US Brig Syren by captgino - Model Shipways - scale: 1:64
Hi all,
As my Rattlesnake will likely take a while, I decided to work on a kit at the same time. I was recently given a already started Syren. Sweet gift 😊!!
Some much beautiful models on this forum, I will try to do it justice. Here is the current state.
Jean-Philippe (JP)
Current build: SyrenRattlesnake (Scratch built)
:dancetl6:Please visit and subscribe to my YouTube Channel
On Hold: MayflowerHMS Victory Cross Section
Completed:   Armed Virginia Sloop, Viking ship,  The Flyer, Pilot BoatKrabbenkutterMarie-JeanneSloup, The Smasher
Link to comment
Share on other sites
Reviewed the documentation and plan.
I have a few items to correct.
Bearding line missing on one side.
Small adjustments for the deck, some of the blocks are a bit too. high. 15878800184723746050397996636092.thumb.jpg.70b00c7d44403ac95c61605fa1d9b013.jpg
Sills and Lintels all over the place.
20200425_223417.thumb.jpg.1ebe3ec24035354cc3978422301e834a.jpg20200425_223347.thumb.jpg.f2b837ec1819d2851637079825aea785.jpg
Stem was over sanded on one side or miss aligned.
I am getting to take it appart and correct as much as possible these issues.
Jean-Philippe (JP)
Link to comment
Deconstruction process. :P
Numbering and removing Sills and Lintels.20200425_223019.thumb.jpg.a3a0dbd2548bbf2f5ca27a7ca81c2535.jpg20200427_211109.thumb.jpg.e88110ad4334676f9b3a1da08d64bcb8.jpg20200427_210503.thumb.jpg.97002289221dbdb465b62382bfe35b7a.jpg
Removed the Stem. I will need to rebuild from scratch.
And of course repairing the broken frame stems
I also remove the keel and rabbet strip since they were damaged during my attempt to add the bearding line.
Edited by captgino
Jean-Philippe (JP)
Link to comment
Getting crafty to hold the ship reversed.
Worked on the Bearding line quite a bit last night to be able to meet with the 3/32 rabbet strip. The previous one was 1/8 so a lot to catch up to.
And... Disaster the strip broke as I was putting rubber bands. To be expected when passing the bulkheads... Grrr. Here the result after fitting the strip on the stern. It will cover by copper so it will not be seen. 20200429_223520.thumb.jpg.3b9bd7986533d0c86b80b09ed90a7bb4.jpg
Dry fitting the new keel and the old stem20200429_225827.thumb.jpg.57fa91da2102bacdd373c22e3bbec83e.jpg
Stem needs to be redone from scratch. It was faired too much and unevenly. 20200429_233229.thumb.jpg.ab46c822079552bb49447c6aead0332e.jpg
Draft stem design. Thoughts ? 20200430_000047.thumb.jpg.56eb1a101a299d3ceb2fa9291af1554f.jpg
Edited by captgino
Jean-Philippe (JP)
Link to comment
Productive weekend, from design to reality...
20200503_213831.thumb.jpg.ac728063c82899055322ca48c8277aa4.jpg20200503_213250.thumb.jpg.227d2bee092b19cf68e10ba9cbeb0a60.jpg it was not easy and I broke a few parts. 🤪
Next step :drilling the holes and glue up.
Jean-Philippe (JP)
Link to comment
Video production of the stem.
Part 1
Part 2
Jean-Philippe (JP)
Link to comment
The deconstruction continues on my Syren. I noticed a few issues with frame adjustments. Here is what my survey outlined.
The second and third frames from the stern were too high, resulting into a 1/16 gap between the top of the frame and the center 'spine'. See the red marks below.Inked20200510_204517_LI.thumb.jpg.da9ea3b93922f8ea6b2ffc5dd8b0de9d.jpgInked20200510_205044_LI.thumb.jpg.9542e0ec21415031f32e00c125b1233c.jpg
The solution was to remove them and the blocks surrounding them and push them down. I had a similar situation in the bow (see below). I was able to use a thin strip to provide a smooth transition across all frames for the deck planking.
Deconstruction madness in pictures. :)
Since the frames were glued with white glue, I used Acetone to soften the glue and a few tools to remove them. Time for your shot!20200510_224307.thumb.jpg.9d1ddbfd65c36b7f23ada3d84ae8588f.jpg
Removal frame 2.
Dry fitting frame 2.
Drama with frame 3. The doctor is busy. LOL....
Dry fitting line with frame 2 and 3. MUCH BETTER !!!
Gluing and rehabilitation.
109919318_20200511_2337371.thumb.jpg.b0ffd603af395f3b5a1cd9d54d884b63.jpg1395483083_20200511_2355581.thumb.jpg.ec498d6c9e5c3dffda28ff35750e3efe.jpg
Edited by captgino
Jean-Philippe (JP)
Link to comment
Glued up the stem. It took quite a bit of time to adjust each piece to fit as perfectly as possible together20200519_201833.thumb.jpg.b61fdb5eef4f8ccff458aa20bf9e0f3a.jpg20200519_201847.thumb.jpg.15b4e3f7050bab6aa6f6c95ce9a4a484.jpg20200519_211801.thumb.jpg.6f5c0dcaf875954cec5a4907fc5c97cf.jpg20200519_221310.thumb.jpg.ddf388ff27de03ef4c1cc0d346ed9d80.jpg20200519_221324.thumb.jpg.408c3dad33d2af58f5226aa6e4303d3f.jpg
Here is the final result.
Jean-Philippe (JP)
Link to comment
If you would like to see a video for the stem glue up. Check out the latest installment of building the Model Shipways Syren on YouTube.
Jean-Philippe (JP)
Link to comment
Finished attaching the Sills and Lintels.
Jean-Philippe (JP)
Link to comment
Jean-Philippe (JP)
Link to comment
Worked on reattaching the new stem. Here is the result.
Jean-Philippe (JP)
Link to comment
Here is the video of these activities :)
Jean-Philippe (JP)
Link to comment
I really like the videos! There aren't many build videos on YouTube so I wish I started my Syren after you, would have helped a lot in visualizing the steps 😄
Current:
USF Confederacy - Model Shipways (Build Log)
HMS Pickle - Caldercraft (Build Log)
Complete:
Virgina 1819 - Artesania Latina (Gallery)
U.S. Brig Syren - Model Shipways (Build Log, Gallery)
On the shelf:
Armed Virginia Sloop - Model Shipways
Link to comment
Ha. Well I am far from been the expert so I will follow your build and you can help me 😊
Jean-Philippe (JP)
Link to comment
Shaping the Sills and Lintels for the gun ports.
Jean-Philippe (JP)
Link to comment
Working on finishing up the framing of the gun ports. Here are some pictures.
20200613_165529.thumb.jpg.de0bd8bd00de900e7cf19704a2ccfae1.jpg20200613_165611.thumb.jpg.b36b94521a32da723d4232ffde2c4efc.jpg
And the video of the process.
Jean-Philippe (JP)
Link to comment
Framing the stern part started.
Fairly challenging process to get the exact position of the gun ports.
20200614_073825.thumb.jpg.6b559ce0284173202069759e318fd10d.jpg20200614_073850.thumb.jpg.95d3147325addb74081ee863df07c3c8.jpg20200615_224854_MOD.thumb.jpg.e3d7c3821b29ec12540a8ad5d1e6cd68.jpg
Jean-Philippe (JP)
Link to comment
Here is the video of these activities.
Jean-Philippe (JP)
Link to comment
Worked on finishing up the stern shaping and sanding.
Jean-Philippe (JP)
Link to comment
Jean-Philippe (JP)
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
