Have IPSFocus  been playing around with the Theme display?
Mine suddenly went into  a strange linear display with oversized logos, virtually unusable on a desk top monitor.
It seems that it is what they call the default mode, and to get anything recognisable the option is 'Uniform' which sort of looks like my old preference.
My old display theme.
Anyone else experiencing this, you need to scroll to the bottom of the page  and change the selection in 'Themes'
B.E.
Edited by Blue Ensign
Ok, now appears to be fixed.
I temporarily switched everyone to the other theme while I fixed the problem, so you can now switch back if you wish.
The core software had a security patch which needed adding, and even though the themes were supposed to be unaffected, Dimension was. I've now refreshed that theme and all looks ok from this side.
Ongoing:
3 minutes ago, yvesvidal said:
I do NOT like the new look.
Yves
You can change back to previous look easily. scroll down to bottom of page and select 'dimension' from drop down list when you click on theme.
Matt
Current Builds
HMS Winchelsea by Mnewsholme
Duchess of Kingston by Mnewsholme Vanguard models 1:64
 Previous Builds
Lady Eleanor Vanguard models 1:64 completed
1 hour ago, AJohnson said:
I Like the new look! 👍
Yves
It is not a new look. Just change back to the theme you want at the bottom of the site page.
Everything you see was here before.
Ongoing:
Every time I post images I have problems. My solution: I gave  up and just quit posting photos. This is the ONLY site I have these issues.
Regards,
Jim Rogers
Damn the Torpedoes , Full speed ahead.   Adm David Farragut.
If you have an issue with posting photos, please start another thread and tell us what happens. Only then can we try to look at that for you.
However, I can tell you that there are zero problems at MSW in that regard, so that would be us helping you with your equipment.
Recent problem fixed and topic locked.
Ongoing:
Guest
This topic is now closed to further replies.
