The front mast has received its sail..
The sails are made of paper from a flower shop that is only 0.05 mm thick. Below are the steps of production.
-Port and starboard sides printed together
-Folded along the center line and glued together
-Cut out
-Leek rope glued on
I know the logs are a bit too thick...
Alvb
14 hours ago, Rik Buter said:
Yes, they are boat hooks.
Rather than boat-hooks (because they actually do not have hooks at the end) I think these are poles for 'poling' the boat along canals or to push it across shoals (of which are a lot in the Zuiderzee and the tidal waters around). The fork at the end would suggest this. Such poles can still be found on Dutch craft.
If it were a pole it would interfere with the leeboard operation and if stowed on the outside of the hull would make it likely to get separated and lost. Early artist were at times sketchy about details.
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
We are making progress in small steps. The main mast and its sail are up.
One thing is giving me a bit of a headache now.
The sail sheets are led over "Leuwagen" or sheet brackets (what is the English term?). But where are they attached? Looking at contemporary depictions, the jib sheet could be attached to the lower block, but the main sheet could be attached somewhere further in front of its "Leuwagen".
What do you think about it?
Alvb
Van der Velde was not sketchy on details. So when he draws something, there was somehing. I know of things misding from his drawings, butnot of ‘making up’. A boathook or pole is the most likely. Often those are stoeed on the shrouds, but these ships dont have those. Given length and the fact that you should have them on hand, outboard stowage is logical.
Jan
Sail sheet: attached to the lower block of the tackle. Left overvRope coiled on deck, or attached to the nearest side. As far as I know both for main and jib.
Does your rigging also has the so-called ‘dirk’: a rope running from the mast top to the end of the boom?
Jan
Thanks Amateur,
I arranged the sail sheet like this on the foresail, and on the mainsail I placed it on the side of the ship. That's how I interpreted the illustrations.
The same applies to a dirk only on the mainsail. The dirk cannot be seen above because it runs on the port side and is therefore hidden by the sail.
Alvb
Edited by Alvb
