At this point of time i have measuered 7 full planks down to the wales. Under the wales I've planned the first spilled plank. As per Chris picture post.
Got it marked out on the hull and test bent some planks to see the lie of them.
At this stage no clinkering out so could be on a winner? We shall see..
Regards, Scott
Completed builds:
Awaiting construction:
Strips are way to damn thin! I knew it would be difficult but not this bad. Sorry guys but it might take some time to get right. Try and update soon.
cheers to the guys who chipped in. Obviously something I didn’t know before was the hull can be planked two ways. I’ve gone with the replica version.
All your feedback is appreciated. Thanks.
Regards, Scott
Completed builds:
The first few planks laid down. The slightest curve and the top edge wants to kick out. Using drawing pins to clamp planks down so I have no holes.
It’s tedious work but I think I’m winning. What do you think? Look ok?
Regards, Scott
Completed builds:
Sorry photos taken off my tablet and are not the best
Regards, Scott
Completed builds:
1 hour ago, Cabbie said:
Looks very good to me, no gaps, as long as you keep the planks tight to the ship should be ok.
I use contact glue a lot for my planking, goes and stays on, but you have to be right first time.
Thicker strips take a lot more work to go around the bow.
I'll be honest, I used a little bit just to hold the plank until the tightbond PVA took hold. 😁
Regards, Scott
Completed builds:
Time for another update. Better pic quality this time. Continuing on down the sides with last layer. Coming to the tricky part now. Hope you all like so far.
Regards, Scott
Completed builds:
don't forget they put a coat of deal planking on top of the original hull strakes to combat ship worm along with crushed glass and white lead- they have most likely recreated that hence the run of the planking looking wrong.
Don't worry guys. Im still building.  Slowly getting it done.  I've gone down the path of the planks termination at the stem. Actualy working out great. Mapping each plank for fitting and the lie of it. Checking and re checking.
Regards, Scott
Completed builds:
32 minutes ago, Jeff-E said:
Looking very neat , Scott, keep it up
Thank you very much.  Glad you like it.
Regards, Scott
Completed builds:
I want to paint the hull an off white colour with the yellow orcre bands on the top. But we'll wait and see how my planking job turns out. I might just want the wood colour yet.
Im affraid the exposed unpainted section of wood will be too dark.
Regards, Scott
Completed builds:
Hey all. Some more work has been done and progress is good.  Finished planking the hull below the wales and added the stem post, keel and about to add the stern post.
One rubbing strake has yet to be added about two plank rows above the wales.
This whole thing needs a good sand very carefully because the veneer strips are only 1mm thick. Some touch ups to do but im pleased with it so far. Hope you enjoy.
Regards, Scott
Completed builds:
46 minutes ago, Cabbie said:
Looking very nice and neat Scott, doesn't look like there were any problems shaping the planks
Cheers mate. Well, No it dosnt look like it surprisingly but trust me about 14 different languages were spoken during the course of it.
Regards, Scott
Completed builds:
5 hours ago, Jeff-E said:
Very neat planking job Scott, those thin planks can be awkward to get them to lay as you would like them to.
Thank you very much. Your not wrong. I like big thick planks, also gives you some wiggle room when it comes to sanding afterwards.
Regards, Scott
Completed builds:
Update time. The counter planked up and the waist rubbing strakes on. Next up is the gunwales and so on. Pleased how its turned out so far
Regards, Scott
Completed builds:
Stern windows this time! The kit supplys you with the unsightly metal cast windows which i defiantly wont be using. So instead om making my own out of 1mm×1mm stock and then make my own glass for them.
Regards, Scott
Completed builds:
The glass came out really nice i think. Nice little bit of scratch building.
Regards, Scott
Completed builds:
Finaly got some colour on to her. Happy with the result so far.
Regards, Scott
Completed builds:
The glass turned out really well, I will definitely order some. The painting looks great too!
Cheers. Yes it works great. Takes a while to dry but it is worth it. A few touch ups on the paint and it should look good.
Regards, Scott
Completed builds:
Stern assembly time. The ornaments on top came in the form of a slab of metal. Painted the recessed areas blue then applied brass paint on the protruding areas. Im happy with the outcome. Strips above and below windows added as well.
Regards, Scott
Completed builds:
Okay so... More gastly chunks of metal. I decided to drill out the material where the glass should be and add my own glass. Trying to jazz them up abit.
From photos the deadlights are red and I decided to include them. Might just have to go a touch darker red on them but we'll see.
Regards, Scott
Completed builds:
I think it looks good. Or is the window on too much of a slant?
Regards, Scott
Completed builds:
