On 1/29/2025 at 7:09 PM, hamilton said:
Your work is excellent! I live about a 15 minute drive from the St Roch so if you ever need specific photos let me know!
hamilton
Thanks Hamilton...
Actually there is a topic I have reached out to the museum curator about, unfortunately with no success so far...
There has to be a sea chest or similar in the lower hull to provide cooling water for the engine, but my plans give no reference to this and neither do my photos.
Not an urgent requirement, but if you're going to be visiting the museum can you please and thanks take a look at the lower hull for such an opening?
Regards,
Bruce
6 minutes ago, Lecrenb said:
Thanks Hamilton...
Regards,
Bruce
I'll be able to get there next weekend - do you know what the general location of the opening would be? The ship is dry docked in the museum and it's possible to go down into the well, so to say, and examine the lower hull - I'll take a look through the photos I already have and see if there's a likely candidate....I can PM you a couple of images to see if they're what you're looking for and if not, I can swing by next weekend
hamilton
Quick PS - just looked through my stock of St Roch photos and I wasn't able to identify anything on the lower hull that would look like a scupper for the sea chest - but I will head down to the MM to have a look around
hamilton
hamilton
Hi Hamilton,
Thank you very much for your kind offer! The cooling water inlet would be under the superstructure area, where the engine room is located. Probably around the curve of the bilge, no idea port or starboard, but definitely below the water line. I have been down there as well and never noticed anything, but it never crossed my mind back then to look for it!
I will let the curator know you're coming, if they unearth anything they can let you know!
Regards,
Bruce
hamilton
Thanks very much!
I'm now making the chain plates... there are a total of 14; 3 each side of each mast and two main mast preventer stay plates.
They are made from simple steel bar stock that bolt flush to the hull, passing behind the rub rail and bolting below it. Turnbuckles that tension the standing rigging bolt to the top of each plate.
I derived the lengths of each plate (they are not all the same) by scaling from drawings. The first picture shows the two sets for the foremast, complete with turnbuckle ends I made from solid core solder.
I drilled a .020 hole through each assembly then pinned each shackle to its' plate with Grandt Line 1 1/2" scale bolts and washers...
The turnbuckles that tension the rigging have fork ends that bolt to the plates, but detailing those while installing the rigging would be a recipe for disaster! I plan on modifying the turnbuckle ends to fit over my 'shackles', so they will look like forked ends.
The plates are not straight up and down on the hull, they follow the line of the rigging. I temporarily set the mast and used thread to derive the correct line... in the picture the thread passes down the aft side of the mast to the rear chain plate.
And here are the port fore chain plates installed using CA glue.
Now to pin them into the hull, then do the other sets and move on to the rub rail, which is the last structural member of the hull!
Regards,
Bruce
Edited by Lecrenb
hamilton
G'day Hamilton...
I heard back from the Executive Director, David Jordan. If the visitor services staff is not too busy they are prepared to give you private access to St. Roch's engine room. You should be able to identify the water pump and associated lines that draw water in and discharge it overboard.
Just tell them you are Hamilton and are looking for engine cooling details for Bruce LeCren, hopefully they will have time to let you in!
Do you have a rough idea of when you might visit?
Thanks and regards,
Bruce
My rub rail is made from one single piece of lumber, scaled 4 x 8 inches, each side port and starboard, and a curved section across the stern...
These rails fit over top of the chain plates and overlap the lower edges of the fo'c's'le portholes, so the first order of business is to take measurements back from the bow of the model, and notch the rails appropriately...
The cutouts are where the portholes line up. The notches are for the foremast chains.
Here it is being test fitted to the hull...
Then the rail is steamed, bent, clamped to the hull to dry, and painted semi-gloss black. Yes, the main chains pass under the rub rail but over the poop deck wale...
Here is the starboard rail glued and clamped in place...
The cocktail toothpicks make sure the rail does not encroach over the scupper. The block assemblies transfer clamping pressure down onto the rail. Fingers crossed everything stays in place and I only have minimal cleanup to do tomorrow, then on to the port side!
Of interest is this picture of St. Roch showing parts of the main chains. These were not removed when the main mast was taken out in 1944, presumably they were sawn off at the top of the rub rail because the shipwrights did not want to deal with the resulting exposed notches!
As always, thanks for looking in and comments are welcome!
Edited by Lecrenb
what is the flanged hole under the support just to the right of the centre of the last photo?
Edited by AON
Alan O'Neill
Hi Alan... well spotted!
That is the engine exhaust used by the original diesel. St. Roch did not get a funnel until the larger engine was installed in '44.
Got the port rub rail on, and started some fiddly bits...Portrubrailgoingon.thumb.jpg.aa8fa433673ad6de23a4deabfe22e93c.jpg
There are five fairleads that pass through St. Roch's bulwarks... since the flanges are visible on both sides I ordered 10 from Cornwall Model Boats. They are not the correct size so I used my small hobby vise and Zona saw to cut them down and glue them back together with CA...
Here is one being test fit to the bow, again use Forstner or brad point bits for drilling clean holes!
And here are the pair installed at the bow...
How I proceeded to make the hawse... this should be the last of the hole drilling forward of the poop deck!
I measured not twice, but three times, off the plans to locate the ends of each hawse pipe, double checking against photos and the model to ensure they are symmetrical on my hull...
After drilling the holes straight into the hull I used my 4" round file to set the hole profile.
Then my 1/4" styrene tube was fitted...
And the pipe marked for cutting...
I roughed in the hawse rubber on the deck, and the flange on the hull, and glued the flange to the pipe...
Then I filed and sanded the flange to shape, detailed the rubber, and test fit to the hull...
one more to make, then paint and they'll be ready for the anchors!
Stay tuned for more fiddly bits!
Regards,
Bruce
You only had to measure it three times to be confident it was correct before you started potentially butchering the whole thing.
I am impressed!
:cheers:
Alan O'Neill
I am impressed!
:cheers:
LOL Alan!
I am always amazed how far Cornwall Model Boats business extends. Nearly as famous as Wall Drug.
Always a tricky and stressful job Bruce, but you executed it well.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Well, I bet you were very wide awake drilling those tubes out! Well done.
Small item: it's such a nice model, I'm going to point out that the belaying pins you have look far too chunky. The handle diameter is usually no more than 2" at full size and the pin 17" long overall. See a typical example at:
https://www.rmg.co.uk/collections/objects/rmgc-object-3892?_gl=1*hlwx9x*_up*MQ..*_ga*OTc2MjMzNTAuMTc0MDM0MTQyNQ..*_ga_7JJ3J5DBF6*MTc0MDM0MTQyNC4xLjAuMTc0MDM0MTQyNC4wLjAuMA..*_ga_4MH5VEZTEK*MTc0MDM0MTQyNC4xLjAuMTc0MDM0MTQyNC4wLjAuMA..
I'm sure that you won't regret a re-do, Bruce.
Thanks Keith...
I bought almost all of the fittings I needed for my HMCS Chicoutimi build from Nick at CMB... most needed modification to be period correct but that was ok.
It has been a few years since then and I notice the number of suppliers and selection has gone down, but that is not CMB's fault.
Still my go-to supplier!
Appreciate your kind comment on drilling the hawse... at least if I mess up wood is easy to fix!!
Regards,
Bruce
Well spotted and quite right, they are getting another spin on the Dremel!
Rregards,
Bruce
While trying to install the base of my anchor davit it went skittering across the fo'c's'le deck and down the hawse hole to the depths of the interior!
I got it back by holding the ship upside down and giving things a good shake.
I did get the part back, and I thought I had been keeping the interior pretty clean, but all the dross in the picture fell out, including a missing fuel filler cap!
Fun  and games!
58 minutes ago, Lecrenb said:
Ooohh... Good point! Maybe I should put it back for posterity?
 With a note asking for forgiveness for the poor housekeeping. :)
OK, all the fiddly bits are mounted on the main and foc's'le decks, and they are essentially complete. I need to make the hatch cover, fo'c's'le deck hand rails, and the platform on the starboard side that was used for swinging the lead.
Besides the large items that are plainly seen, there are 30 'wedge keepers(?)' that hold canvas covers in place, 24 ring bolts, 2 deck lights, 8 gooseneck vents, and 6 fuel and fresh water tank filler caps.
The black rectangles are bases for the winches which will take me a while longer to build. The small hatch forward on the main deck is access to the sail room, beside it is the freshwater pump.
Everything is scratch built, except the 2 bollard fairleads at the stem, the anchor and its' davit. I find it interesting that the chimney for the Quebec heater extends above the foot of the jib sail, so the crew would have to lift the sail over the chimney when tacking...
If I wanted to get ahead of myself I could step the masts, but I will move on and complete the poop deck first!
It is -12 outside and we just got 10+ cm of snow, but the sun is shining, the dog enjoyed her walk, and we saw a pair of geese flying low over the frozen ponds!
I guess this means the rodent lied, and spring is only days away!
I've been using the last few nasty days to start stick building the wheelhouse and the cabin area behind it...
I have started painting the wheelhouse interior... it will be fitted out with the wheel and magnetic compass, based on the original layout, because these will be seen through the windows. I'll probably add the chart table and flag lockers, modelled after today's, but otherwise 'best guesses' on my part!
I have zero information on the interior colours, but I am following parts of the scheme that I do know, such as the red oxide deck. Was it linoleum like today's wheelhouse... maybe??
This deckhouse was built to replace the original in 1930, and other than exterior photos and the original plans there is zero information available.
It is almost complete, I am going to work on the interior before adding the rear wall, windows and doors, and the roof.
The area aft of the wheelhouse contained two cabins, one for Captain Larsen, and the other for the Detachment Commander. They will be a simple enclosure without interiors. Photos indicate that there must have been doors from the cabins into the wheelhouse, but I have zero information, so again a 'best guess' because they will be seen through the wheelhouse windows.
Thanks for checking in, comments and suggestions are always appreciated!
+17°C (62.6°F) down here.  You should be experiencing a chinook any time now!
She is really looking good (just to be clear I am referencing the model) 😁
Edited by AON
Alan O'Neill
