Thanks Peter for your suggestion... PS that's a beautiful Cutty Sark you have there!
A few pictures at this time referencing the rear cabin dormers.
I sanded back the undersides at each end of the wooden part in order to create a slight convex surface in order for the part to sit with more contact to the curved roof below. Once I got a good "seat", I traced the bottom side profile to follow the side contour of the roof line and then traced a gentle curve to the fore edging, sanding back with the disc sander, then with a file and then hand sanding with sandpaper in order to get the dormer shaped for initial fitting. I need more concavity in the fore 1/3 of the dormer on each side...
Julian
Current: Mamoli - Friesland
Finished: Billing Boats - Bluenose
Mamoli - Santa Maria, Billing Boats - Dutch Sperwer
On Hold: Caldercraft - Bomb Vessel Granado
Very tricky work filing the window profiles out to accommodate the laser cut windows (that I am picking up tonight).
The thin plywood openings were so fragile to file and prepare (in this estimated 45 year old kit)... I just took it very slowly with a fine file in order to minimize the destruction of the ply.
The last picture references the completed  part for use.
Julian
More work done on the quarterdeck galleries...
After rough cuttting out the material for the windows, I was able to get a tight and clean margin for the windows to pop in with a simple file.
I received the new windows from a friend's friend that had a laser cutter at home. Very well done in my opinion!
The green ones are plastic and came with the kit, allowing for only one per side gallery.
It seems as all the build logs on MSW added the full compliment of windows to their builds.
Additionally, I soaked the fascia boards in hot water for just a few minutes, and then with an electric plank blender, bent the parts to follow the frame on the hull in a bending and twisted fashion, and then pinned them to the hull in order to fully dry.  Very different from how Mamoli advised to do it...
Julian
I am a big believer of a picture tells a story, and a 1000 word story at that...
Lots of work and "stress" in getting this gallery part to fit right as this was NOT an easy process.
The instructions from Mamoli would absolutely not work in this process... and this is how I did it.
First did some edge bending of the plank (2x4mm), getting an OK bend for the side profile of the galleries.
I then used the electric plank bender to bend the gallery windows in a bend and twist fashion (after a quick soak in water), then gluing the gallery window pieces to the hull and allowing it to dry completely on the hull and only then did I attach the pre bent plank to the top and bottom profile as evident in the fourth picture.
I then cut out the acetate and glued them to the inside profile with a hot glue gun and only then gluing the completed assembly to the hull.
This final step turned out very well but lots of CA glue and wood glue and clamps as the pre bent profile was not perfect to complete the attachment.
The last 2 pictures show the completed gallery with the acetate and openings ready to receive the laser cut windows once painted.
Julian
Quite the process Julian, but the results look great. I really like the black acetate you used to replicate the window panes. All the best going forward.
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Indeed great work.
Instructions that come with these old kits are not always clear.
Working on an old Corel kit, the instructions actually stop as soon as the hull is planked. After that there are 2 drawings and an Italian text...
exciting 😇...
Thanks Patrick for your reply…
Mamoli has a decent set of instructions with very good illustrations I should add but the problem is that there are frequent omissions to those instructions and plans. Then you have to deal with kit design problems and issues with  fitting of parts. I found myself instead referencing the building logs on MSW for the extra clarity and it’s all good.
I view these challenges as all part of the learning experience.
The building continues… 😊
Cheers!
Edited by mrcc
Julian
More work done... and only now time to post some progress.
My laser cut windows were an excellent fit on the side galleries.
Not so great on the stern gallery windows... will get those recut as the stern windows are slightly larger than the side profile windows unbeknownst to the person cutting the windows.
Julian
Completed the side gallery dormers.
First laying out the bands of 3mm with a 2mm overlay.
Also worked on the side gallery dormer windows... lots of fiddly work, first milling by freehand with my Dremel, the inlay for the windows and acetate, then milled the side channels in order to fit flush inside the bands and then sanded back the inside profile in order to fit flush to the hull.    NOT much fun here...
Edited by mrcc
Julian
Lastly, glued in the side gallery dormer piece, drilled a hole into the side hull as I believe I will pick up some of the LED lighting (embedded inside) from this window, and laid the window in with a piece of acetate underneath.  I will do a wood fill to clean up the margins of the inlay I did with the Dremel.
I laid out the roof shingles while also adding a small fill piece at the bottom as the ornament to come later will cover the fill piece.
Bit of a "dog's breakfast" but good enough.  I may peel a couple of the shingles at the very top, one on each side, as I think I can make it look a bit better...
This hobby makes it very hard to be a perfectionist...
Julian
Here's a problem I need to address...
The line drawn in with pencil is actually level to the decks.
The entire rear stern has a twist that was noted earlier but perhaps being in denial, has now come to haunt me. The bulkheads never did fit properly and with a vintage kit, and loose fittings of bulkheads into the keel, and the large tolerances in the fitting of the parts, this is what I now get.
Frustration but an added learning element as I think I can optically reduce the perception ever so slightly by adjusting to a more level state the rear ornaments one by one to appear more level to the deck lines going from the top to bottom... in the future. But I need to address the discrepancy to a degree in planking the rear stern as this is the next step in the plans.
Julian
Finished the rear gallery panel and planking below... on further assessment of the slight twist of the stern counterclockwise, I realized it was only the last frame that was such and not the rear keel and frames. Good news for me... with regards to correction, I just dropped the starboard side of the rear panel, probably about 1 mm downwards, to clockwise, and created a better optical effect of a more balanced appearance.
I started to prepare the transom framing and everything looks good in my mind...
Julian
The next issue to contemplate is the supplied stained planks.
Seems like they are so faded and dull... I decided to experiment (with a can of forest green stain that was 25 years old) and see how they look with a re-staining.
The plank on the right was a plank from the first layer of hull planking and they both look good and even in shading should I need extra planks as it seems on the old kits, people are barely supplied with enough.
Edited by mrcc
Julian
Got all the planks stained to a darker shade which I prefer. Some planks did not take the stain as well as others.
Finished the transom planking... and now on to planking of the hull with the finish layer per the Mamoli instructions.
Going to wait on finishing some of the stern and gallery ornaments until more of the hull has been finished.
Edited by mrcc
Julian
That is really coming along Julian. Really nice colouring on the stern. What paint did you use on the ornamentation? I could use that on one of my later builds.
Cheers,
Peter
Hi Peter...
I have yet to paint any of the ornaments yet but will likely focus on Gold with minimal other color highlights... yet to come.
The planks on the transom were stained with a water based Minwax Hunter Green color, left over stain from a furniture project from 25 years ago and the stain is still perfect to use even though stored in the garage in at times freezing weather conditions ie Alberta winters.
Cheers!
Julian
Started to plank the hull... following the instructions in terms of order of construction but taking some liberty on color scheme as no directions in that regard - painting the wales a dull black.
Once the top wale was set, it was quite easy, but very tedious work in the lower planks' and wales' placements, especially with regards to marking them off around the gun ports.
Placed the bottom 2 planks in full width at the bow but needed to take off some material in order for the next wale to lie better.
Pleased with their lie on the port and starboard sides but will need some fill at the bow.
Julian
Nice work , Julian. How long and how high will the ship  be when finished?    :cheers:    Bob  M.
                   WASA
                   USRC Harriet Lane
Thanks Ronald for checking out my build log…
Yes, my wife is Dutch and well aware of the Fryslan connection.
Her ancestral roots are from Rotterdam.
We are in Holland from Canada every 3-4 years for a visit.
Julian
Thanks Zappto... I really appreciate you checking in on my build log!
Some progress on planking but it has been a slow go as busy with work and then away on holidays for 2 weeks in Greece.
Anyways here is some progress...
I did have to taper the rear stem post as I decided to completely plank the post and rudder and you need to taper back down to account for the thickness of the planks otherwise the pintles won't fit. Nothing noted in the instructions  but do know this from my previous Mamoli Santa Maria build. Same for the rudder...
Definitely need some fill between some planks in some areas of the hull.
I think I did a better job of planking on my previous Santa Maria build.
Edited by mrcc
Julian
