Robert:
No problem. A nice filling and sanding will solve this. And you will cover everything. I am pretty sure you learned a lot, and that will help you with the second planking.
After seeing the picks, I will insist you to take a break. Minimum 2 days. And then do not attempt to do more than 4 planks a day. 2 each side. Calculate, measure, cut, bend and glue; but the most important thing, be relaxed and enjoy.
Get a gel CA glue, it helps a lot to dose the correct amount. Use just a small drop on the plank-bulkhead contact area. Use white glue for the rest.
I think you tried to do too much too quick. But it is good it happened with this first layer and not with the second.
And smile, because after this, you will enjoy much more your build when finished!!!
Hello Robert,
As the previous speaker said, I´m sure you will make it.
It`s very easy with filling and sanding. The planking looks very good and with patience the result will convince you.
Helli
14 hours ago, Eugenio Treviño said:
Robert:
Eugenio you are a good friend. Thanks for your encouragement. You're right, I've learned a lot very quickly. I'm going to take a few days off from my build to soak in what I've learned. And when I'm ready to resume I'll be sure to think through each step. I'm not a big fan of the CA glues. I've used them a lot in building model aircraft, but this is so different. I might go back to using Elmer's. I don't know. Need to think about it.  Thanks again for your advice and support,  it means a lot.
Best regards,  Robert.
7 hours ago, Helli said:
Hello Robert,
Helli
Thank you Helli. I know it will work out with a lot of sanding and filling. I'm going to rethink the whole process and make sure that I have the planking widths and tapers figured out before I even start. I appreciate your support and encouragement. Best regards,  Robert
I've resumed planking the hull.
Many mistakes, but many lessons learned. I'm looking forward to getting the first layer of planking finished so I can concentrate on applying everything I've learned on the walnut outer layer. I know I need to slow way down.
In the meantime I have added a new friend to my hobby room.
Say hello to Mr. Byrnes 😊
I now have the starboard side completely planked. Gave it a thorough sanding. Many areas that need filling. I still have a ways to go on the port side. I'm going to take my time and use this as practice. Then I'll take the time to lay out my walnut planks properly. Here's a few photos. Have a great day.  Robert
It looks very nice Robert.  A good smooth surface will help a lot with the second planking.
Take your time. A pair of planks on each side per day is enough at the beginning. That will allow you to check a correct positioning, alignment, tapering and glueing.
I am sure you feel much better today!!!
I can't believe how much I've learned. This is a very challenging ship. Thanks for the encouragement Eugenio.     Robert
My hull is completely covered in planks. Not the prettiest but it's a good start. Still have a few planks to put in around the poop deck.
I'm probably going to cover the poop deck with deck boards before I close it up with the hull planking. I installed the stern gallery frames and faired them in. I redrew my port openings on the starboard side and drew in some reference lines for position of the walnut planking and wales.
Here's some updated photos.
Have a great day,   Robert
Nice job Robert!
Have you glued them poop deck?
If not, please do not forget to remove the deck beam there.
It helps as support, but the height of that area (between the two decks) will be not correct if you keep it.
Check the attached pick of my Victory. I didn’t remove it and it is not correct.
Best regards.
12 hours ago, Eugenio Treviño said:
Nice job Robert!
Best regards.
Thank you Eugenio for pointing that out to me. I completely missed that. Yes, I already glued everything in. But, thank God for dremel tools.😁
With a steady hand, and some filing,  I believe I have it where it needs to be. The diagram is from "Anatomy of the Ship" by John McKay.
Hi Robert:
I hope you are doing great!
I have been away from my build for some days, but hope to re take it next week.
Have you worked in yours recently? Keep us posted!
Best regards.
