6 hours ago, gak1965 said:
Oh wow. Did not see that.
It works, the lines look phenomenal.
Yep…… looking closely you can see the technique here….. in each belay pin.
pretty nifty.  The only issue I see is that the pin could be pushed off axis slightly.   But once the rope coil is applied it is all good.
Current build:
Finished build:
Current build(On hold):
  • 10 months later...
It has been nearly a year since I stopped working on the Flying Fish, well 10 1/2 months.  Today I installed the Fore topmast shrouds and back stays.  The inner and out stay is terminated under the fore deck.  To any Flying Fish builders, how did you accomplish this?  Any help would be appreciated.
Mike R
Mike,
     Glad you are back. I described what I did in this post:
The summary is that I ran the forestays through the relevant locations (bees or hole in the jibboom) and the dolphin striker (if relevant) and then fed it through a hole I drilled in the bulwarks. At each location where the lines changed direction, I put a drop of CA glue to hold it in place, so that by the time I got to the hole in the bulwarks it would stay taut without having major strain on that one drop of glue (the line had 2 or 3 glue drops holding it in place.
My recollection is that I ran enough line through the hole that I could snag it with a tweezer and hold it tight while the CA set (maybe 30 seconds). It worked for me, buy YMMV.
Hope this helps,
George
How are things coming along?
I was reviewing your log and I had to sit and look over your carriage house front.  My issue is not with your wonderful work....it is with the representation of the house's front facade.  McKay used quite a bit of decorating and details.  He always went above and beyond in his finishings.  I'm quite disappointed in the representation that this particular scale drawing, (used by you and many others), which depicts the Flying Fish with such meagre...barn like features.  Quite unbecoming of any other McKay design and or description we have of many of his other ships.  This, in no way reflects on your skillful execution.
McKay's last clipper...
Glory of the Seas, was quite ornamental.  A stark contrast to the Flying Fish. image.jpeg.ce80bce8b2c58252df97a761c09d2708.jpeg
Rob
Edited by rwiederrich
Current build:
Finished build:
Rob
 I still have to add on the fancy carved corner knees for the roof.  I never tried carving before so that is what the holdup is.  I did have a scalloped molding that went under the roof line, but I did not liked the way it looked so I removed it.  I am still plan on trying a different design.
I have been working on the iron work for the lower yard, topsail yard and the top gallant yard. These were silver soldered , then placed in an acid bath to clean them. I used liver of sulfur to blacken them.
Mike R
Disaster, while working the royal yard I broke the cross arm off the top mast crosstree.  I thought about trying to repair it, but it is the base of the top gallant shrouds so I had to replace it.  I really felt bad cutting most of the rigging off, but it had to be done.
Mike
Two steps forward, one step back. Seems to be my motto!!  Spend an hour making some small piece, then I drop it on the floor, never to be found again!!
You are doing a fantastic job!!
Rick
Rick, I run into that problem too. I have dropped many items and found a few while looking for them on my hands and knees.  I probably spent more time looking than the time spent making the item.  I made and installed a new top mast crosstree, I replaced the cut away rigging, installed the chains for the Bowsprit and ran the rest of the running rigging.  I am working on the braces and have completed the braces for the skysail yards, the royal yards, and the topgallant yards.
Mike R
  • 9 months later...
I guess it is close to a year again so here goes.  I finished the rudder and I think it is my best joinery to date.  Trouble is you will never see it because it is covered with copper plate.  For the gudgeons and pintles I am using .110 copper plate.  I cut and drilled the 4 gudgeons.  I attached the pattern for the pintle to the copper with rubber cement.  Then I drilled the hole and started to cut it out but I broke my last saw scroll saw blade,  I broke 2 blades cutting these out.  I am now waiting for  my order of 2/0 metal cutting blades to be delivered.
Mike R
While adjusting some rigging on the foremast, the button on my shirt sleeve cuff caught in the rigging of the lower yard  and broke the brass knuckle joint  that holds it on the mast. I made the new one out of stainless steel.  Using my wood lathe and files I turned a 1/8 stainless rod down to .039" and then ran threads with a 1mm die. After I filed the connecting lug and drilled a mounting hole I reinstalled on to the foremast.  Needless to say I am now wearing sweat shirts without buttons on the cuffs.
Today I made railings for the forecastle deck.  The vertical post are 1/16" square ebony.  I drilled 1/16" holes in the base,  using a small chisel I turned the round holes into square holes  and finished them with a tapered square needle file.  In the posts I drilled two  .6mm holes which I ran 2 fine wires through and weaved the railings.
Wonderful work indeed.
Rob
Current build:
Finished build:
Nice job on the Flying Fish figurehead!
Why the rails on the forecastle, not specified on the plans and not evident on the China Trade and  Buttersworth paintings.
Tour model is beautiful!
Rick
Thanks for the comments Rob and Rick ,  also to everyone who hit the like button.  Rick, I would think there should have been a railing there to prevent anyone from falling about 5 1/2 ft. to the main deck. Yesterday I used 1/16 square tubing to make the davits.  I then silver soldered the cleats to the tubing.  I added a couple of small brackets to the railing and drilled and made square holes in the channels to mount the davits and I started on the 24 ft. long boats.
Mike
Really nice job on the lifeboat!!!
I’m trying to carve mine.  We’ ll see how that turns out!
Did the guys for the davits interfere with the run of the main topmast brace?
Rick
Rick  I just noticed that the guy line is just touching the top mast brace.  It will be an easy fix to move it to the inside of the brace.  I think the life boats look better in person, the close up photos show every imperfection that I do not notice with my eyes.
Mike R
Absolutely beautiful work.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
