I'm loving it!    I'm still slogging through the first planking.  It looks beautiful so far.
I'm playing with the idea of backdating mine to the age of crows feet, because I see many a 28, 36, and 44 in my future....
Carry on, Sir!!   It's looking bloody marvelous.  Sir Glenmorangie says so hisself, he does.
On the bench:  Vanguard Models 1/64 HMS Speedy
On Deck:
Vanguard Models 1/64 Zulu,
Vanguard Models 1/64 Fifie,
Victory Models 1/72 HMS Bellerophon
Looking really good Glenn. I’m sure you’re right to fit the gaff and boom first.
Derek
Cheers, Derek
Current build:   Duchess of Kingston
On hold:              HMS Winchelsea
Previous builds:  HMS SpeedyEnglish Pinnace, Royal Yacht Caroline (gallery),
                            Victory Cross-section (gallery), US Clipper Albatros, Red Dragon (years ago!)
On the stocks:    18th Century Longboat
My progress is slow at the moment. I have finally installed both the rudder and the main mast so today I started work on adding the boom prior to fitting the shrouds.
As can be seen from the plan sheet there is a nice double block assembly required for the boom topping lift.
This took a little bit of time and effort to get the loops on the blocks, but it was not as difficult as I first feared and the boom was fitted and the topping lift added without to many problems. I just need to finish off belaying the drop. I have positioned it around the belaying pin, but I needed to take a break so will come back to it tomorrow to finish it off and add the other boom rigging. I will also add and rig the gaff in the next few days before I start work on the main mast shrouds.
65609171_227BoomFittedBelyaingstillrequired.thumb.jpg.4501fef289d98950e9c2a4d4ddc1f49d.jpg
I realised that I had not fitted the cleats to the stern patterns so it was a bit tricky drilling the holes with the tiller and cannons in situ, but I took my time and managed it without incident.
Glenn (UK)
I have now finished adding the boom and gaff. I did have to redo the boom because I made a fundamental rigging error with the boom topping lift rigging, as I took it through the wrong double block on the main mast.
I did find it difficult threading the 0.25mm natural thread through the 3mm single blocks even when the end was hardened with ca, but eventually found a workable solution.
As I have said before I'm not very good at rigging, or taking photo's but I'm getting a bit better at the rigging.
1022802333_228BoomandGaff.thumb.jpg.c8e3e873edf7be2c59f9cccfb867a631.jpg775335182_229Boom.thumb.jpg.4ac8b7cc2e62e6bb820e5d2a383a3a05.jpg1220106805_230Boom.thumb.jpg.dd90c9ff5287e53750efcae490591dfb.jpg70634753_231Boom.thumb.jpg.40fc12079651f132c88389484632c734.jpg1631024155_232Gaff.thumb.jpg.9f0b080e1d96fb2ebb916eb8038d4014.jpg
Glenn (UK)
Quote
What was your solution ? I hope to build the "Flirt" as my next project.
Richard
Richard
Current build :  Victory cross section / DeAgostini, Lady Eleanor  Vanguard Models
Other builds :   N scale computer controlled model railroad
Richard
I taper the edge of the thread but cutting at approx. 45 degrees across the thread which really helps. I normally run a 0.6mm micro drill through the 3mm block holes which seems OK for the most part but I have increased the micro drill bit size to 0.7mm when the thread is 0.25mm which seems to have done the trick.
Glenn (UK)
I have not done an update for a while. I have decided to take a different approach and I plan to only part rig the build. The rigging instructions are very easy to follow but with my poor near vision, and my extra large hands I'm been finding it a challenge.
Also I have a new project starting shortly with a 1 / 250 scale build of the Yamato.
20200705_183135.thumb.jpg.2d319d107b49d039a04821db2a8e53cd.jpg20200705_183212.thumb.jpg.81b883657ac656c2e3fbe13d10eb4f8b.jpg20200705_183308.thumb.jpg.30ce0fa233427cdd7e23b363f0ab3ea9.jpg20200705_183409.thumb.jpg.8b0b0f64c1fe1b55f59523a15d956472.jpg
Glenn (UK)
9 hours ago, glbarlow said:
How is your Speedy coming along?
Hi, I have partial rigged Speedy. I have really enjoyed the build of a very well design product but I have no plans to carry on further as I have a commission build project to undertake for a close friend.
Glenn (UK)
  • 2 months later...
