Hi Folks
Having lurked on here for a while I’ve been inspired by Chris Watton and James H to build a wooden fishing boat. I have a keen interest in the early SW sailing fishing boats. Nisha seemed the perfect opportunity of a well thought out kit with character boat for my first build.
Just the basics until the completion of the first layer of planking.
When first fitting the false deck, I was a little nervous of how much to fair in. The consequence was the inner bulwark would not sit flush to bulkheads on the bottom edge. Taking the deck edge back to bulkheads et voila they fitted like a dream, no pins used.
P1120499
P1120502 P1120503
I have deviated from the instructions in the following ways.
Part 62 the stern board. I fitted this ahead of schedule after fitting the bulwarks parts 45 & 46. Due to the exposed the nature of the stern timbers. This may come back and bite, time will tell.
First layer of Planks / strakes was marked using tick paper and fan as per this forum. Perhaps unnecessary for the first layer but good practice. Edge bending required from the 5th strake down.
Fitting Garboard strake
P1120504
P1120506
I also temporarily clamped the various rabbet patterns and drew along the inside to give me a better idea of the planking finish line.
Simple clamp for holding strakes whilst shaping
P1120538
Edge bending. I found it required only a damp finger run along the wood
P1120540
First layer completed
P1120543
P1120545
P1120546
Thanks for stopping by
Kev
The planking looks really nice Kev. Like you, I recently joined here and it was also caused by a Vanguard kit, in my case the Duchess of Kingston.
Your Nisha sports some nice contours, always looking like a dynamic raceboat.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
Thank you guys for your kind comments
On 5/28/2022 at 5:42 PM, Craigie65 said:
Is this your first build?
Second planked hull. First ended looking like fish gills. I must say I am so impressed with the quality and ease of building Chris Watton has achieved. Aided by the huge amount of information and tutorials on this site. I think I have achieved a reasonable standard.
I agree, the sailing trawlers were known for their turn of speed.
Kev
Edited by longshanks
Time for the second layer starting with the bulwark strip
P1120554
Painted with Vallejo Black grey with a thin off white strip to hopefully indicate the scupper line. I don’t like to use black or indeed any Full colour at this scale. Compare the black grey with the black of the clip, I feel the black is to harsh.
You will also note that I have added 0.5mm ply where the first full strake will lay. This being to infer the thicker deck wale.
I struggled a bit with the tick strip/fan due to the involuntary tremor mainly in my left hand.
So I marked frame spacing of 40mm with 20mm at the ends. Using paper I found the length of the hull arc and divided by the number of strakes giving the width of the stake. This was transferred using digital vernier.
P1120557
Note I have the rabbet pieces still held by clamps to simplify sanding
P1120564
P1120567
P1120568 P1120571
Note at the bilge line amidships I have again packed out the strakes (2) to form the bilge wale.
P1120562
A question for the wise folks on here. I’m not sure if the wale should follow the strake line, sheer line or water line. Do you have any thoughts?
Thanks for looking in
Kev
P1120554
P1120557
Kev
Hi Kev, you are off to flying start and very well executed so far!  👍
If you are referring to the thicker planking this is on two locations on "Nisha", Topside & Bilge planking, the first follows the bulwark/deck profile and the second follows the hold deck profile.  See my build log, post number #42 onwards where I have had a go at simulating these features.  The brilliant book "Sailing Trawlers" by Edgar J. March has been my guide.
Andrew
Completed (Kits):-
Thanks for the info, most useful.
I confess to having Edgar J March excellent book and hope to tweak a few bits as I go
Kev
A change of pace and closer to my comfort zone (I normally try and scratch build using plastic).
Case in point.
The steam capstan is very detailed but the vanes are photoetch but only 0.4mm so..
I packed each side with 0.35 plastic card, giving an overall width of 70mm more in keeping I feel
P1120574
P1120578
P1120603
P1120602 P1120604
Then on to the tow post which centered around the pump. So I thought it would be good to represent the pump handles
P1120585
P1120590
P1120593
P1120594
Kev
Love that pump Kev.
Must admit I was unsure what that post represented. I think it is described as a tow post in the parts list.
I swithered on using black grey but decided as I was not shading or highlighting flat black would do.
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
Thanks Folks for the kind comments and likes....
Hull a step closer with the rabbet strips fixed
P1120613
P1120615
P1120617 P1120618
A touch more blending but good enough for government work.
The bows of these trawlers were fitted with a roller for the trawl hawser. This is not represented in the kit so of course I had to add one :shrug:
This is not a reflection on the kit which is building into a fine model. The kit is designed as a starter and given my physical limitations I wanted something I could
tweak where I was able but still finish up with a fine model trawler.
Bow roller a combination of plastic and brass tube
P1120605
Horn made from an off cut of the wood sprue
P1120607
P1120610
P1120612
Room for a good clean up I feel
Kev
Painting the bottom ....
Hull prepped.a few irregularities in the planking showing a working  boat. Hull colour Vallejo Black-grey
P1120621
P1120623
I'm hoping to show her as a working boat so I used a Chocolate brown to represent the tar anti fouling.
P1120630
To take away the monochrome colour I used Oil dots. Grey, white, yellow ochre and raw umber. Blended and washed out with white spirit.
(I did use smaller dots the next time)
P1120634
P1120636
P1120644
I feel I achieved the look I was after
P1120645
A nice contrast
P1120648
I hope you like it. Thanks for stopping by
Kev
Thanks for the likes
Slow progress but....
Working the hull above the waterline
White, grey and raw umber oil
P1120654
P1120655
P1120657
Rudder temp. added with pin for strength. Note scupper line has had the stanchions picked out with shadow
P1120663
P1120662 P1120667 P1120666
Thanks for looking I hope you are enjoying the build
Kev
Very nice detailing and painting effects! 👏
Andrew
Completed (Kits):-
Only a few pics but big steps forward.................
Deck fitted. This has had numerous washes of lifecolour 'Wooden Grey Umber'
You can see the original maple colour where the boiler plate is missing
P1120669
Rubbing strake painted Vallejo Emerald knocked back with pale grey. The hair grips have been shortened on the inboard side
P1120671
P1120673
Thanks for stopping by and for the likes
Kev
Moving onto deck furniture....
Dandy wink. Used to hoist rear of towing beam
P1120688
P1120690
I chose to have the hatch boards open
P1120681
Drilled holes, punched disc to fit. Stretched sprue for handle
P1120683
Tissue/dilute Pva to make tarpaulin
P1120685
P1120691
Tarp, boards and metal bands to lock down the hatch boards
P1120693
P1120696
I hope you like the progress
Kev
Hey this colour scheme is getting better and better. 👍👏
Andrew
Completed (Kits):-
Glad you like it
On 7/20/2022 at 9:47 AM, Craigie65 said:
looks like a really hard working boat!
That's the way I'm hopefully going
Thanks for likes, it's good to have the support
Kev
Capping rail added
P1120704
Along with Taff rail and transit rail. I cut a new deeper taff rail to cover timber heads and transom trim.
P1120705
Rudder gets additional pintle & gudgeon above deck
P1120707
Dandy wink gets a Dandy Score (Scratch built). Roller fairlead for aft end of trawl beam
P1120709
P1120711
P1120712
P1120713
Current thoughts are having the Nisha dried out with beach legs and the Trawl beam resting on the the sand
Capture
Transom finished off with trim
P1120716
Kev
It's been a while due to health issues.
Before I go further with a tweak to the kit I'd like to state at no point do I think Chis Wattons kit is sub standard. It's a brilliant starter kit made to a price.
I've already got further than I ever have with a wood boat. Having been a scratch builder for many years, health issues were causing problems with dexterity and Nisha gave me a way forward knowing I could always fall back to kit mode.
Whilst browsing Edgar J March book I noticed that the blocks of the time were were internal strapped, So could I.....
The sides/sheaves built up in layers
P1120725 P1120728
and the ropes run
P1120729
Hook and eye formed
P1120734 P1120733
I had to anneal the hook to form it and wondered how to harden it. Gentle tapping work hardened it. Seems to work
P1120735
Seems to work
P1120737
So this may be the way forward for the large throat halyard and main sheet but can I manage the smaller blocks...
Kev
Hi, glad to see you back in the saddle and hope your health issues don’t keep away further. Take care.
Andrew
Completed (Kits):-
