Looks like I may have to do a bit of cheating as I am very disappointed the way the stain has taken on the Falconet supports
I sanded it well after fitting the bands but it looks like the glue has spread badly
Considering it was thick and only a tiny drop was used I was rather upset  :angry:
I wish I had still got some of the loctite gel left but I used that up on the other builds
If I try to sand any more it will put the wood out of shape so I think I will have to redo
Not at all happy with this
I had a slight problem with bleed on the handrails but not as bad as this
Trouble is the wood is so soft
Oh well I will have to see what I can do  :huh:
Keep it up  :10_1_10:
Mick
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
Well pleased
I tried using card and also I stained first
Stain does affect the glue a bit so I had to try several times on some as the glue would not go off
However the bit of extra work is well worth it as you can see  :dancetl6:
So much better and as the Admiral used to make gift cards she had some quality black card I could use  :D
Keeping it up  :10_1_10:
Mick
<p> </p>
<p> </p>
Hiya all  :)
Still working on bits and bobs
I have a question about the windlass
I have made a start on mine but I have a question about its finishing
OcCre tell you to make marks on it so
Now, what are they meant to represent???
Is it good doing them like that or, like I did with the capstan, would drilled holes be a better representation?????????
As I am not sure what they are for I am looking for advice
Working on the ships bell too
Going to have the metal surround gold rather than brown  :o
Have a bit of glitz  :dancetl6:
Anyway the ships bell was very important so I don't mind a slight departure from reality  :P  :P  :P
Keeping it up  :piratetongueor4:
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Mick
The square marks are square holes into which handspikes or bars are inserted to give leverage to turn the windlass. The suggestion that they are marked rather than formed is probably because making a square hole is difficult without a milling machine. You probably can get away with a round hole although it isn't technically correct.
I reckon you'd be well served by getting yourself a copy of "Historic Ship Models" by Wolfram zu Mondfeld. It will answer most questions about bits of ships and has a wealth of very good drawings and modelling tips. I'm sure many here have a copy - I sure do and enjoy leafing through it. It also has a picture of an Endeavour model on the cover!
Cheers
Alistair
Cheers
Alistair
Current Build -
Mick,
The photo below shows the windlass on the replica endeavour.  You can see the handspike holes quite clearly.
In this photo you can see the square handspike holes at the outboard ends of the windlass on my Palmerin model.  The square holes were made by first drilling the holes to size and then squaring them off with the tip of a very small square file.
John
Mick
Cheers
Alistair
Hi Alistair
I do have a dremel with some tiny routing bits so with a steady hand and some practice.............!!
As to the book
165 QUID  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o  :o
The paperback is £58  :huh:  :huh:  :huh:  :huh:  :huh:  :huh:
I can't afford that on my meagre pension  :(
Luckily Amazon do second hand and I am having a copy sent from America in good condition for under £8 including shipping  :D  :D  :D  :D  :D  :D  :D
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Mick,
John
Hi John
Thanks for that
As I just said to Alistair I do have a dremel so I can make the slightly elongated holes and then square them up with a square point file
I want to mostly try and get it right rather than just inking the holes in
Mick
<p> </p>
<p> </p>
Mick, you will be happy with this book - guaranteed. It has more in it than you'll ever need to know and the drawings are amazing. Well done on the price - I think I bought mine new when it was still in print so it was about $NZ40 or 20 UK pounds. 8 UK pounds is a steal.
Good buy - enjoy.
Cheers
Alistair
Cheers
Alistair
Current Build -
Mick I suggest you practice making the square holes on a piece of scrap wood :)
Hi Adriaan
Yes I think I will go along with that about 150%  :cheers:
I have a miniature point square file which I think will be perfect to finish the holes off with
So here's hoping  :dancetl6:
I hope you are still feeling good and your builds are going well  :)
Mick
<p> </p>
<p> </p>
There we are then  :)
The windlass and the ships bell  B)
I think the bell looks fine with the gold paint
The windlass took a bit of practice but I think I got the holes as good as I could
So I am fairly pleased
I am getting very close to the time when I need to finish the painting  :o
I have some new brushes so it could take place anytime now
Mick
<p> </p>
<p> </p>
Hi Mick,
just went trough your buildlog, you are way far ahead of mine.
You are doing a great Job, keep going as I will keep an eye on your ship.
Cheers,
Udo
Current builds:
Le Coureur 1776 - CAFmodel 1/48
VOC Retourship Batavia
Boston Typhoon steam trawler 1/32
Research/Side Projects/On Hold:
H.M. Bark Endeavour
HMS Bounty 1787
Good work on the windlass Mick and I hope that my book recommendation doesn't make you regret spending 8 pounds. :( Actually I know it won't.
Your bell - sorry mate, ditch the glitz in my opinion. The roof of the belfry could be gold but gold all over??? Too much in my opinion but, hey, it is your ship - up to you.
Glad to see you've taken to cheating too :P.
Cheers
Alistair
Cheers
Alistair
Current Build -
Had my first major accident today :(
The ship slipped as I was painting and took off a length of handrail and some columns
I have them back on ok but the incident has me thinking whether to paint the handrails etc black as I have seen in other Endeavour models, as I am not 100% with the staining
I am doing the major painting now but have made a few other things ready to fit such as the davits and I have decorated the transom
So, back to work watching the golf as the paint dries :huh:
What do you think of the black rails etc, OK?????
Mick
Edited by Micklen32
<p> </p>
<p> </p>
Cheers
Alistair
Yes I do see your point Alistair
Maybe a gold top with a black surround
I will have a think on that
And yes, the cheating worked very well  :dancetl6:
I did use brass on the end of the davits though as I wanted the finish  B)
Mick
<p> </p>
<p> </p>
I was quite surprised how tricky it was to apply the masking tape
I have it done though and I am ready to do the black
I will do what I have masked then decide whether to do the gallant rails, handrails etc.
Please let me know what you think about that
Mick
<p> </p>
<p> </p>
Hello Mick,
masking tape looks good, it denotes a clean line.
In order to prevent paint spreading under the tape, creating distortion, I'am using some flat mat varnish. Just brush it along the edges of the tape to seal it.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Hello Mick,masking tape looks good, it denotes a clean line.In order to prevent paint spreading under the tape, creating distortion, I'am using some flat mat varnish. Just brush it along the edges of the tape to seal it.
Thanks for that Edward
A simple idea that wouldn't cross your mind
I will give it a go
Mick
<p> </p>
<p> </p>
Hi all, I am happily painting away, bemoaning the quality of the wood  :(
But I have a question for the Endeavour experts and those with a library  :P
The question is about slots on the front davits
The picture has arrows pointing to what looks like slots, but the instructions say nothing about them
So do they go right through?
I presume they do
And the dimensions
They look to run from the brass wrap to the pulley holder
Does that seem about right
Thanks in advance for the heaps of advice  ^_^
Mick
<p> </p>
<p> </p>
Hello Mick,
the CC drawings are showing four holes only. Attached the drawings from my AotS book, actually the Slots are the cat head sheaves. the pulley diameter, measured on the drawing (scale 3/8in = 1ft) is 8mm, width of the Slot 10mm. I don't have no idea how to convert this scale into something metric.
I have noticed your instructions asking to install a pulley (155) on the thumb cleat. This is not shown in my book.
have a look, if you need more Information just let me know!
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Hi Mick,
I have posted pictures of the models I have seen in Chatham.
Somewhere over there you will see pictures of the Endeavour
When you go to Model Ship World and look for museums you will found a topic that called " Chatham History Dockyard"
Model Ship Clubs and Exhibitions and Events, Museums and Museum Ships
Maybe it helps you a little.
Edited by Sjors
Hi Mick,
Thanks a lot Sjors
I will take a good look as soon as I get a chance
Mick
<p> </p>
<p> </p>
Hello Mick,
Hmmmmmm  That is a tricky one
Am I right that in the first picture I just see a rope through that slot where in mine there is a pulley and then a pulley further up the davit
Or am I reading that wrong ????
As you say the bottom photo just shows 4 holes with some sort of groove between each pair
I presume  :huh:
Difficult
If we come up with a solid answer I will possibly change things
That or I will simply follow OcCre's instructions
Thanks a lot Edward
Mick
<p> </p>
<p> </p>
Your instructions are showing you to drill four holes in the end of the cathead, straight down through the cathead. You then can make it look like two slots by connected the front and back holes at the top and bottom surfaces of the cathead. On the real ship this would be two parallel slots with sheaves in each one. Now, you could also do that if you had two very small sheaves and a way to cut the full slot, but that is a lot harder to get right. I have always used the four hole method to simulate these sheaves. Also, the holes should really be drilled at the angle that the cathead will be mounted on the model, so they are perpendicular to the water line. You can see this in the first photo from Edward. I have not done this on any of mine, but will on the next one. That sheave in the instructions (155) goes on the outside of the cathead in the wooden holder. I can't tell what the line that goes through it is used for.
A very comprehensive response
Thank you Tom
I think there are limits you have to place on yourself depending on your skill and needs
Now I know what is needed I will do my best to get it looking like that but I will never expect my build to approach museum quality by a long way
I am finding on this build that the quality of the wood is holding me back slightly as it is difficult to get it to a sufficiently good finish for staining or painting without reducing it's size quite a bit and when you only have 2 x 2mm to start with you can't do a lot
I will keep going with it as best I can with my limited skill and knowledge  :piratetongueor4:
Mick
<p> </p>
<p> </p>
So the painting is almost finished
While I was doing the hull I also did the hull on the lifeboat  :D
My paint finish is never as good as I would like it to be and I also think it could have had a lot more sanding, but I think it will suffice for what I need  :dancetl6:
I have decided to do the gallant rail and the posts and columns on it black, as I have tried a small area and it does look a lot better
So that means a bit more masking up including some difficult bits on the inside of the gallant rail  :o
I am also in the midst of putting together the absolute loads of bits and bobs that sit on the hull
Strakes, doors, all sorts
That means I have plenty to do  :huh:
Mick
<p> </p>
<p> </p>
Hi Mick,
I have attached again the first Picture of my previous post in a better Quality. I understand both of the cathead slots are equiped with pulleys, but no pulley on the thumb cleat as per your instructions.
The second Picture is the corresponding part of the 'English man of war'.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Mick, you are doing a great job. Do what you think is best. I for one am more pleased if I have something that looks good than something that is technically correct but looks bad.That said, I am always trying to do something better on the next one than the current one.
Going back to the bow davits or whatever they are called  :huh:
Is this what it should look like then?????????????
With no pulley in what I think is the sheave and a pulley in the end of it where the yellow is
And are there then holes at the sides of the pulley
I am really trying to get my head round this  :piratetongueor4:
But don't forget my brain capacity is limited  :P  :P  :P
Trying to keep it up  :10_1_10:
Mick
<p> </p>
<p> </p>
Guest
This topic is now closed to further replies.
