Hello Gents!
Got a sweet deal on a Proxxon DB250 wood lathe, so I pulled the trigger on this unit with the 3 jaw chuck while I save up for a Sherline (which you guys really sold me!).
Are there any tips/tricks/mods that can be performed to improve function/added value?  Would love to see what you guys can come up with...  already saw a stainless steel mod for the tool rest, so this one seems a no brainer to perform...  bugger, more stable tool rest.
Please, let me know what can be done to improve the unit.
Thanks!
Jorge
20 minutes ago, bartley said:
The 250 mm  center distance can be limiting.  For example the bowspit on my Cheerful is 310.  So I have the extension table which allows me to turn longer pieces such as masts.
John
I did notice that there is an extension available, but I have only seen it in Australia; I have searched multiple time/ways, but I havent been able to find it anywhere in US...
Thanks!
Jorge
I brought a second bed direct from Proxxon (Code 27020-31) and mounted it and the lath end-on-end on some MDF. The bed cost €14.30 (+ postage) a couple of months ago, try your Proxxon dealer to see if they supply spares. Obviously not as good as a single piece extended bed, but it does the same job.
Gary
As for all lathes, collets are basically a must (also from a safety perspective), when you are working with smaller diameter pieces. However, I think the lathe normally comes with collets, doesn't it ?
@obsidean12: why do you have a a three-jaw chuck in the tailstock ? I hope it is a free-spinning one ...
For most ship modelling purposes a long bed lathe is not essential. Yes, for small objects such as deadeyes, turned stanchions, cannon and those kind of items a precision lathe with collets is great. However, I've never understood the need to turn masts and yards or other long pieces. The shipwrights' method in miniature works just fine. Cut the spar four-square, then eight-square and finally round it off using sandpaper strips works just fine!
Druxey, I think it depends also on the diameter you have to work with. If your spars are only two or three mm in diameter at the end, it may be rather difficult to employ the classical method. For this you would need to make yourself jigs to hold the material while applying the plane or offering it up to the circular saw.
Jorge
I would be interested in seeing the info on the S/S mod for the tool rest. I also have a DB-250.
Thanks,
Hank
Construction Underway:
Builder's Yard - USS STODDARD (DD-566) 1967-68 Configuration (Revell 1:144 FLETCHER - bashed)
In Development - T2 or T3 Fleet Oil Tanker (1:144 Scratch Build Model) - 1950s era
Currently - 3D Design/Printed 1/200 scale USS PURITAN (BM-1)
Completed:
Armed Virginia Sloop (1768)
Royal Caroline (1748)
Sloop/Ship PEACOCK (1813) (Scratchbuilt)
USS NEW JERSEY (BB-62) 1967-69 Configuration (Trumpeter 1:200 bashed MISSOURI)
3D Design/Printed various scale USN Gun Mounts/Turrets, and GFCS Directors
Member:
New Bern Ship Modeler's Guild
NRG
NCMM Beaufort -CSMA
Obsidean: Chacun à son gout - we each have our own preference, and that's OK.
Wefalck: I always use jigs for planing (actually I use chisels, bevel down) and can 'turn' to very small diameters when well supported.
Gary
Found it and ordered, so will be waiting for the same later in July/August (out of stock, and ordered from Germany).
Thanks!
jorge
If I were already saving for a replacement, I wouldn't look to improve or upgrade.  I would put my time into learning to use the tools so I was ready when the Sherline came along.
R
Richard
Member: The Nautical Research Guild
R
Small improvements always help as well.  For what I purchased tHe unit, I can do a couple Fixes/improvements, and still be under the new price.
Got it from a widow that can’t stand to see her husband’s hobby stuff in the house.  New, in the box, for $100.  Seems he never got to use it, as all the manuals are there, and the chuck in the original package as well.  Got a kit as well during the visit.
