmy Buffett
