Was debating doing a build log for this older kit that was given to me from my brother, as he received it from a co-worker that had recently passed away, and wished to pass it to him and thus to me prior to his passing...
It is classified as a beginner build but these "beginner" kits from Billing Boats are in my opinion so basic in design and parts and given the poor tolerances for fitting out of pieces and parts, that it in fact it is not a beginners kit.
The high end large kits (now laser cut) with fitment being so perfect, that though classified as advanced, it perhaps could be qualified as much easier to build... anyway my thoughts.
I decided to do the build and pass it back to my brother given the emotional connection is truly with him.
My wife is Dutch descent and given my trips to Holland and having seen my fair share of Dutch river barges... I do find them absolutely beautiful!
I have decided to build it completely out of the box with no upgrades with the exception of the sails.
I started this in the fall and worked on it here and there... I did forgot to take some early pictures but this is what I have to show for...
This thing was not easy to plank at the bow for me and given it is single planked construction, I knew really quickly that this was a plank and paint project... which all of the working Dutch barges' hulls are anyways  - painted.
Julian
Current: Mamoli - Friesland
Finished: Billing Boats - Bluenose
Mamoli - Santa Maria, Billing Boats - Dutch Sperwer
On Hold: Caldercraft - Bomb Vessel Granado
I did plank the deck and cabin floor boards with left over strips from an other kit that is finished... turned out looking good, especially with a couple coats of varathane.
Not so good is how the bulwarks fit and became a real mess for me fast!
Some layers of wood fill and touch ups and now looking a bit better... as exemplified in the post to follow.
Julian
Again, building the kit with supplied parts (often plastic), with touch ups to follow, especially on the hull.
Unfortunately a bit stalled as waiting to put together a large order of stuff from Cornwall Model boats... short on matching Admiralty paints in order to finish painting the hull (and acquire other fittings for my future project of an old vintage Mamoli Friesland kit which I purchased off of EBay- which surprise surprise is missing a few parts. Lucky that Dusek Models is able to supply the missing items via CMB).
Julian
I'll tag along, I am sure your brother will love it. Good luck on your journey.   :cheers:
Edited by Knocklouder
                   WASA
                   USRC Harriet Lane
Very nice work on your Sperwer Julian! Working with older Billing kits certainly has its challenges but you seem to be dealing with them handily. Those planking curves at the bow and stern certainly sure look daunting! I have the Mamoli Catalina coming up next in my build sequence so I will be dealing with a very similar hull. I have also built the Billing Zeeschouw but it had very easy hull planking and it had laser cut parts so it was a pretty easy kit compared to your model.
Keep up the great work and I'll continue to follow along.
Cheers,
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Thanks Peter for your comments…
Funny as I reviewed your entire Cutty Sark build log a few weeks back and enjoyed it thoroughly.
PS… noticed you are on the Island… my parents are retired in Nanaimo and we love to spend time there once a year, time permitting.
Cheers,
Julian
  • 3 months later...
I am certainly not a painter!
Good enough as I am tired of fiddling with my roll of 2mm Tamiya masking tape.
This is the final color scheme...
Edited by mrcc
Julian
A little more work done on the sails...
I secured the reef points with a spot of Tamiya lacquer and it has stained the sail where the drop dispersed...
I thought I had done this once before without ill effects.  I will be brushing on a layer of GAC400 to stiffen up the sails in order to simulate a wind blown effect and I hope the blemishes will disappear.
Julian
Also added more details to the deck.
Secured the bollards with masking tape so they stayed upright while affixing them to the deck railing with a drop of epoxy.
Even though it says 5 minute epoxy, it takes an hour plus to fully cure.
Julian
Started adding details to the sails prior to affixing them on the masts...
Hopefully I can set the mast tonight
Absolutely no rigging instructions in this kit... and a couple of lines I am not able to trace their beginning and ending points but should be easy to figure out anyways.
Julian
Working on some of the rigging details...
As I mentioned, this is an out of box build, and am somewhat embarrassed to show you pictures of plastic blocks.
At the moment, the rigging is loosely affixed and a tightening of all the lines will be done shortly.
Also, I had to do lots of research on the rigging details as the Billing Boats plans are absolutely useless in terms of origin, belay, and termination points.
Cheers
Julian
Both sails are up... lines are all tightened and secured with white glue but the ends are not cut to length or rolled up yet.
Edited by mrcc
Julian
Worked on the kit supplied flag - a self adhesive fold over with an added layer of tin foil.
I hope it curls into a nice shape and yes I know the Dutch flag is upside down on those last 2 pictures.
Julian
Looking good my friend   :cheers:.  At least it's not glued to the ship,  :)
Bob M.
                   WASA
                   USRC Harriet Lane
  • 4 months later...
Completed the build at this time... what can I say...
I am pleased with the look but certainly the cheaper the kit, the cheaper the result. As simple as that...
As I said at the beginning of the build log that it was to be a straight out of the box build.
My painting effort perhaps is not the best... but better next time.
Going to move-on from the experience and at this time going to focus my effort on my Mamoli Friesland (which I have already started).
Thanks for checking out my build log!
Julian
Congratulations, very nicely done!
Nicely done, .     :cheers:  Fine looking boat  !!!
                   WASA
                   USRC Harriet Lane
Hi Julian. Congrats on your fine model. She turned out really nice. I like building this size model between bigger builds like your Friesland. It makes for a nice break of intricate, complicated repetitive steps. All the best with your next project! Merry Christmas! Peter
Thanks Peter… yes it is a nice break from the big builds but this kit had some frustrating elements to its construction. All good though…
I know Corel has a Dutch Royal river boat that looks really interesting as well.. should someone be interested in this specific subject matter.
Yes, Merry Christmas to you as well!
Julian
Are you sure it is Corel? I was only aware of the Mamoli-kit mm61, that is called ‘Catalina’, but isclearly modelled to the ‘Groene Draeck’, the private yacht of theDutch royal family.
Btw: yourboeier turned out realy well, it is a difficult model to build.
Jan
Edited by amateur
