Unfortunately I stuffed up either my measurements or my gluing of the landing strakes and the sheers don't overlap the landing strakes properly. There should be a 1" (scale 1/16") overlap the full length but I finished up with zero overlap at E, F, G and at the transom. The stem and midships are fine. I Ummed and Ahhed for some time and finally decided to add some packers to make the sheer sit at the same height it would be if it overlapped and then when I fit the fender it will hide everything.
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
19 minutes ago, iMustBeCrazy said:
Glad your back, hope the eyes are good now.
That planking looks really good, what is the finish you used?
Tim
Current Builds :
Cutter "Speedy" 1828 from Plans by Bill Shoulders at 148
Bounty Launch - Scratch build - FINISHED
85 ft. Harbour Tug. scratch built  from plans by Francis Smith. ( FINISHED but no build log for this )
HMS Lightning. kit bashed from Deans Marine HMS Kelly kit ( FINISHED ) yes at last....
Thanks Tim, they seem to be.
At this stage it's just a rough coating of shellac to seal it.
Craig.
  • 2 months later...
Finally back to it, sheer strakes fitted and painted. Tomorrow I will find out if I've glued her to the mould.
Craig.
Ok, ok. I couldn't wait. She popped of pretty easy, just snagged a little on the plywood tabs holding the frames (see post #33), the cling film (saran wrap) worked great.
A small amount of excess glue and I over bevelled the planks a little but otherwise she's good.
Craig.
Debating what to do about the colour scheme.
The exterior I will probably paint white or white below the waterline, the interior I'm going to leave 'natural' but the wood seemed a bit too light (see first pic in the post above) so I took some shellac and added a touch of spirit based stain and brushed it on. Seems to have done the trick nicely. The stain bled through the plank joins in some places, but only enough to darken the seams a little. I could leave the hull with the current shellac finish without anyone noticing.
Craig.
Mocking up the interior:
Craig.
Update time.
Transom knees fitted, floorboards fitted, windlass chocks fitted, cap rails and thwarts made, windlass made.
To do: Foredeck, there are several valid options but I think I'll go with framed with longitudinal planking.
           Thwart knees, iron or wood? Both the Bountys launch and large cutter had removable knees (and bolts), the cutters knees were stored in a carpenters chest - wooden knees would take up too much space so they were almost certainly iron - but the launch?
           Fender below the sheer strake.
           Cant frame in the bows.
           Mast steps and brackets, round or square lower mast? The drawings usually show round, the models square.
           Masts and sails.
           Oars.
           Rudder.
           Other stuff, probably.
Craig.
Fenders and port cap rail fitted. I need to finish the interior before fitting the starboard.
Craig.
On 6/8/2023 at 11:00 AM, iMustBeCrazy said:
Update time.
That has turned out fantastically, congratulations.
Gives us all something to strive to achieve.
Tim
Current Builds :
  • 1 year later...
On 11/12/2024 at 4:07 AM, AlfredoCampos said:
I noticed this build of yours which I had not yet seen. Absolutely beautiful and so inspiring!
Thankyou.
Craig.
