On 1/19/2023 at 8:49 AM, Craigie65 said:
Well recovered, you are nearly there.
Loving the paint scheme. If you think the white is too bright for the rubbing strake, perhaps an off-white might be more in keeping?
Thanks Craigie, you’re entirely right an off-white would be better - but I won’t be able to repaint it nearly so neatly now it’s attached to the model and has chainplates crossing the rubbing strake - I think I’ll leave rather than risk making a mess.
Dan
Current Build: Sherbourne (Vanguard Models, 1:64)
Previous Builds (All Vanguard Models 1:64):
Fishing Boats: Fifie, Nisha, ZuluSaucy JackErycinaRanger
Warships (and Yacht): HMS AlertGrecianHM Gun Brig Adder, Duchess of Kingston Yacht
Waiting to be Built: Speedy (Vanguard Models, 1:64)
So, Erycina is almost finished.
Main, mizzen and topsail added. Inner jib in the process of being tied on. 61590F6F-EB87-4D27-A61E-9A9E89529E80.thumb.jpeg.e2c5cc6f3db2d7cdd12d4a30aaac815f.jpeg1DC31FF2-600F-420A-8C2C-FADE51EAC528.thumb.jpeg.0e841f86c9439c1e2e030bc428ae7639.jpeg
Sails and rigging all added. Almost finished except for the stand and adding a few coils of rope next weekend. ECF97BC2-9DD9-4401-8251-C4F5DFA443EF.thumb.jpeg.188b4a4755cf684e9c0f6440acfc1932.jpegA13CA2A9-C925-44A2-977C-140D80E5A7D3.thumb.jpeg.91e778574c94c88b089acf608a4f8295.jpeg7A632CB6-26F5-418A-9B0B-711A7D97F977.thumb.jpeg.27fdb53c98d9451ea7ec489846cb7cfd.jpegFA1D0C90-A2B8-40EC-9CAF-54BF9CF01BBB.thumb.jpeg.5b5a74c85d86a7977b014bc494bcc3e5.jpegF5B8F827-DAEB-4237-BBE9-56F8D6205CDF.thumb.jpeg.9aaba794695205ad955728f091b3f625.jpeg
Erycina is welcomed to the fishing fleet. Only Ranger still to join.
The fleet, Erycina is the second largest after the Zulu.
With the two smaller trawlers.
6C7C9019-F041-46BA-9963-03E05F3F0C63.thumb.jpeg.73f0dcd646bd23d20443445ce54c4506.jpeg41168A53-F270-42A2-91FE-957B323E08FF.thumb.jpeg.28861d6575867e9a2055e78a6dbcd33c.jpeg
Erycina like the rest of the Vanguard fishing fleet was a great pleasure to build and her hull has some of the most pleasing lines of the fleet. Thanks Chris for another superb kit and James H for another excellent set of instructions and build log. Thanks also to the other Erycina build logs: Glennard, Niwotwill, Bowline and Craigie - a hugely valuable resource.
How did Erycina stack up compared to the rest of the fishing fleet? Under Chris’s new difficulty classification she’s rated “Amateur” which is the second level of difficulty above “Novice”. I think that he’s right.
Her hull was straightforward to build despite the lovely curved shape. But her rigging was a little trickier that the other builds. Part of it was just two masts, sets of shrouds, ratlines, running rigging, etc. This added complexity meant that for each piece of rigging you might need to refer to two or three plans not just one sheet to ensure that rigging was routed correctly and tied off at the right points. All the info is there on the plans, but on this build you had to look a little for it. For example,  I missed the set of blocks at the bottom of the top halyards on both masts and only added them later. This was a great learning curve for me as I head onto my first more complex build. The other added complexity is that, like Nisha, the plans are not full size and all measurements need to be scaled up.
I can’t recommend these little Vanguard boats strongly enough for someone new to the hobby, as I am, and with limited modelling skills.
Next I’ll be sticking with Vanguard but need to decide whether to build Ranger and complete the fishing fleet or challenge myself more and build a warship, Alert. I’m erring towards having a change and building Alert.
Dan
What a fine collection of vessels.  I am in the process of building the Medway longboat by Syren.  When complete I have decided to try my hand at the Lady Elanor.
14 minutes ago, Montaigne said:
Looking very good, well done!
Thank you!
Dan
Thanks, I really enjoyed the Lady Eleanor, I thought that she was the easiest build of the Vanguard fishers. Good luck with your build!
Dan
Those are lovely boats, Dan. The colours work well together.  You should be very proud of your fleet and your skills.
I think you would enjoy the challenge of one of Vanguard’s smaller warships - HMS Alert looks a sweet little model. With the instructions online you can always look to see how involved the build would be.
Cheers
Craig
Current Build
HMS Indefatigable
Erycina - Vanguard Models
Finished: HM Bomb Vessel Granado - Caldercraft, HMS Pegasus - Victory models, Nisha - Vanguard Models
What a great looking fleet Dan! Well done on another nice build.
Andrew
Completed (Kits):-
Thank you all for your very kind comments and encouragement. Alert it is next!
Dan
Last couple of photos. Erycina is finished.
D25C4C30-B69D-417B-A1A6-B2D2F0774F0C.thumb.jpeg.fdbe77850b4a3432c6919cb5a7a261e4.jpegDC80DD07-8E04-4B24-A2A6-CAC320AB2D17.thumb.jpeg.c10e0ec890c9cff5e70bf0176985c6ee.jpeg
Dan
3 hours ago, Dave_E said:
Very nice Sir indeed! 👍👍😀
Thanks Dave!
Dan
what a nice job and how well explained the progress, every day I like more and more these Vanguard fishing boats.
Congratulations
Greetings
Gus
Current build log:
San Francisco Cross Section
