Hello everyone !
Today I'm glad to present you my new project for the upcoming months (years?).
Context:
I may have been too ambitious ... 🤔
My initial plan was to choose a medium size kit after finishing my King of Prussia from Corel, for less than 300€. But there was the black friday at Occre, I saw this beautiful kit at -30%, at 370€ instead of 530€, I could not resist the temptation. I am now building the most complex ship from Occre, while I am a student in last year of civil engineering school 😅
image.thumb.jpeg.78b77da7986f367e72606388f7036b97.jpegimage.jpeg.1226240ca98e0bd70b6622382bb9242d.jpeg
For the historical point, the Montanes was a 74 guns Spanish ship launched in 1794 and wrecked in 1810. It participated in the battle of Trafalgar but was only slightly damaged and managed to return to Cadiz.
Objectives:
Besides finishing this model, I have set myself a few other goals.
The first one will be to illuminate the model with a method I've never seen before in model making, using LEDs designated for Lego sets.
Secondly, I would have liked to have a french 74 gun ship, but I only know one kit, Le Superbe from Mantua, which does not seem to be of such good quality. So, the goal will be to modify this model to be closer to a French ship, while keeping some details specific to this model, making a hybrid Spanish/French ship. The model as a whole will be a fictional ship, but I will try to make historically accurate modifications of some elements.
image.jpeg.fa3aefc4754fe7fc58f789d1ae4a92b1.jpegimage.thumb.jpeg.94624d412159f00c6438d3ebb964ee95.jpeg
I will base my work on pdf's from Jean BOUDRIOT's collection "le vaisseau de 74 canons' ' and many other build logs (Montanes, san ildefonso or Superbe) , especially on John Aliprantis' video series of the Montanes.
I hope this log will be interesting !!
The next post will be the unboxing.
Unboxing
First of all, I don't find the box very interesting, it's just a picture printed and glued on a cardboard box.
Inside, everything is well organized. There are 4 plastic boxes inside :
IMG_20221216_204122.thumb.jpg.4d8cdba8358e8c6f92148a4f750cec37.jpgIMG_20221216_204115.thumb.jpg.4623571679e49cea200f6a20f606eee9.jpgIMG_20221216_204101.thumb.jpg.fcd71b4d44bf9e85613a15878a7131aa.jpgIMG_20221216_204129.thumb.jpg.a40d96306fae351f93d73498ef79612a.jpg
+ Lots of details, the pieces are quite clean, in wood and diecast. The door and window frames may be replaced in wood.
- The cannons and carriages are in diecast, which is not very good. Moreover the barrels are not completely drilled, I think about buying better barrels.
Good surprise, the pulleys and pins are made of wood! Occre uses a lot of composite on other kits, but it's not very nice.
There are a lot of pre-cuts, and a big pack for the hull structure.
IMG_20221216_204328.thumb.jpg.2475e88d24aa03dd5fef6929b2d7f63a.jpgIMG_20221216_204310.thumb.jpg.f97c04969824ba812a61e46c607e444d.jpgIMG_20221216_204302.thumb.jpg.f125abfe7acfef78b8031efd49431939.jpg
And here's the bunch of ropes, different colors and sizes, I hope there's enough 😅!
Then the set of wood rods, lots of basswood, sapele for the submerged hull and some walnut:
Finally, the set of sails (over 20 sails!) Hand sewn:
And as a bonus, the led kit I found on Aliexpress, 2 receivers of 10 led each, and so 20 led color yellow/orange. It's basically for Lego, but their small size and ease of use are ideal for model making! It cost me less than 20 €, and will not require soldering.
The Christmas holidays were very productive, I was in a rush to get as much done as possible before going back to school, so here is a summary.
I started by carving the structure before gluing everything, to make 2 false decks under the gratings which will be illuminated. I drilled a lot of holes for the wire runs. The protection of the oven was scratch built.
IMG_20221217_085349.thumb.jpg.003d9a00378c50044983ba6208f66bff.jpgIMG_20221217_094047.thumb.jpg.098521072b72f8890580850c3059a01f.jpg
IMG_20221218_093622.thumb.jpg.0022c23666d8499d23b752edb517c09d.jpgIMG_20221219_141712.thumb.jpg.b83a540825a0209f98a175cf7c337ee3.jpg
To save glue for the decks, I tried double-sided tape, with a few dots of glue, and it works! The joints were simulated with a pencil, but for the most visible bridge, I cut 8 cm planks, to show the joints and to have different textures between 2 planks end to end. It was very long but the result is much more realistic.
IMG_20221220_215300.thumb.jpg.781888bfd7be022baab42217c4776d90.jpgIMG_20221227_100342.thumb.jpg.aac13f270d44558616a10e0d45a09007.jpg
 As the stern will be illuminated and visible, I printed a tile pattern (drawn on Sketchup), as well as bulkheads, which won't be too visible. This result works perfectly for me! I added a small table with 2 chairs, and I replaced the portholes in windows on each side.
IMG_20221222_151035.thumb.jpg.9df6aadc76555faf2cb8c79f95be54c1.jpgIMG_20221222_182254.thumb.jpg.3a816bcaaaa8087c12ff6f13afbe0a1f.jpg
IMG_20221231_184704.thumb.jpg.85f4e3e7e3911d3a663c2f34e20799dc.jpgIMG_20221223_191316.thumb.jpg.aa256d504d88e7b47a1833394fb02365.jpg
The bow structure was reinforced to have a better support for the planking, which required a lot of sanding...
IMG_20221224_165249.thumb.jpg.19cfc6f9f830152bdabad9b95b81d7cd.jpgIMG_20221224_111500.thumb.jpg.4ca1cdfa2740cf26373220dde5ba8d43.jpg
I relocated a window in the stern by raising it, which was low to the deck ( just like on the real ship) and I didn't like it, so I aligned it with the other smaller ones. Also, I have started to build the interior bulkheads, but I am stuck because I have lost a window...
IMG_20221229_193817.thumb.jpg.7f8a8322c39784cfae07bfbac2401f1e.jpgIMG_20221230_183824.thumb.jpg.5164b9722362f24f6c5c014c8aa2c7a3.jpg
IMG_20230102_142728.thumb.jpg.56e9b63b9d686e78e9f6370ac86fb73b.jpgIMG_20230101_022901.thumb.jpg.9bc872c0432ac7698e5ea6d36b6519a8.jpg
To blacken the brass, I used AK burnisher. The reaction is a bit slow but with only a little bit of product, I was able to burnish all 140 rings as well as some diecast parts!
IMG_20230101_132200.thumb.jpg.5a62451e99ad39d103fefc6c34398a43.jpgIMG_20230101_134836.thumb.jpg.d6078991427aa31f2ab1ebfdad91794f.jpg
Here is the progress in 2 weeks, I'm very happy with the result with the LEDs, I'm sure it will be the future masterpiece of my collection!
Thank you Gary !
On the stern, the posts were ruining the view and were not really useful to support the upper deck, I removed them to the base to keep a point of attachment to the sternpiece.
The bulkheads required some extra work to run and hide the cables, but the result is worth the effort.
IMG_20230107_105802.thumb.jpg.3adca859daee9312825962dee111472d.jpgIMG_20230107_160135.thumb.jpg.ba89f7bb2f63649e7af7843fa1299311.jpg
IMG_20230108_203744.thumb.jpg.bb9db8902e65bd8bd8d628fcd9423c11.jpg2.thumb.jpg.b0d22acc2851797e343a38cce963b91b.jpg
Work has progressed on the bow, with the planking (+ walls on the ports to add some depth). You can see here that the pre-cut deck piece is not aligned with the gunport guide. I chose to add some material to compensate for this. The surface for guiding the gunports needed a lot of sanding before planking. One day to sand everything is very long ...
IMG_20230115_181228.thumb.jpg.86999731e3c48faec8d2711ad863d481.jpgIMG_20230116_094241.thumb.jpg.df03625dbc0e2455680c2dbac5485e1a.jpgIMG_20230115_093438.thumb.jpg.114d7c1c4f2f646c3b65e59f88675a70.jpg
I finally designed guides from the pre-cut leftovers to drill the false walls in the middle. Here's the epic result with the raw barrels :
I hope to start soon the planking, the step I'm fearing the most, especially since it's a single planked kit...
IMG_20230116_182831.thumb.jpg.430aec2b91e2a3ee69bc372a221bf30b.jpgIMG_20230116_195418.thumb.jpg.4cd52be7c39d3b58ca2c035df63f3e28.jpgIMG_20230116_195635.thumb.jpg.d5a54c5c0f046afeb2c18fa0eeb5bd8c.jpgIMG_20230117_082759.thumb.jpg.030e1bf3f65df106d63cc3867426f274.jpg
After a lot of sanding to adjust the gunports guides I started the planking. It was quite hard to align the first plank, which is crucial for the rest of the planking. I also had to think about the placement of the stringers on the deck: I like the guns to pop out of the hull, but the stringers prevent the carriage to be against the wall. So I improvised by cutting the stringers at the position of the guns. The inside of the walls was painted with the iconic red.
IMG_20230120_200100.thumb.jpg.50df264dbb068109217f6746b6189bc3.jpgIMG_20230121_151930.thumb.jpg.ef8f0e398a45cb0d0b50109e07bc38f7.jpgIMG_20230123_094139.thumb.jpg.2bc2d042c5905f5e0546458f6b4283e7.jpgIMG_20230121_201829.thumb.jpg.b2ffaa36e6d48c2e24ee3fcffee480e0.jpgIMG_20230123_133401.thumb.jpg.2cf937ea609f00b66b3edd8c047887f2.jpgIMG_20230129_175204.thumb.jpg.0e0883b0c93995008a1b6529317162c6.jpgIMG_20230129_210022.thumb.jpg.7c5a4d465706bb38873e5222fac764f3.jpg
  • 3 months later...
Hello everyone,
It's been a long time since I've posted anything, but I've made a lot of progress on my ship! I've finished planking the entire hull, which was EXTREMELY time-consuming, as it's very large. The instructions don't describe how to do it, so I had to improvise the planking to get a nice hull. At the stern, an electric bender is necessary, as the curve is very pronounced. To avoid gaps between 2 planks, I apply wood glue to the edge, removing the excess after fitting. If any holes remain, I fill them with wood glue and sand around them, so that the dust goes into the glue.IMG_20230204_094941.thumb.jpg.ce6dd2268cda80af591169f1c4420e45.jpgIMG_20230216_170152.thumb.jpg.5706729d6219fed1a64648df141f3499.jpgIMG_20230415_125526.thumb.jpg.8433f70f9acd051ead8ae349cde1e788.jpgIMG_20230415_125617.thumb.jpg.4f230eb18d24f8b823ad5125fce6c1ad.jpgIMG_20230415_125854.thumb.jpg.0190909ec2932ed96dfb02456d24823f.jpg
Once the hull was finished, I painted the upper part in occre and made the wales. The kit includes 2x4 rods, but this seemed too wide to me, so I used leftovers from a previous model, in 1x4. The result seems much more realistic, and the installation was much easier! Next, I painted the model in the classic blacks of the era, and then took the liberty of painting the upper part in royal blue.
To add realism to the breakwater, I used a cutter to simulate the wood joints.
For the gunport frames, I swapped the 1x4 sapele for 1x3 deck leftovers, which adds depth and is much easier to paint and trim. I also used a cutter to mark the space between the occre-painted planks. Finally, the hull was varnished.
IMG_20230520_210200.thumb.jpg.f7f09c73c69f5588fe620e506a08db5c.jpgIMG_20230528_115106.jpgIMG_20230527_113512.thumb.jpg.77785027ddf296e27ef5142e49c23b2f.jpg
Please let me know what you think, and if you have any tips!
Edited by Iseaz
  • 3 months later...
Hello again,
I've spent a long time without posting but I've made good progress on the hull. I've already finished the outer lines, and I've got a spiral decoration using a 2mm thick piece of round wood with holes carved in it, which looks better than twisted brass wire.
Bow :
I hesitated for a long time about the colour of the wooden elements, between black or the "natural" colour. The occre-coloured curves are 1x1mm, extracted from the remaining 3x1mm strips. I love working with 1x1, it allows me to add a lot of relief on a small scale, like on the frieze above the doors. For the anchor holes, I added blackened brass circles, also to add relief, and the result is superb! Below, I used a twisted decoration: 2 brass wires wound with a drill, then flattened with a hammer, then painted in occre. I'm really pleased with the way the bow looks - the curves are magnificent!
Stern:
For the balcony, I started by cutting the hull right up to the wall, and added a plate for a cleaner result (it was very difficult to cut in this space). The bottles are very complex to make because of the general shape, and the photoetched parts had to be adjusted to follow the curves correctly.
The back panel was delicately painted and placed on the wooden piece. As there's very little relief, I added walnut-coloured 3x1 columns on the windows, and strips around the panel, for a clean finish. After struggling to paint all the columns, I glued them in place and the result is superb!
IMG_20230709_165022.thumb.jpg.f121f114cc0987ca787170a0864f04ab.jpgIMG_20230813_190417.thumb.jpg.0dfeaafcb41c04e3d8a2438f0ca012dd.jpgIMG_20230819_090825.thumb.jpg.c7aa7e2622ef2611f1ff93b4be827c05.jpgIMG_20230917_100427.thumb.jpg.008718941fe1e85da1be0b0714b125c5.jpg
Cabin:
I have no idea what this cabin is for. It's not planned in the kit, but I've opened doors and windows to get a look at the illuminated interior. If I get the inspiration, I'll add some details on the outside walls...
IMG_20230831_131813.thumb.jpg.878bb1aff55bac94e3f2405cf5324897.jpgIMG_20230828_102732.thumb.jpg.9aab33b40d61918eacfd6e6dd877f2f7.jpgIMG_20230831_130332.thumb.jpg.def5596d728cddf0b4130fd1b2671dcc.jpg
Cannons:
Certainly the biggest flaw in this kit... badly moulded, undrilled cannons, simple carriages that are impossible to drill, and no wheels for the 8 cannons on the 2nd bridge, which don't even look like the other dummy cannons on the 2nd bridge. Using scraps from other models, I was able to fit the missing wheels. Unfortunately, if I wanted to replace them with brass cannons, it would have cost too much...
The gun ports took a long time to make, fortunately only the first bridge has them!
I still don't know what angle I'm going to give them. I've also added scratch rings to attach the rope to the gunport
IMG_20230831_130616.thumb.jpg.cfb714a3cf076ef6e7f504fa0e586a8e.jpgIMG_20230920_170131.thumb.jpg.3c8b8f5ce2bf1c228b056e0f74c6e862.jpgIMG_20230922_123309.thumb.jpg.9648d1647e0955e902a82f6fb0e27eb0.jpg
It looks like it may be too late on this project but did you look at printed cannon?  I have purchased them at 1:64 for about $0.75 a piece including shipping (in the USA).  I sent an STL drawing of each size to the printer and had them back in about a week.  They are as detailed as the drawings including the cypher even at that small scale.  I have 2D drawings of various size Spanish barrels used circa 1765-1808 and 1718-1765 but we have not gotten to these in 3D yet.   You are welcome to the 2D if you want to get them done in 3D drawings so you can get them printed.   A larger scale printed British barrel of 1760 can be seen https://modelshipworld.com/topic/35120-armstrong-frederick-cannon-by-allanyed-124-scale/ to get an idea of the detail.
Smaller scale pieces are below in the British Commonwealth pattern circa 1650-1716  Note the conical trunnions for that period.
Allan
  • 6 months later...
Hi, it's been a long time!
Not many posts but the work continues, slowly...
I've made good progress on the hull, the shroud supports, the bow and the stern
I've also done the longboat, which was harder than I thought!
I'm very happy with the improved crow's nest, which looks much better than the solid part supplied in the kit!
I've also made good progress on the mature, all the elements have been cut, except for a few yards, as there aren't enough parts in the kit (and I should have optimised the rods to make 2 masts...). I improvised a tool to turn the wood... not incredible but it helped me a lot
Nothing's glued yet because there's one big subject I'm undecided about: the cannons and their carriages. I don't really want to fit the masts before the cannons, it would be too much trouble...
IMG_20231110_220807.thumb.jpg.974a93755b9e00b9272f5850618613ae.jpgimage.thumb.jpeg.170ad6bb8c734d912c8a3269b008ffdc.jpeg
IMG_20240127_171115.thumb.jpg.90f0baee7a5ac5d9157cdace9a804b64.jpgIMG_20240203_134507.thumb.jpg.5ce542b41b872d79680c345837dd14d7.jpg
image.thumb.jpeg.4d25c0bf2441b7f584b56c21bd37472e.jpegIMG_20231112_164511.thumb.jpg.86c503bbde3b35d486815b6553fa8d35.jpgIMG_20231230_201004.thumb.jpg.c04b70f930fec121cfeea052f4cc2192.jpgIMG_20240331_113327.thumb.jpg.df397ddcb9320a5af6e49645c4ba2071.jpg
  • 5 months later...
Slowly but surely, construction continues.
Cannons
Cannons on the deck glued and rigged, I've found a solution to glue the rings, as the carriages are impossible to drill. I looked at many resin options, but unfortunately they were way too expensive...
Bonus: a magnificent calculation of shroud right in front of a gunport!
IMG_20240526_154431.thumb.jpg.4715ef6d32708ce33d80bd4ecd8c17ee.jpgIMG_20240824_095406.thumb.jpg.1884e9a6f957b584e6a7c6793bfee626.jpgIMG_20240609_170604.thumb.jpg.5874edd8253205b08f41fccde0715b4f.jpg
Masts:
By cutting a gap in the mast, I managed to pass the lantern's calble through. But I still have no idea how I'm going to make these lamps...
IMG_20240525_151028.thumb.jpg.5f021c56ac7763b05272720c753aed26.jpgIMG_20240526_154332.thumb.jpg.0318647ab044f1382d1ac6a11938abd3.jpg
Next, the yards:
IMG_20240901_120741.thumb.jpg.04118880de5aedea06dfb43e8c8d4364.jpgIMG_20240901_145924.thumb.jpg.fefec1010cdd19e53919186d61cb8964.jpgIMG_20240831_115819_1.thumb.jpg.1e36afc0798d64d27386854975986fdb.jpg
I can't finish the main mast right now because I'm missing some deadeyes (well, that's my fault) and I have to ask Occre for some, in addition to 2 6mm rods and 4/5 3mm rods (they're missing from the kit). I'll wait a bit before asking, as other parts may be missing, so I'll keep working on the rest before I'm really stuck.
I'm also waiting for as much time as possible before gluing the bowsprit, it's so big that I'm removing it to avoid breaking it.
At the moment, I'm spending a lot of time studying the rigging plans: there are mistakes, too many or too few pulleys, and it's not always very clear.
For the ropes, I need some “fabulon” product to remove all the ugly fuzz. I'll then use it to give wind to the sails.
And here are a few nice photos taken on a (last?) sunny day:
IMG_20240915_143448.thumb.jpg.3187bde8c9407ce4304a81d55ca61096.jpgIMG_20240915_144150.thumb.jpg.217199bc0b3719fb97aaa116dd09d23b.jpgIMG_20240915_143903.thumb.jpg.e10f5d2bd4999a6db28b8574822c9f66.jpgIMG_20240915_143756.thumb.jpg.677ea9459486acb0062e3eda8c81fe9b.jpgIMG_20240915_144253.thumb.jpg.baace9358caa30cc5f92ee85a2700291.jpgIMG_20240915_144300.thumb.jpg.cd1dd52e580e014b450141826a57fbe5.jpgIMG_20240915_144305.thumb.jpg.14039bab2fb65b4679b3e3577c5329fb.jpgIMG_20240915_144445.thumb.jpg.1a92098088071364e640ab538f0f41e8.jpgIMG_20240915_144437.thumb.jpg.88a3930c18ceb2ea273dfb0c2afda610.jpgIMG_20240915_143727.thumb.jpg.e69f4561b658256d11f28e4d0948823f.jpgIMG_20240915_143659.thumb.jpg.44f3d4c3c56abd30f8cd1635f494e3fb.jpgIMG_20240915_143722.thumb.jpg.12ffb70f04751884859b956467452f91.jpgIMG_20240915_143716.thumb.jpg.09e866b82c939ed04a6d843a57451323.jpgIMG_20240915_144330.thumb.jpg.1efa9b8c9500bcd2437f1c016c36e8a6.jpgIMG_20240915_144500.thumb.jpg.543fef451cdeb992a8b55d59df858335.jpgIMG_20240915_143854.thumb.jpg.15fc748cf67265d0f6694efd499444c9.jpgIMG_20240915_143851.thumb.jpg.f33fc49afa884a2f7734885fcbc7d947.jpg
  • 7 months later...
