Not having seen the plans, I really could not say.  But I do think that problems arise with the rigging if people are not sure of the purpose of each line.  The rigging of these ships is actually very straightforward and logical if you think about what is needed to control each yard and sail.
For instance, look at the various rigging plans that omit the sheaves or holes for the tacks and sheets, or have them leading in on the wrong deck.  The tacks and sheets are coming from points far outboard of the ship.  It would be a very poor lead to bring them directly over the gunwale to a cleat.  Therefore they must come through the hull at some point.  Also, on the Constitution at least, there were no lines worked from the gun deck so plans that show them leading in there are incorrect.  Now, you may notice that the tacks and sheets seem to rub against the shrouds at times, but consider that they would only do this when the course was clewed up or furled and therefore there would be no tension on them.  When these sails were set the tacks and sheets would run far enough outboard to clear everything.  A line called a "timenoguy" was sometimes rigged from the top of the anchor stock to the side of the ship to keep the fore tack from falling behind it and getting fouled.  That would be the closest thing in concept to what was described in the posts above.
Any line that does not give a fair lead for it's intended purpose is probably wrong.  The Bo'sun would probably flog the sailor that did that.
Henry
Laissez le bon temps rouler !
Thanks for the info Henry. That makes perfect sense to me. Research---Then research some more.  B)
GEORGE
Now you all see why my rigging has slowed down.....I must figure out how these square riggers sailed. I'm reading all the Patrick O'Brian books starting with Master and Commander to help me, as well as all of you. Thanks!
Rich,  It's not all that difficult.  Once you figure out one yard the rest are the same.
You need something to hold the masts up: shrouds, stays, and backstays
You need to raise the yard = halyards or jeers
You need to hold the yard in to the mast = trusses or parrels
You need a line to control moving the yard horizontally = braces
You need a line to control the yard vertically = lifts
You need to hold the corner of the sail down = sheets and tacks
You need to haul the corner of the sail up = clew
You need to gather the foot of the sail up for furling = buntlines
You need to gather the sides of the sail up for furling = leech lines
There are variations in style and detail from era to era but the basics stay constant.
Fore and aft sails are slightly different:
Hoist the sail = halyard or uphaul
Lower the sail = downhaul
Hold the corner of the sail down = sheet
Some stay sails were trapezoidal so they had another line at the lower front corner = tack
Regards,
Edited by popeye2sea
Henry
Regards,
Thanks, Henry
Well my rigging is progressing very slowly while I learn "the ropes". However, since all my rigging works...that is, all the rigging can be adjusted, I don't want to tie anything down until it's all rigged. What to do with the "rats nest" I've created?
I took Bill up on his idea to just remove a belaying pin and run the line through the hole then re-insert the pin. It works great!
Edited by Hipexec
If you want great reading about the ships we build, check out Patrick O'Brian's Master and Commander. It was very good. Now, I'm on his second book.
Got the DVD. Great movie! :)
GEORGE
Well here is a Connie connection for M&C from IMDB.
The French frigate "Acheron" was modeled after the USS Constitution ("Old Ironsides"). The film crew spent quite a bit of time taking pictures and filming the Constitution. The images were then digitized to make the movie. Originally based in Providence, Rhode Island, The HMS Surprise was actually the HMS Rose, a reproduction tall ship built in 1970 at Lunenburg, Nova Scotia by Smith and Rhuland Ltd. The film crew made several alterations to its design to match the 1802 design of the HMS Surprise. The Rose/Surprise has been at the Maritime Museum of San Diego since 2004, but in previous years the HMS Rose was available for tall ship cruises.
Bill
Chantilly, VA
Its not the size of the ship, but the bore of the cannon!
Current Build: Scratch Build Brig Eagle
Completed Build Log: USS Constitution - Mamoli
Completed Build Gallery: USS Constitution - Mamoli
Didn't know that. Think I'll screen the movie again and take a few freeze-frame, screen-shots of the Acheron, then look for similarities.
GEORGE
Here's a screenshot of the Acheron's stern, as seen by Russel Crowe looking through his spyglass right after receiving a broadside from her.
Edited by GLakie
GEORGE
Didn't have any intention of bringing that up any more. A lot of time and effort, that always ends with the same conclusion. Builder's choice. Besides, it's just a movie, and that was the first shot of her.
GEORGE
Slow and not very sure rigging progress. I now have to buy some very long tweezers and sissors since it's getting very hard to reach into the inner recesses to attach lines to belaying pins. I have drilled some sheaves to run lines through the gunwales.
Edited by Hipexec
Looking good Rich! Micro Mark has just what you're looking for. Long-reach rigging hemo-stats for clamping and the same style for cutting.
Cheers
GEORGE
Rich I use these to get into the small spaces especially the belaying pins http://www.modelexpo-online.com/product.asp?ITEMNO=MS111-A I find the a great help
Jack
Current buildUS Constellation
Now that I've rigged the two foresails (jibs) according to Constructo's plans....I'm puzzled why they hang like staysails instead of being run up and down on jib stays?  How are the actual jibs on the real Constitution set?
The jib sails are fastened to the stays with hanks or loops through the edge of the sail so they can slide up and down the stay. I can't explain it as well as a picture can.
GEORGE
Here I'm practicing making a splice to a stay. The rigging plan calls for most braces to be rigged with a block and a line spliced to a shroud.
The braces were not spliced to the stays.  They were seized.  There is a difference.  Splicing involves tucking individual strands of the rope under and through the strands of the stay, while seizing involved lashing an eye in the end of the brace to the stay.  Each gives a much different appearance to the finished work.
Henry
Was not sure if my saying that would be taken as a bit off-putting. Sometimes it is hard to know if one is crossing a line or not. But it really makes a big difference in appearance.
Henry
These are great plans...I shall refer to them the rest of the rigging progress. Thanks
I'm stopping rigging the square sails while I rectify the Constructo omission of not telling me I needed jibstays. I should have known better since I sailed for several decades on modern fore & aft rigged boats. They all had jibstays.
I placed a rubber absorbent mat under my work area to "catch" fallen tiny hanks. I dropped most of them and it caught all but one. Goodness knows where all these little dropped parts disappear to.
Now that the brass hanks are on the jibs...I shall attempt to install jibstays.
It's not a problem for me Rich, but because of size and copyright issues I couldn't put the entire thing up. Those are some good looking sails.
GEORGE
