How  you guys do this with such  delicate stuff is beyond me   -   amazing but scarry.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
OC.
quite easy OC
1 card kit, shape blades, straight edge, decent paper glue and superglue to mend me fingers when the sharp blade a straight edge system dont work
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
good evening everyone
day 8/90
managed to make up another deck today, the last one is going to have to wait as it is fitted directly to the deck plates, and i am miles away from that
the corners i am putting a thin strip of paper to tidy them up, with loads of weathering i doubt they will be seen
tonight, i primed one level in grey just to see how it looks, i have infact just ordered some white primer and top coat i have not seen a SD14 superstructure in any other colour than ochre or white
@realworkingsailor what is the best deck colour? would it be green
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
4 minutes ago, Jim Lad said:
The accommodation block is coming together really nicely.
A dull reddish brown was probably the fashion colour for decks at the time, although I've also seen a dull green.
John
the red brown sounds good as it will be end of life anyway
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
23 minutes ago, Jim Lad said:
This is the sort of colour, Kevin - MV 'Kooringa".
By the way, the vast majority of cargo ships had white superstructure.  Most buff superstructures were found on ships in dirty bulk trades like carrying coal or ion ore.
John
thank you
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thankyou for comments and likes
day 9/90 shaft tunnel
taken me most of the day to get this level done, varnished, cutouts and slots done, deck plates will cover this in the next day or so,
After this is glued into position,  the stern will start to be built up
IMG_2267.thumb.JPG.7b5c5ef01271aa764c07f8f65a3315c2.JPGIMG_2259.thumb.JPG.9b11ec04eaa1ecb9602aee3d86574483.JPG
IMG_2258.thumb.JPG.4e0c4a38641109087d0f6b50692726a8.JPGIMG_2260.thumb.JPG.e12743bdf347432df79925490b249315.JPGIMG_2262.thumb.JPG.449bfc26658573c34a09887280f4a992.JPGIMG_2263.thumb.JPG.596660162169fd749466f635d205303d.JPGIMG_2264.thumb.JPG.6e9d7558032993b5d3fa8ad19c1fedb4.JPGIMG_2265.thumb.JPG.1a8771924a98649f56f1a3b963064c06.JPG
all loose so will straihten them out as they have pva applied
IMG_2266.thumb.JPG.809c213dfe67f07ea50f0794d882b56f.JPGIMG_2268.thumb.JPG.6380b88ad6675e7a84148af7ebc3391b.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
9 minutes ago, Jim Lad said:
Still charging ahead, Kevin!
John
lol i see the phots i posted they all look soibad then add a bit of glue and they become more presentable
i now am asking myself what colour were the double floor frames, would i get away with red ochre i doubt they will ever be seen, but i dont know what sections are going to be opened up yet
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
thanls guys, i was considering black, or very dark grey (off black)
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 10/90  Stern Frame and after peak
this section has taken me again most of the day, and still not completed, next bits to be added will be the top of the rudder connection
some of the bits for todays work, varnished and trimmed to size
making up the top deck girders for tomorrows work
IMG_2280.thumb.JPG.94784257acd885a71004dfda5e964c07.JPGIMG_2281.thumb.JPG.e5c3ed3389f164df4b839477be1d8763.JPG
just in place for the photo
IMG_2284.thumb.JPG.fcc34c057c9472d668ed0aa25980cf6c.JPGIMG_2285.thumb.JPG.7000755e57707fa2189acbfdd669251a.JPG
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 11/90 up to main deck level
thank you for comments and likes
not quite as much done today as planned, but the height certainly increased as the tween deck on the shortened middle section went up to the main deck and i was able to put the main longitudinal in, this will help me get the alignment right, for everything going aft the ribs for shortened middle section are not strong enough to support the weight yet, i may have to rethink that area
having done that i went to the after peak and went up another deck again to the main deck level, the longitudinal should go in tomorrow
very little of todays work is glued yet
i placed the accommodation blocks on top in more or less the correct position there is another level to be made up,
it is certainly going to be a nice sized diorama
im pleased with it so far, perhaps it looks naff to some,
Edited by Kevin
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Good evening everyone
day 12/90 engine room tween deck
thats all i achieved today build wise, also prepared another 100 pieces for tomorrow, which will be the engine room deck
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 13/90
engine room flat, engine room tween deck frames 37 to 54
well today i managed to get the two levels of the engine room done, primed and painted red, i can now get the upper deck longitudinals fitted to keep the main bulkheads separated
after that, proceed aft and finish off the shaft escape tunnel, and the continue aft back to the rudder stock
a few photos of todays work and others  for my benefit of deciding how to display this in a scrapping diorama
i would love some ideas (please) wrt the build
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
Looks amazing  mate.
OC.
Current builds
Completed works.
im hoping from today everything will start to tidy up and straighten out
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
It's starts out looking hapzard, but once you've glued and painted the various sections, it looks good. Keep on truckin' 😁
Ken
Started: MS Bounty Longboat,
true, its not the way to build this, but the main bits i want are around the engine room, the rest may be left open to the cutters
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day 15/90 about 1/2 way through
about anther 300 pieces added since the last update, mainly on the upper deck transverse beams, each section i complete is  bringing  it into shape,
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
and on the 16th day @Kevin took the day off
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
day17/90
the build is now going from 28" to 38 as i have taken another section from the redundant midships section, not fixed yet
everything is now starting to fall into place including the stern as the transom gets fixed into position
i now have in excess of 100 frames to fix into position so i know what i will be doing tomorrow
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
10 minutes ago, Jim Lad said:
Only a hundred frames/  Shouldn't take long, mate!
John
tell the truth it dont look much different to sat photo, and honest I put loads of transverse frames in today,
i can  honestly say that this has been really enjoyable build so far, and if given the chance i would do all 3 sections together with open frames and no hull plates
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
