DAWN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  :o  :o  :o  :o
Could that be just after 9.00 please  :cheers:
Mick
Edited by Micklen32
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
Sorry Mick, I won't be home at 9.00 to serve it, so here is your requested beverage.
Anja
Those we loved but lost are no longer where they were, but are always where we are.
In the gallery: Albatros 1840 - Constructo
:cheers:  :dancetl6:  :10_1_10:  :bird-vi::dancetl6:   :piratetongueor4:  :piratetongueor4:  :piratetongueor4:  :piratetongueor4:  :piratetongueor4:  :piratetongueor4:
<p> </p>
<p> </p>
Hi Mick
Nice work on the long boat you are going well.
I have an AL Endeavour which I have been very slow on coming back to this site will be the encouragement I need.
Keep up the good work.
Kevin
Hi Mick
N++ic+e work on the long boat you are going well.
Kevin
Cheers Kevin
Let me be the catalyst to get you going on your build again
Mick
Edited by Micklen32
<p> </p>
<p> </p>
To virtually finish the lifeboat other than painting or whatever I fitted the throles
I shaped them slightly as they had in the picture instructions
Then I made another oar in the shape I thought was right but when I looked at it I realised it needed to be made from a square section to get the shape needed so I glued 3 tongue depressors together and cut them into 3
This now gave me the shape I wanted
I feel that looks so much better in shape and size
It is only fractionally shorter than the original
Looking at diagrams they seem to be the same size all the way up virtually, apart from the thickness of the blade and a section of round just above the blade
The thread has also arrived
I am a little disappointed as it is not as thick as I remember the thread I used for the Thermopylae
I will give it a try this afternoon and if it is no good I will have to see if I can find some actual carpet thread
Well this is how it is turning out
As you can see it is improving as I go
The thread really isn't thick enough and carpet thread would do the job much better but I had great difficulty finding any so I went for the upholstery thread
What I did to make it work was to twist it double with a tiny bit of glue
Carpet thread would be perfect though and I will try and get some for the upper decks
Not much of this deck is seen
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Hi Mick,
Nice oar  :D
Looks like real one!
Also nice thread and it looks good on the deck.
I will wait till the end result of that.
When it looks good, maybe I will give that a try at my next build.
Hello Mick,
Your lifeboat is looking good. She's coming along very nicely.
It's a shame the thread isn't exactly what you expected or wanted.
Maybe, instead of twisting the thread double, you might try to put a thread between the planks and add another one later.
Or is that a bad idea?
I do hope you will be able to get your hands on some carpet thread soon.
Anja
Hello Mick,
Anja
The problem is if the thread is not secure and also strong it will pull out or shred when you sand it Anja
I was going to send off for some 1mm bracelet thread as that would be great I thought
I consulted the wife to see what she though of the idea and she said 'hang on a minute'
She brought in some embroidery thread and this is how it looks
As you can see the last two are the ones with embroidery thread and it looks real good
So that may be the way to go
I would say if you had nothing that 1mm Shamballa bracelet thread should work well and is quite cheap
It's important to fill the gap as solid as you can
I remember reading a thread somewhere where a chap cut 1mm or less shims of wood and used those
That would be hard work though without specialist kit I would think
Edited by Micklen32
<p> </p>
<p> </p>
Hej Mick,
I know your ship is in a much bigger scale as mine, but as you might noticed I used “thin paper” on the Sanisima Trinidad for caulking,
Maybe you can give it a try with “thick cardboard” or “glue” it on both sides of the planks instead ?
It  might look complex to use paper or cardboard but actually (maybe after a few tries) it will probably surprise you how easy it is..
And you can sand it down as much as you want afterwards  :)
Best wishes, Theo
Current Project:
Santisima Trinidad -> Build log
Finished Projects:
Smit Rotterdam -> Gallery
Hej Mick,
And you can sand it down as much as you want afterwards  :) [/size]
Ah yes Theo, I must have seen your post at some point when I was searching caulking through here
I did think about it but thread had done such a good job for me before
It is just a question of getting the right thread
Mick
<p> </p>
<p> </p>
Interesting "experiment " with the threads Mick. I hope you find one that you're happy with. It does look to give a nice effect.
Hello Mick,Your moving along at a steady pace,doing a nice build.Mum inlaw past on will catch up on your blog soon,regards.Edwin.
Hi Edwin
Please accept my condolences
I did try to message you but was told you couldn't receive any more messages
Take care
Mick
<p> </p>
<p> </p>
Looking good.  I really like the instructions. They seem to be more detailled than the AL version
Current builds : AL HMB Endeavour 1:60
Next build :       Vasa 1:100
Previous Build : Nil
There is no such thing as a dumb question.... other than the one not asked.  :dancetl6:
Hi Bankie
OcCre are famed for having good instructions and also supposedly the most realistic models
The also now seem to be doing most or all their instructions in English
Anyway to keep you all abreast with what is happening there is so much on the TV today what with the Test, the Scottish Open golf and most importantly FISH-O-MANIA   :cheers:  :dancetl6:
But what am I doing
I am making oars
And do you know what else  :mellow:
I have the DREMEL out  :o  :o  :o  :o  :o  :o  :o
I won't say it's any easier, it's probably more difficult
Slip with a sander you make a bit of a mark
Slip with the Dremel and you have a tooth pick
But I am a whiz with it and it is so much quicker  :P
So production line oars for a bit, then I may do a bit of planking
I can plank while i watch the TV  B)  B)  B)
Mick
<p> </p>
<p> </p>
Hello Mick,
The last two with the embroidery thread are looking good.
It makes a huge difference with the other thread.
Anja
Thank you Anja
Here is the half deck finished
I have done my best to even the caulking up but as I have said most of this deck is hidden in one way or the other
I have finished 6 oars and the rest can wait until my fingers have recovered from the cuts  :huh:
As you can see the 'Hand' made ones are a lot better but they take forever and I think the others are good enough as they will be heaped in the boat
I should finish the other half deck tomorrow so it can be fitted in the hull
Then it's the more important decks that will be seen more
Right better go and change the dressings on my hands  :P
Mick
P.S.  Oh yes.  Question of the day.  Do you think the decks look better polished or just varnished??????????????
Edited by Micklen32
<p> </p>
<p> </p>
It just looks great mick!!
keep it going, .. even i consider threat next time ..
As for the question of the day... can I convince you to use ..beeswax.. as the final touch ??  ;)
Best wishes, Theo
Current Project:
Finished Projects:
Hello Mick,my messages have been coming non stop,anyway many thanks for your thoughts,my wife appreciated them,she could not travel to Trinidad because of her own illnesses,you are doing a great job of your model(should call you speedy),Got a model with some pieces missing,got fast response and service from OcCre.Regards to your good lady.Edwin
Hi Mick,
Great (and fast) progress, looking forward to more.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Yes I think that has to be the way Theo
Nothing more satisfying than working a bit of wax in to build up a lovely finish
Thank you all for your nice comments
Remember the reason I may seem speedy to some of you is that I spend around 8 hours a day on the build
I don't suppose there are many that can say that
Anyway I need a few more planks cut to finish the second half of the lower deck so back to work
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Hi Mick,
Deck looks good. As to your question, my only advice would be to avoid a finish that looks too shiny. With your deck planks, you might want to consider staggering the plank endings a bit more. This "shift of the butts" is usually 3 or 4 planks (ie 3 or 4 planks between plank ends ("butts") falling on the same beam, while yours appear to be at every other plank. I know you said this deck won't be seen much, so maybe something to consider for the upper decks.
And half your luck - being able to spend 8 hrs/day in the shipyard! :D
Edited by gjdale
Hi Mick,
Basically what I am doing Grant is following the instructions  :P
Thing is with the planks only being 65mm it would be tricky to lay them any differently
Plus I have always done it as I am now and it is habit  :huh:
So it actually never even crossed my mind although I have read about it
I am afraid as well that I have started the middle deck the same way  :mellow:
Maybe the next ship
If I can afford one  :(
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Deck looks great Mick,
Even when you don't see all of it, You and we know that it is there…..
Use some real beeswax ! not the syntatic stuff…….
Edited by Sjors
Hi Sjors
Yes you certainly know yourself even if it's 3 layers down  :huh:
Anyway the first job today was to finish off the lifeboat
It's really annoying on the photo as the paint looks nice and smooth when you pick it up and look
Almost makes we want to clean it all up and paint again but we all know how difficult that would be on something so small and delicate
Now the lower decks
I finished the planking and rubbed in some beeswax
I was amazed, there must have been some sort of tint in the wax
It didn't look like it until you rubbed it in
Anyway that will be the lower deck so it will be dark anyway
The second deck needed supports so these went on next
Simple planks glued to the frame
I then dry fitted the decks
They did not line up perfectly as you can see but slight pressure bought the hatch sides into line so they would be fine
I wanted a strip pf caulking down between the two halves of the deck
As you can see I glued a length of the thread to the edge of the deck and the first row of planks
Hopefully that should work well
So I planked the decks and rubbed in some different beeswax that I hoped had no tint in it
I think they turned out quite nice
I have never been one for bright wood
I like a bit of texture to it and I think this wax gave it just enough
Two more decks to fit and then the building starts
Just remember Mick
GET IT RIGHT FIRST TIME!!!!!!!!!
Mick
<p> </p>
<p> </p>
Hi Mick,
You are in the next gear?
Planking of the deck looks just great.
You keep it this way?
Under deck dark and the decks above lighter?
Hi Mick,
Thank you Sjors
That is indeed how it will be
That lower deck is totally covered by upper decks so it would appear darker anyway so I will leave it so and the upper decks will be as the middle deck is
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Hello Mick,
My compliments to you.
Both decks look great.
The lower deck has a sort of weathered look now
The middle deck just has a more solid color. Very nice.
The thread seems to work out ok.
Anja
Guest
This topic is now closed to further replies.
