Rob, thanks for the update on your progress. It won't be long before we're seeing yard arms too. It's still so uncanny how much your model mimics images of the actual vessel herself.
lovely to catch up on the build again, stunning work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Thanks everyone, for the fine comments.
I hope to finish up the mizzenmast mast today…….then I’ll move onto fixing the chain slings and prepping for shrouds.
Rob
Current build:
Finished build:
Current build(On hold):
I did a bit of minor work on the masts.  Banding and adding the chain hoists.
This kind of work takes time since making and blackening eye bolts takes time.
Rob
Current build:
Finished build:
6 hours ago, Vladimir_Wairoa said:
nice clean work Rob as alwyas. one question guys.
I believe glory didint carry stunsl sails and therefore her yard arms didnt have eyes for it , correct? or ? thanks much. Vlad
Vladimir, actually Glory did in fact originally carry a full set of Stuns'ls. By 1877 when Rob is modeling her, apparently those booms had been removed.
Thank everyone for the fine comments.
Sometime prior to her 1877 San Fran image she relinquished her stunn sail booms. Probably because she became a West coast carrier, rarely going far South and not rounding the Horn any more.  Accommodating doldrums was no longer going to be a burden for her.   The true reason stun sails are carried.
Honestly, I’ve spent more time lately, planning the addition of the futtock shrouds and their dead eyes to actually be doing any work on Glory.
I did add the bell and bell arm to the forecastle leading edge.   Not much
Rob
Edited by rwiederrich
Current build:
Finished build:
10 hours ago, Vladimir_Wairoa said:
Thanks much folks. Stun sails be it then on mine too. my gosh :) V.
I've been meaning to ask you Vlad.......what was the factor that caused you to change your mind and go ahead and finish your version of Glory?
I also saw that you are working on her bowsprit and jibboom as well.  Nice to see your efforts again.  Your 1/72 version will truly be a big model.
Glad you're back in the shipyard.
Rob
Current build:
Finished build:
Rob
I realised its a pitiful slight on her without All that tall splendor, and taking advantage of scale i Can to the detail Ed portrayed on young America. Not his quality of course but i have place to learn Few tricks from there and from you od course. :) Ill be updating here and there so stay tuned  ..v.
I too originally intended to only make my (Original) Glory....the one this thread started with....a simple hull model, but as you say....it would leave Glory a pitiful shadow of what she really is.   Your scale does slightly afford you with a bit larger and *easier, to make, I would assume(NOT) rigging and accessories.
I fully agree....EdT's Young America is a great example to mimic...and the plethora of images available on his thread...are a builders blessing.
A couple of good rigging books might help and surely Michael Mjelde's second book will aid in rigging her by using his drawings as reference.
Currently, I am planning and thinking out my process for making the futtock shrouds and their connection to the lower top deadeyes.  I do things unothodoxical, so too keep things simple and highly repeatable.   I'm remembering and refreshing my thoughts as to what  I did for the Great Republic.
I'll duplicate the  technique I used then.   I've got to clean up and prep a lot of deadeyes and strop them first.
Rob
Current build:
Finished build:
Rob
Rob i look fwd much to see your style in place. with all that paper sails etc. i will not hesitate to ask for advice or help if needed sure.  As for my progress atm im enormously enthusiastic as im doing soemthing new. and more importantly after rigging 1:24 cutty, i was soldering everything and i dont need so far - so  im  enjoying it so far. im far from rigging,  but following Eds gigantic show helps as well as flying fish rigging masting plans i observe. everything is explained there. i started untypically with yards :) than making masts and probably next winter rigging. but with me it is - one never knows :))) so with grain of salt :D but even installing wholebowsprit itself changed her enormously. did i mention im not going with composite masting? i take hat off of sou guys but i am not good at it - never made one . thats why. i dont wsnt to spoil it all.  when i see your masts i just clap hands with outcome and effort that was made. v.
Edited by Vladimir_Wairoa
add
Worked on the mizzenmast  futtock shrouds and deadeyes.
Rob
Current build:
Finished build:
Couple more.
Rob
Current build:
Finished build:
Rob, how did you calculate length of main and fore masts? In the book they say 91 vs 94 FT but IT consisnts i assume overal length Down Up to the  mast step. I Guess i Will have to calculate it , Well knowing her measures upside Down it is no problém ať All. Just curious :) V.
Vladimir, in post #2134 I discussed mast heights with Rob. My conclusion by totalling up combined keel dimensions was to add 9'5" to your mast heights, to account for these massive spars being mounted onto Glory's substantial internal backbone. Measure
from the very bottom of the keel of your vessel. That's for lower masts only. All other masts above the lowest, would exactly follow the published list.
Many thanks Rich, your encyclopedic knowledge never let down :)
1 hour ago, ClipperFan said:
Vladimir, you're welcome, I'm sure!
To pipe in....along with published numbers...I always use calipers or drafting dividers to cross reference these numbers with actual photographs.  Dead reckoning via direct measurements of photographs....either validates or causes you to remeasure.  Like any good carpenter....measure twice(5 times if necessary), cut once.   If I can reverse engineer the entire hull from knowing the actual length of the figurehead....I can do the same with the masts and yards.:dancetl6:
Rob
Current build:
Finished build:
Rob Rich would you folks mind to post pic or to point me to some i Can see how exactly IS mounted topgalant yard on Glory? I mean construction on yard. IS IS samé AS royal yard? Built over added wooden half circle with metal lock around?
I apologize if not goint to watch All pics so far but  not sure that shows yards mount. Flying fish Has Still same double eyed casted hinge as lower yards. Up to topgalant. But having one topsail less so probably thats why....
Many many. thanks. I should probably slow and watch Rob doing IT 😕
Glad….here are some diagrams from several sources first this overall image shows the yards and how they are fixed to mast.
This image shows the lower double royal mounted as the lower topsail.
Glory did not have one of these
Image is from “Lore of Ships”
Rob
Current build:
Finished build:
Next…..Glory was rigged with Howes double topsails.
these two images come from, “The masting and rigging of American clippers” and “Masting and rigging of clipper ships and ocean carriers”.
They show the Howes double topsail design.
Glory was slightly modified from the image with the banded support arm.
Rob
Current build:
Finished build:
Crane for the top mast cap.
Rob
Current build:
Finished build:
These last images are showing the configuration of all the yards and their fixtures.
Images from Campbell and Underhill’s books
Rob
Current build:
Finished build:
Hope this helps.
Rob
Current build:
Finished build:
Thanks a milion Rob, it helps enormously. Though i dont intend to change topsail mounts at this point - it was tremendous work. im glad topgallant is different but wioll be more and more iron work... i should seek for some books of masting and rigging - i note there will always be some variations even with bands on yards... as looking at flying fish design plan i have. so  more headache. 😕 . i assume there will be slight innacuracy in a way here and there with little details but i dont consider it fatal. even some captains might have done some rigging adjustments. though essentials are functional structures that are always given.
Rob
Strange thing is on these pics topgalant is mounted differently not on crane but with a round parrel. seems it gets confusing it probably varied ship from ship isnt it...
Vlad, may have something to do with the size of the spars,  In my Victoria build, the yards used a patent truss for the lower yard, an iron parrel for the topsail yard, and rope parrels for the topgallant and royal yards - confirmed in the Rigging Warrant.  The upper mast (top, topgallant and royal) was a single stick so the upper parts were relatively quite thin and fragile, and it appears the royals were rarely used.  Rope will have been lighter and kinder to the masts as you have surmised - horses for courses (parrels for masts).
cheers
Pat
Edited by BANYAN
p.s. GS Nares in his book 'Seamanship' (1868) also recognises the various options including rope or iron parrels (iron being iron brackets on a wooden support bolter to the yard).
