Michele
How are you cutting the frames for the ship's boats?  These are quite delicate even at 1:48 so I was wondering if you are cutting the to shape or if you are soaking the wood and bending them around a form.
Thanks
Allan
Edited by allanyed
On 25/9/2022 at 08:20, allanyed said:
Michele
Come state tagliando i telai per le barche della nave? Questi sono piuttosto delicati anche a 1:48, quindi mi chiedevo se stai tagliando la forma o se stai immergendo il legno e piegandoli attorno a una forma.
Grazie
Allan
Hi, the spear ribs are cut the same way as the ship ribs.
I use a scroll saw for cutting futtocks of the ship's frames but for 1.48 ship's boat frames, which are about 0.032" - 0.80mm at the top even using castello boxwood, they break very easily before I can finish the sawing,  Do you use a power saw to cut the pieces or a coping saw, or a knife, or some other tools?
Grazie mille Michele.
Allan
6 hours ago, allanyed said:
Uso una sega a traforo per tagliare i futtocks dei telai della nave, ma per i telai delle barche da 1,48, che sono circa 0,032" - 0,80 mm nella parte superiore anche usando il bosso castello, si rompono molto facilmente prima che io possa finire il taglio, usi un motosega per tagliare i pezzi o una sega a tazza, o un coltello, o qualche altro strumento
Allan
I use the fretwork at minimum power and make the grain coincide with the knee part, precisely to prevent it from breaking. It is very delicate work but with patience it can be don
  • 2 years later...
Szia Michel!
Gémes Attila vagyok, Magyar hobbi modellező. ( H.M.S. Pandora 1:36, jelenleg Granado 1:36.)
Nagyon szép precíz munka, gratulálok!
A felület védelemről szeretnélek kérdezni.
A szerkezetnél használt körtefára, az írod hogy sellakkot és bitument használsz.
Pontosan mik ezek, és hogyan viszed fel a felületre? ( Ecsettel, rongyal stb..)
Légyszíves küldj képet!
Köszönöm!  Gémes AttilaPandora videó 1779.cr letöltés
