Hi all,
Just recently started ship modelling after a long lay off, interested to know of any UK or European based outlets where I can acquire planking screws,  have tried various methods and am keen to try this one.
Tony
Hi Tony,
Miskin models. Set of 12 scew clamps £10.95 although at the moment they are out of stock. Excellent item I usually predrill the the hole first.
Ken
Started work on Constructo's 'Emma' a Baltimore Clipper Sidmouth 1815, she's an older model 1:50 Scale, and what may I ask is your current project?
Was a busy builder 20 - 30 years ago.  Spending most of my time building up my tool chest, lost and mislaid most of my kit, but I guess I'm 75% stocked up again.
Edited by Tony H
Caldercraft Diane, adout 4 years in so far. Only work at weekends and holidays.One of the older Caldercaft kits but still very nice kit. You should start a build log, will look up Emma'a Baltimore to get an idea what your building.
  • 1 year later...
I have been using commercially made plastic planking screws for years. They work quite well  but after a while the head of the screw starts slipping in the plastic casing. It is not accessible and super-gluing it on the outside is only partly successful.
I thought about investing in the Micromark metal clamps, but they are a bit expensive. I then came up with the following idea and made a set of my own planking screws.
Sneaking into the back yard under the cover of darkness, I pilfered some of the Admiral's plastic pegs from her peg basket.
I dismantled the peg and cut off the ends
I then used some 8mm dowel and some 4G by 20mm wood screws to make the `handle' of the planking screw.
4G by 20mm was the thinnest/longest screws I could find so I had to recess them into the dowel so they were long enough to go through the bottom. I had to grind the screw heads a little so they would fit through the dowel.
post-1505-0-91903900-1413879186.jpg   post-1505-0-44682300-1413879212_thumb.jpg post-1505-0-29162400-1413879241_thumb.jpg
I then cut notches, using my hobby knife,  into the `wedge' of peg that I had cut off and drilled a hole as close to the end of the notch as possible (this gave the most leverage when screwing in the planking screw)
post-1505-0-06787300-1413879409_thumb.jpg   post-1505-0-45855300-1413879435_thumb.jpg
The pic above shows a peg end with
and without the slot
I then fitted the dowel `handle' to the peg `wedge' to create the planking screw.
It did not take long to make up a set
They worked quite well, especially on straight runs
I thought I was very clever until the Admiral questioned me about all the half pegs in the rubbish bin! Gulp, I knew I should have buried the evidence!
Hornet
             Current build HMS Granado - Caldercraft
             Completed Ship Builds. - USRC Harriet Lane - Model Expo.
             Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
Yep, sure did Brian!! Won't be buying any more though.
Hornet
This is a simple and smart idea. Thank you for sharing!
Sincere Regards,
Bill
Passion is Patience...and I am a carpenter in any scale.
Current build;  Endurance - 1:70 scale, Occre
Current build;    H.M.S. Surprise - 1796, 1:48 A L
  • 5 months later...
I had the same problem with the nylon headed plank screws.  Glue doen't work but heat does.  Use a small torch and when the screw gets wobbly, remove the torch and then be sure the metal screw is alighned with the nylon and let it cool off.  Done,
Duff
  • 2 months later...
Don't you have problems with the size of the screw? I will try but with 2x18mm because i think that 4x20mm will make problems to the plywood
Current build : Sovereign of the Seas - Mantua 1:78 scale
Finished:        San John the Baptist - Cross section
                    Santisima Trinidad - Cross section                  Galery Santisima
                    San John the Baptist ( San Juan Bautista)    Galery  San John
                    HMS Victory 1805 - Cross section - Corel 1:98 scale
                    Panart (Mantua) 740 Battle Station          Battle Station Panart 740 Galerry
On Hold:        HMS Bounty 1:64   Mamoli MV39
  • 11 months later...
I bought those Micro Mark clamps too. The problem with them was that the material used is very soft (some lead/tin alloy) , leaving dark marks into the planks. They also bend very easily under pressure.
This is why I made my own clamps of 6 mm brass rod, which was knurled and a 2 mm hole drilled into one end. A 2x16 mm screw was epoxied to the hole. Pressure part was made of 2 mm plywood, and the clamp was ready and didn`t cost anything. No dark marks any more into the planks:
Drawing pins do the job for me. Works a treat.
Regards, Scott
Completed builds:
Awaiting construction:
  • 3 years later...
