HMS Pegasus by The_bitter_end - Victory Models - 1:64 scale
Good Evening All
This is not the most positive way to start a build log but I guess it was to be expected for a newbie like myself.
So I have finally received my HMS Pegasus from Amati. The box is barely open and I already have problems.
This would be a great point to recommend a build log or other resource for this build. I have found many but Im struggling on that covers the finer details that a rookie like myself needs.
The instructions make no reference to a rabbet or bearding line, I have however come across reference to this in virtually every single build log that I have read on the vessel. My extreme lack of experience has lead me to several questions regarding these two subjects.
1. Rabbet line:
- Am I correct in saying that they should be cut from the very bow to the very stern(excluding the vertical portion of the stern as indicated between the red arrows)
-Should this line be cut 1.5mm "tall" and 1.25mm "deep" on either side of the false keel?
-Do I need to sand the true keel down from 5mm to 2.5mm to match the width of the false keel after being cut down for the rabbet line?(this doesn's seem to make a hue amount of sense but it seems like this is what some people have done on some of the photos that I have seen.
2. Bearding line:
- how do I determine where to draw the bearding line?
- should the false keel be tapered evenly from the bearding line down to the rabbet line?
- the instructions say "the stern area of the false keel to which the rudder post will be glued is to be sanded to roughly half the original width" does this essentially mean that I should sand from the bearding line to the vertical portion of the stern as well as the rabbet line(so that it tapers to the edge of the keel both vertically and horizontally?)
Thanks a million in advance!
Link to comment
Share on other sites
Hi, look at your plan on framing it will tell you where the beading line starts to where the it will end at the rabbet
Drawing just to show you what I mean
I used tracing paper and traced the shape then relaid it to my frame, on my model the keel is part of the frame, do you have to add the keel on yours
You shape from the beading line down to the rabbet, rabbet depth will be the thickness of your plank
Hope this makes sense
Regards
Richard
Link to comment
Regards
Richard
Hi Richard
Thank you so much for your response. This now makes perfect sense.
The only problem is that I have is that the plans fail to indicate either a bearding or rabbet line.
Is it appropriate to just run the bearding line right below the lowest point of the frames?
Link to comment
34 minutes ago, The_bitter_end said:
Hi Richard
That is a bummer
The bearding line starts right below lowest point of  all frames (bulkheads) you are correct but you have to make sure all frames are smooth from one to the other if you look at my frames they did not hit the bearding line so I had to build up face of frames (bulkheads) because if you don't planking will be up and down, trial fit your b so you can see where.
Do you have to glue the keel to the bottom of your center piece?
Regards
Richard
Link to comment
5 minutes ago, Retired guy said:
That is a bummer
Regards
Richard
It is a bummer indeed haha
I will pay careful attention to the framing. That is going to be a whole other challenge.
Yes, I do have to glue what they referto as a "true keel" onto the edge of the false keel
Link to comment
Hi Haiko,
Looks like the SAPO came through after all, hope the customs duties wasn't too rough!
I have come across two build logs that have reference to the rabbet and bearding process, hope it helps:
HMS Pegasus by SkipW - Amati/Victory Models - Scale 1:64
HMS Pegasus by Landlubber Mike - Amati/Victory Models - Scale 1:64
Link to comment
No rabbet, like almost all European kits, Pegasus is double planked. Most US kits are single planked, which allow for a rabbet. There are patterns that glue to what would be the rabbet positions. A proper rabbet would not work so well with double planked kits, as the first planking would most likely take up all of the space in the rabbet slot, due to the angles and bevels involved.
Link to comment
6 hours ago, Jolley Roger said:
Hi Haiko,
Hi again!
Customs duty ended up being zero Rand. I only had to pay 15% VAT, which seems fair seeing as I didn't pay tax in Europe
Thanks for getting those links for me. I will be bookmarking both and going through them in fine detail immediately.
Link to comment
Hi Chris
Thanks for your input! I feel like you might be right about this. What does however confuse me is why the likes of SkipW, Blue Ensign and Landlubber Mike went for the rabbet line. I am totally new to this so I dont know if that is just a design choice or if there is a "correct" way.
EDIT- I just found out that you designed this model. I find myself quite amused by what Just happened "you MIGHT be right Chris" 😂😂
😂😂 sorry about that. No further questions.
Cheers, Haiko
Edited by The_bitter_end
I just found out that Chris is probably fairly well informed on this subject
Link to comment
Day 2 updates and questions.
Progress is very slow but I am really enjoying finding my feet.
I have cut the rabbet(1.5mm "high" and 1.2mm "deep", leaving a strip of untouched wood down the middle of the false keel 2.5mm wide) and marked the bearding lines(just a fraction below the bottom edge of the last 3 bulkheads) and Pre-fitted the bulkheads. this leads me to my questions for the day.
Do the Rabbet lines in the photos below look correct? I cut the rabbet lines at a 90 degree angle but I see some examples(like in the example so kindly posted by Richard above) where they are cut away at a slope.
I realise that I still need to taper the stern from the bearding line to the edge of the false keel(I hope that's correct)
My second and third questions are as follows. Is the bearding line marked correctly? Do i need to cut back the lower edges of the bulkheads so that they follow the same contour as the bearding line?1824010124_Beardingline.jpg.2a4b1aec8bb0d801653587b4c08a06d3.jpg
I realised I had missed out a question that is relevant to this post
Link to comment
Chris is right - he designed the kit !!
 Just initial points - if you are going to copper her then it is pointless getting too wrapped up in the rabbet along the main keel
The bottom of the bulk heads should be shaped  -  I mark the edges of the bulk heads for the 4 or 5 BHs fore and aft along the edge facing midships and shape to just leave that edge untouched
Sort your fixing points out !!
There are two main things I would suggest about  Pegasus  here ( and Fly of course is identical)
My log pegasus log  Shows this though most of the log was lost
 But My pickle log  https://modelshipworld.com/topic/8650-hm-schooner-pickle-by-spyglass-caldercraft-164-scale/?do=findComment&comment=267216
Covers the ground illustrating with some pics of Pegasus
1 Its really handy to create a "rabbet" at the stem - it really helps when planking. You create a false rabbet by chamferring the fore edge of the keel and then the extra keel bit completes the rabbet - but need a rabbet across the "tongue"and top section
2 But getting the stern shaping right makes life sooooo much easier .
The main issue is bring two planking layers into the stern post -  dont try  - chamfer in the first layer  before  reaching the edge of the keel  and LOOK how steep an angle the aft Bulkhead edges need to be
Edited by SpyGlass
Link to comment
Considering its your first model, I wouldnt get stuck on extra details like that. Just follow the instructions and put the bulkheads into the frams and start the first layer of planking. You will learn as you go along and when you do your next kit you can start trying to raise the level of quality.
Link to comment
Good Morning Spygalss!(it is 0504 here)
This is all starting to make sense. And I am genuinely warmed by the willingness of this community to help me. The detail you have put into this respose makes all the difference. THANK YOU!
I do still have a couple of questions, which I hope you font mind answering. I know exactly what you are saying about the fact that I should be too worried about the rabbet as I am going to be coppering the Hull anyway. However I really want to get every single step as perfect as possible so I can learn for future projects. I am in no rush to get finished. I am a very patient man and I live in a very remote place with not much to do after the sun goes down.
1. I think I understand what you mean about leaving the one edge untouched on the bulkhead but how do you determine how much to take off on the other edge?is this just something that you eyeball as you go along?
2. What do you mean by "sort your fixing points out? are you referring to the contact surface between the first layer of planking and the bulkhead section?
3. I notice that you cut the rabbet for the stem at slope and not at 90 degrees(i dont know if this makes sense?) By the time I read this post I had already cut a rabbet at 90 degrees on the false keel should I cut it back to a slope? I know that I was probably not meant to cut a Rabbet at all but I have sort of crossed that bridge already.
4. Thanks again for that tip on bringing the first planking up the the bearding line on the stern. Am I correct in saying that these planks just get sanded so that they taper smoothly to the false keel?
Regards
Haiko
Link to comment
Hi Vane
Thank you for your message. I cant really argue with you on this, you are totally right. I will however try and explain my somewhat poor logic....I want to try and really focus on very tiny detail on this build, even the things that dont really matter or wont be seen so that I can get maximum training value out of this for future builds that are more complex. I may well end up following your advice when I realise just what ive bitten off but for now im going to be as German as possible about this process.
Link to comment
Day 3 (morning)
I have now tried to take on as much advice as possible(bar the mistakes Ive already made...sorry Chris)
I have sanded down from the bearding line to the stern. I am not entirely sure if this is a sufficient amount of sanding. I am erring on the side of caution at the moment and i just sanded down to the rabbet line that I cut at the stern which was 1.2mm deep on both sides.
I also cut the groove suggested into the stem. Again I am not sure if this is correct. Please advise if you have any input.
Link to comment
Bitter end your numberd questions  = quick and messy reply i have terrible internet
1 Eventully when they are mounted you use a planking strip to check the curve of the hull over the bulkhead and sand/ shave
But i do a fair amount before gluing the bulk heads I mount them  unglued with decks ect to hold them fairly firm
Then using one of the long " stanley knife - style break off blades"  trim the edge of the buklhead of holding the blade equidstant from the BHs before and after its not accurate byt gets a lot of the initial stuff off
2 fixing points  I should have said mounting points - i drill and fit for threaded rods to mount onto pedestal
3 i cut the rabbet so the plank could lie into it  -same applies to edges of all rabbetss they are not square cut
4 yes - technically i suppose the bearding limne rusa sling the bottom of the bulkhead - cutting off teh corners  for and aft
 I actually bring the planking to a point halfway  roughly between that bearding line and the keel edges and indeed then just smooth it in so you get a run onto the thinning bit of the keel
Link to comment
6 hours ago, SpyGlass said:
Yea that looks right  At the stem just take the stern edge of the keel down to just a bit over the stern post less two second planking thicknesses so that you just end up with the second planking jussst a teeny bit proud of thestern post and you can sand those strips flush
Well Explained!
Link to comment
Good morning Mr. Glass!
Perfect explanations again. I came close to doing all this correctly as you will see in my next post. I just need to modify my rabbet somewhat to take away the 90 degree corner.
thanks, Haiko
Link to comment
Day 3 (Evening)
At this point I faired the bulkheads.
Predominantly bulkheads 1 to 4 and 10-13. I did this by dry fitting all bulkheads and then removing and shaping one at a time(repeatedly) until i got a reasonably tapered angle for the planking. I suspect there will be some modification as I go. In addition to this I also sanded all the laser cut surfaces a small amount to allow better glue adhesion.
I then dry fitted the lower deck. My suggestion to a newbie like myself at this stage is to clean up and sand all mating surfaces as best as possible. I found it to be a hang of a tight fit. After cleaning it up a bit the deck went in somewhat more easily. However once I was satisfied with everything and I had glued the bulkheads in and started to fit the deck things got somewhat panicky because I was really struggling to get the lower deck in and the glue was starting to dry....SO...make sure that everything goes together without effort or you may regret it.
Another minor observation is that I fitted and glued bulkheads 3-10 first, then seated and glued the lower deck. I found this to allow me just a little more space to work on the lower deck and then fitted the remaining bulkheads.
The plan for this morning is to tidy up the work a bit and fit and shape the "plank termination" pieces as far as possible
This is the progress so far, excuse the rather odd keel clamp. It looks strange but works a charm. PLEASE tell me if you see something wrong here, Even the smallest detail. I am here to learn.
1554218848_SternFared.jpg.b16c416c0f73d822c248f4e250067b9b.jpg1865284675_Bowfared.jpg.ae900e429ba7b1183fdb10493ec1acb0.jpg606938199_Bulkheads-fared.jpg.198bc760fafb0d0f0eeb05018c45ad03.jpg
PS. I realise that my Rabbet lines need some correction But I have decided to attend to this as I begin planking. I suspect that the rabbet is a somewhat "fluid" structure which in some places was not needed at all(particularly on the keel in the bearding area(i think)), some places where it should remain cut at 90 degrees and some places where it should taper in at a currently unknown angle. ...
Link to comment
Thats not at all bad - i think you will need a bit more fairing at stem and stern BHs - i try to ens up with just a trace line of marker on the ulk head.s  Oh I forgtot to add my oterh good tip use the deck or even the deck offcut as a guide to the amount need to be take off the BHs - if you have the deck fitted - temporarilly or permamnently then you can eyeball the angle neded on the BH from above to match the deck edge.
If i remember one of the BHS towards the stern is a teeny bit proud of the run at bulwark level - run a strip along to check the lie .
Oh and its a good time to at least rough shape the blocks in between the end  fore  and aft bulkheads-
I temporary fit them buy positioning and running a drill  through boh and use a drill bit as a dowel, Then you can mark on the block the curve on the " unchamfered" edge of the bulkhead which is a wonderful guide to shaping the block
great  progress
if you havent glued  yet - or even if you have - NOW is the time to decide your mounting  method and position
Edited by SpyGlass
Link to comment
12 hours ago, Vane said:
If you want to do a very detailed and high quality model, my number one tip is to buy alot of sandpaper and really use it everywhere on every piece on every side and make sure perfect fits.
Hi Vane
Thank you for taking the time to give me this advice. I will follow it as far as humanely possible. I have a pile of 600,1000 and 1200 grit paper that I will put to good use. Keep an eye on this build and hopefully you will see improved surface condition from now on.
Link to comment
great  progress
Hi again Spy
I took you advice and did quite a bit more fairing, particularly on bulkheads 1, 2 and 3 using the negative of the deck sheet to guide me. That was a great suggestion.
I took a look at what you said and you are entirely correct. BHS No. 9 is about 1mm higher than the rest. I will be attending to this tomorrow morning once the evenings glue has dried.
I also shaped the blocked now as suggested...a pretty challenging task. I think I will need to make further changes to their profile as I begin planking. I am having a really hard time visualizing exactly how planking will lie so I dont want to make any changes I cat fix just yet.
Is there somewhere specific that I can look at mounting methods? I didn't consider it AT ALL.
Thank you for your encouragement and patience. It is hugely appreciated.
Link to comment
You are making good progress.
As Spyglass says, make sure you fair the bulkheads well, Use a strip of the planking and hold it against the bulkheads and you will see where more fairing is needed to get a nice smooth curve. The more time you spend here getting the shaping right, the easier it will be later on in the planking.
Edit: You might find adding some balsa in between the fore and aft bulkheads will help when planking.
Edited by vulcanbomber
Update
Link to comment
Mounting sort of fall into two categories
A cradle of some type where the model just sits in and that can take many forms
Or a pedestal mounting which needs to be fixed to the vessel.
Some people put screws into the keel
I use bolts or threaded rod which has advantages i find
BUT it must be done early in the build preferably f before any gluing is done but can be done any time befor first planking
I drill and reinforce holes for the rod or bolts and fit in captive nuts see my logs for more detail
eg https://modelshipworld.com/topic/8650-hm-schooner-pickle-by-spyglass-caldercraft-164-scale/?do=findComment&comment=267216
and
https://modelshipworld.com/topic/420-hms-pegasus-by-simonthepieman-victory-models-164-started-by-spyglass/?do=findComment&comment=4702
REMEMBER to at least temporarily fix the walnut keels bits before drilling the mounting holes - its MURDER tryin to line them up later !!
On a related subject I use temporary dowels to hold stem, stern and keel pieces in place . and if you do that you find the stand fixings can be used to hold the walniut keel bits in place/
You might like to try it. I do it mainly to be able to  take off the walnut bits to enable free sanding of the hull without damage to those bits
Edited by SpyGlass
Link to comment
Hi Vulcan!
Thanks for the encouragement. Funnily enough my first question for the day was going to be about the balsa between bulkheads. You have answered my question for me. I will begin with that this morning after my post. I think it will also give me a better idea if my fairing is correct.
cheers
Haiko
Link to comment
and
Hi again Spy
As much as I like the look of the mounts you did I think for a first build it is best that I don't complicate things too much and I just go with the cradle option, this is mostly because Im a complete newbie and Ive already glued the bulkhead pieces in place. . I will definitely do this for my next build.
I will however take your advice on pre-pinning the keel portions in place once I have sorted this balsa issue out.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
