On 8/26/2023 at 5:43 PM, Roger Pellett said:
I am thinking of using scored deck planking for wooden hatch covers on my present project.  Planks would be 6in wide or 1/16in at scale.  I have found some Model Shipways scored basswood with 3/32in planks that might work.  My question:  how thick is this decking?
Roger
My experience is roughly 1 to 1.5mm.  You'll want to back it if you plan on using it for full decking.  I use it often on my builds.  Saves loads of time.
Rob
Current build:
Finished build:
Current build(On hold):
  I've been looking for a source of scored planking for a while ... now I know to look for it at Model Shipways.   THANKS !
Thanks!
I was thinking of using it for the wooden hatch covers for my Benjamin Noble Lake Freighter Model.  The builders drawings specify 2in x 6in white pine planking for each hatch cover and there were 12 hatch covers per hatch.  At 1:96 scale each plank would scale 1/16in wide by about .025 in thick.  I could probably sneak by at 1/32in.  I have since decided on another approach.
Roger
I had won a model competition years ago and the grand price was a large selection of model wood products from Model Shipways.  I got sheets upon sheets of the scored decking....its fantastic stuff for all kinds of modeling.
Rob
Current build:
Finished build:
I think R/R shops has what your looking for. I remember when living in Spokane one the shops had such for scratch build buildings. Don't remember the manufacturer.
Respectfully
Odd Model Shipways doesn't list the thickness. Bluejacket scribed deck sheets are 3 1/2 inches x 24 inches, 1/32 inches thick, various size plank widths. I have used them, good quality.
    Well Roger, for some more authentic-looking (because the grain varies from plank to plank) wooden model ship decking or board-by-board siding go to Micro-Mark.  Black glue is used to bond individual planks of basswood together side-by-side in sheets 3 inches wide x 22 inches long x 0.050 inch thick, perfectly simulating the look of board-by-board construction without the tedious, time-consuming hassle of doing it yourself.
    Planks widths are available in 1/16 inch, 3/32 inch, 1/8 inch, or 3/16 inch.  The price is around $25 per sheet.  Have a look here.
Dave
“You’ve just got to know your limitations”  Dirty Harry
Current Builds:  Modified MS 1/8” scale Phantom, and modified plastic/wood hybrid of Aurora 1:87 scale whaling bark Wanderer.
Past Builds: (Done & sold) 1/8” scale A.J. Fisher 2 mast schooner Challenge, 1/6” scale scratch built whaler Wanderer w/ plans & fittings from A.J. Fisher, and numerous plastic kits including 1/8” scale Revell U.S.S. Constitution (twice), Cutty Sark, and Mayflower.
                  (Done & in dry dock) Modified 1/8” scale Revell U.S.S. Constitution w/ wooden deck and masting [too close encounter w/conc. floor in move]
Hope to get to builds: MS 3/16” scale Pride of Baltimore II,  MS 1/2” scale pinky schooner Glad Tidings,  a scratch build 3/16” scale  Phantom, and a scratch build 3/16" scale Denis Sullivan.
  The store's location looks drivable from the Philly suburbs - maybe 2 1/2 hours.  If I accumulate a shopping list it may be worth while to go there.  The black-glued ship decking is likely done by 'sandwiching' sheets of basswood with a thin layer of dark bonding material between the layers - then pressing the stack while the glue cures.  The resulting slab (3" thick) is turned on its side and the decking sheets planed off (0.50" thick) like flitch-cut veneers.
  There may be places here and there where there is a little glue penetration into the wood (depending on the peculiarities of how the grain ran in the component sheets), but the look at a distance seems great.  I'd want to go there and see the sheets first-hand before laying out $25 per sheet.
Roger, also check out Northeastern Scale Lumber. They produce a wide variety of scale lumber and scored sheets that simulate various planking and siding styles. Lots of people in model railroading use products like this.
Another option is Mt Albert Scale Lumber on the Fast Tracks webite, here at: https://handlaidtrack.com/shop/?v=7516fd43adaa&wpf_filter_cat_list_0=2902
Ken
Started: MS Bounty Longboat,
10 minutes ago, OllieS said:
I wonder if for the scale you are using thick paper or card would be so much easier.
It has been t least a decade since I messed with it, but a 3D graphics render of a wood texture.   A flat rectangle would have a perfect map - no distortion from wrapping around a tube or sphere.  There should be excellent free textures or take your own photo of wood.   Print out the render - glue it to veneer or card stock - touch up with paint.   This as an alternative if you do not think that you can do your own de novo  wood texture just using artists oil pigments.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
