Hi all,
After some time into the build i decided to create a build log of my progress on the sergal cutty sark 1:78.
This is the first wooden ship model i am building, so everything is new to me and this forum was and is a blessing
to me to learn all the tips and tricks of building ship models. The sergal kit comes with very little instructions, only
about 4 pages of text without pictures, and a lot of real size plans. Not ideal for a beginner like me so im getting the "know
how" else where. I also bought the Campbell drawings of the real ship, which help me to add detail.
I started this kit in 2015, but after planking one side of the ship it stayed untouched on my shelf for about 6 years.
Suddely i felt an urge to continue the build, and i did not stop since. Its going very slowly due to working a full time job.
SO hope you enjoy this build log, and im looking forward learning from all of you fellow ship builders.
I had to take some time to think about how i was going to plank the stern. The instructions say just to put vertical planks. But on the real ship to upper edge of the stern is straight up , the inclined planks only start below that upper edge. So i constructed 2 extra frames on which i could attach a bended plank from left to right.
I left it in water first, and dry fitted so it would take the correct curvature of the hull. Then glued it afterwards in place.
Then i sanded the hull, and i marked the areas which required levelling with putty afterwards. So that the hull will be nice and smooth
One problem came to the surface: back in 2015 when i planked the first half, at the stern and bow section i didnt cut deep enough into the keel so the planks would be flush with the keel.
I first sanded the planks down, but then they became too thin to provide a solid background for the second planking. SO i could only remove that section of planking, cut deeper into the keel and reapply new planking in those areas:
  You've got something good going there.  The use of small wood blocks for clamping the second planking (with the wood clamps temporarily nailed into the 1st planking below) is novel ... I'll have to remember that in future.  Your re-do at the bow and stern of the 1st planking was well thought-out and resourceful.  No doubt you'll have a great model in the end, however long that might take.
Very nice job with the planking.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
  • 3 months later...
Looking very good!
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
Hi Hostez,
Wow, such a beautifully planked hull. Seems a shame to hide it under paint and copper tiles. That said, a black and copper hull look fantastic! All the best going forward!
Peter
Edited by petervisser
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
On 6/1/2024 at 11:14 PM, petervisser said:
Hi Hostez,
Peter
Thank you Peter
On 6/2/2024 at 1:25 AM, Kelp said:
The planking looks great!  This will turn into a very nice model.
Don
Thank you Don!
So! Time for another update. When i looked at old pictures of the real ship when she was still in service i saw that on the waterline and below it there were two strips guiding the copper plates. So i added those too after marking the waterline. These strips were cut from strips of deck planking and cut to shape.
After having a final check on the hull i applied pitch black alcohol ink to paint the hull black instead of real paint. That way the wooden planking is still visible.
This i will protect with shellac later on.
Nxt step is installing the copper plates. That will be a new adventure :)  Just doubting if i will weather the copper plates using burnishing fluid  or leave them fresh.
Edited by Hostez
  An interesting picture of the C.S. hull.  Even at this close distance, the metal plates appear to be 'wafer thin' compared to the hull size, and one can't really see any indications of nails holding the plates in place.  I suppose one could simply glue on paper 'plates' that overlap, then paint as desired. The Hulme model doesn't bother with nails.
Hi Johnny, in this picture you see more in detail the copper plates after polishing where the nails are visible.  I got a full set of clinkered pre cut copper plates with my kit. They look realistic so im going to use those.
Edited by Hostez
These are the copper plates im going to use, im going to test some tiles with burnishing fluid to see how it looks good with some weathering. How would you guys prefer it? Clean polished copper or weathered?
Well you don't want the nails to protrude like rivet heads.  You're doing so well....don't make that mistake.
Rob
Current build:
Finished build:
Current build(On hold):
