So here is what happens when you don't re-research your build after being away from it  a bit.  I knew where I left off:  ( the topgallent railing) but I didn't realize the errors that will always manifest themselves...
(I cant seem to find the pictures right now..)
Edited by rfolsom
Hello, Lawrence;   I've looked at your fine Victory log several times now;  There are so many for the Vic it's hard for me to keep everyone straight...
But I'm watching and learning...
Mistakes are stuborn things, in ship modeling and in a life itself. You can put them under carpet, ignore them, do not see them, mask them, and be sure when you do not expect, you will hear their call or see them whispering: "Here I am"
And there is your call to fix them or to live with them
PS: it seems that ending of hard working day put me in a poetry way. Sorry for turning out of the road/subject
Topgalant rail cost me tone of nervs, but I was in better (?) situation than you considering my deck walls ( bulwarks) dropped preety thick, and railing was easier (more surface for glue) with other putty acrobats I made
In your case, your under railing is nice, gently and fragile, so what do you think about to call Harry Poter to help
YOU CAN DO IT, BOB
And I am unpatient to see rails on place
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Ok,  I found my pictures, somehow saved in a file I never use;  anyway, I should have sanded the bulwark assembly down a bit more before adding the rail;  I was so preoccupied with getting the rail centered, I didn't notice this detail.  I used CA to attach the rail, so I won't be ripping it out.  The rail is a little thick yet, so after final sanding, shaping and staining it shouldn't look too bad. (I hope).
You have got just right look an feeling from deck. If you compare with photos from Her deck - this is it !
In progress:
Content of log :
Past build:
My choice of stain (made many months ago) is now too dark in my opinion, but since quite a few fittings, plus the poop deckhouse are already made using this stain (Minwax red mahogany), I'm sticking with it. Here's some pictures of the curved stern portion of the topgallant rail.  The last pic shows a close-up on the poop deck with the seam between the curved piece and the straight piece visible on the right.  This is after initial staining and sanding.  Final finishing will come later after the fore portions of the rails are installed (following cathead fabrication and installation) so the entire rail can be final sanded and finished as one continuous unit.
Thanks Keith;  I'm counting on those goodies to do just that.  But I'd better make those goodies "good", or I'll have to add even more goodies... (ad infinitum).
I heared that ...
In progress:
Content of log :
Past build:
Well, ...  Internet provider was down for about a day and a half;  at almost $80 per month I was very unhappy with that situation...
So I took it out on the C. Sark.... :o
I ripped off the t. gallant rails..  They came off very cleanly, actually..  now I can fix the scaling problem with the white panels.
It's always a good idea, when you're away from a build for awhile, to stare at the plans for a good minute or two (or hour) to re acclimate yourself to the ship and plan your next move;  or else you'll be tearing pieces (or your hair) out.
~Bob
If you have hair. What I to tear?
In progress:
Content of log :
Past build:
Or not enough ... only 3-4 pulling left?
In progress:
Content of log :
Past build:
I wear a very convincing wig.. :P
No railing pictures yet, but I made a small measuring stick based on Campell and went from panel to panel, sanding  along the length of the bulwarks in order to get the proper height.  Why I didn't do this before?  I have no idea... (forest and tree scenario, most likely..)
After this frustration, and while the new rails' stain is drying, I revisited my cathead prototype, decided it was o.k., and started another...  These are the laminar pieces to replicate the sheave slots, that I have posted before..
Edited by rfolsom
neat way to do the catheads Bob.    I really like how the inner bulwarks came out ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thanks, Popeye;  hope to show the "new and improved" inner bulwarks soon... and more detail on the cats before installation...
Alright, CS Fleet;  this is probably the #1 problem I can't get my head around...  I'm working on the catheads, and I'm not getting any consistency between Campbell and the actual ship.  Right now, I'm limiting my cathead attention inboards... There is a "pin" and a cleat  that show up in radically different positions in regard with my two references (Campbell, and actual photos (courtesy of Lou).  Also the taper of the cathead is not shown on the C. plans, but is evident with the pictures...  This is the easy part... I still have to do the cat stopper tumbler and the whisker booms yet...
SOS..  Which would be correct?
Edited by rfolsom
To thicken the soup ...
Here are Lou`s and another present stage pics
In progress:
Content of log :
Past build:
Thanks, Nenad;  Campbell's plans are semi consistent with the actual ship...  This goes for the cathead detail only... the 1/8":1' detail shows the cleats inboard of the pins; as in reality.  His deck plans show the opposite;  and indeed if you match the scale (from the same plan sheet!) nothing lines up.
(Too much scotch for Mr. Campell that night, perhaps?..) :P
Anyway, I'm done with diddling with this, so I'll be using the 1/8":1' plans; and adapting them as I see fit to the pictures of the actual ship..
Moving along... :cheers:
Go on, I am watching
In progress:
Content of log :
Past build:
Progression with cathead fabrication cannot continue until I make the step to cut out the bulwarks where they fit on the ship.  I affixed a template to the deck and  used a razor saw to cut out the bulwarks.   As I thought, the thin basswood broke on one side, but was an easy fix.
These holes will have to be cleaned up before the catheads are installed.  also, the masking tape and scrap wood shows where I protected the deck from my saw cuts. (Margin plank will be notched in this area.)
Final photo shows my progress with the tumbler release handle for the cats...
~Bob
Inside bulwarks modified; see my post 586 for comparison
Very nice. As you are on deck. I like it. Think you have got right proportion of panels as on photos. Keep with good work
In progress:
Content of log :
Past build:
